Old 26th February 2018, 10:09   #15561  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Looks like simple audio delay -250ms fixes a/v sync. Please verify for each movie in PREVIEW SCRIPT before encoding!
Btw. MPC-HC will crash if width is not divisible by 16 in preview script! Resize to common 1920x800.
Old 26th February 2018, 13:16   #15562  |  Link
dracore
what version was the first updated for threadripper please - i have gone back to version 1.18 and having no issues at all now with files encoding but slow speed with my threadripper :/
dracore is offline   Reply With Quote
Old 26th February 2018, 15:08   #15563  |  Link
Atak_Snajpera
There is no such thing as "updated version for threadripper". Your downloaded files are broken/corrupted. That's all.
Old 26th February 2018, 17:01   #15564  |  Link
byteshare
ByteShare
byteshare's Avatar
Microsoft Visual C++ Redistributable for Visual Studio 2017 will be installed automatically if necessary.
Skip demuxing basically means "Do not demux audio/subtitles" I don't remember now but some of you requested this option.
Thank you! I've been wanting something like this for a long time...My HD also thanks you
Old 26th February 2018, 19:10   #15565  |  Link
Viper714
Atak:
Thank you for the fix in the a/v sync. Turned out to be -500ms. Also now resizing to 1920 x 800 as well.
I appreciate all your work on this great program!!
Viper714 is offline   Reply With Quote
Old 26th February 2018, 20:40   #15566  |  Link
jlpsvk
Thanks for making my wishes a reality. HDR/SDR per job and no demux at job create.
Maybe just a cosmetics, I know what it means, but maybe you can rename the choices from BT.2020/BT.709 to HDR/SDR. Will be easier for novices in encoding.
jlpsvk is offline   Reply With Quote
Old 26th February 2018, 21:08   #15567  |  Link
Atak_Snajpera
But I like weird numbers...
Old 26th February 2018, 22:46   #15568  |  Link
GZZ
Updated to newest version 1.22.2 and added a few movies using the batch mode, setting Color Pri to BT.2020. But in DE mode it encode a HDR movie in BT.709. I even tried to stop encoding and making sure its BT.2020 and still keeps encoding in BT.709. So something isnt working.
""\\Ripbot264temp\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "\\RipBot264temp\job90\Chunks\1.avs" -strict -1 -f yuv4mpegpipe - | "\\Ripbot264temp\tools\x265\x265_x64.exe" --seek 0 --colorprim bt709 --transfer bt709 --colormatrix bt709 --crf 19 --fps 24 --min-keyint 24 --keyint 240 --frames 2859 --sar 1:1 --profile main10 --output-depth 10 --y4m --output "\\RipBot264temp\job90\Chunks\1.265" -"
y4m [info]: 3840x1600 fps 24000/1000 i420p10 sar 1:1 unknown frame count
Update:
Its fubar, cant force it to use BT.2020, no matter what I choose in the color pri box its stuck at bt709. Hope you can do a quick fix for this!
And no I dont have the "Force HDR to SDR Conversion..." checked under settings. Will the color pri. automatically be set to BT.2020 when a HDR movie is detected or will it also start out in BT.709 mode ?
GZZ is offline   Reply With Quote
Old 27th February 2018, 00:32   #15569  |  Link
dracore
wrong on one of your releases you said updated for ryzen/threadripper and it shows as the newest versions encode very much faster for me with my threadripper but when i tryd 1.18 all files encoded 100% perfect but with an added 2hours on each file encode time
Old 27th February 2018, 12:02   #15570  |  Link
Atak_Snajpera
Update:
Do you see HDR icon for this video file? I suspect that your video is not detected as 10bit video. Post media info report.
Old 27th February 2018, 13:21   #15571  |  Link
GZZ
It is HDR, tried several UHD movies and the symbol is on.
I know there is a few UHD movies in SDR (Stranger Things is one of them), but this is not one of them. I can upload a screenshot later today to prove it and also post the mediainfo file.
One thing I also noticed and your screenshot proves it, is why does it set Color Pri to BT.709 when the HDR symbol is one, shouldnt it be default to BT.2020 when its HDR ?
Old 27th February 2018, 13:59   #15572  |  Link
Atak_Snajpera
Lol! Because I was testing to see if I could confirm your report.
My screenshot proves nothing...
Just post mediainfo report.
All my HDR movies/Samples have this (required) information.
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000
Mastering display luminance              : min: 0.0050 cd/m2, max: 4000.0000 cd/m2
Maximum Content Light Level              : 1529 cd/m2
Maximum Frame-Average Light Level        : 380 cd/m2
Ps. Happy now?
"C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "C:\Temp\RipBot264temp\job1\job1.avs" -strict -1 -f yuv4mpegpipe - | "C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\tools\x265\x265_x64.exe" --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50)" --max-cll "1529,380" --crf 20 --fps 24000/1001  --min-keyint 24 --keyint 240 --frames 10059 --sar 1:1 --profile main10 --output-depth 10  --y4m --output "C:\Temp\RipBot264temp\video.265" -
Old 27th February 2018, 18:49   #15573  |  Link
GZZ
Im sorry for wasting your time. I found the issue, I had a movie added in the queue from previous version of ripbots (1.22.1) and I then updated the application and tried to encode the already added movie and that didnt work out as it should.
So after a bit more testing I ended up removing the movie and added it again and this time it worked as it should.
Mediainfo on the movie:
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2 h 1 min
Bit rate : 47.3 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.238
Stream size : 40.0 GiB (90%)
Language : English
Default : No
Forced : No
Color range : Limited
Original source medium : Blu-ray
Maximum Content Light Level : 810 cd/m2
Maximum Frame-Average Light Level : 498 cd/m2
Old 28th February 2018, 14:42   #15574  |  Link
dracore
you was 100% right i tryd the encodes again from a full backup of the
blurays and everyone worked 100% perfect, sorry for being a pain
Old 28th February 2018, 19:02   #15575  |  Link
byteshare
ByteShare
byteshare's Avatar
Error while batch importing:
----------[2018-02-28 11:39:49]----------
File: C:\Dracula - Sovereign of the Damned [No Audio].mkv
I don't know what 'erlace' means.
(C:\Temp\RipBot264temp\job492\getinfo.avs, line 2)
Media Info:
General
Unique ID                   : 230681051269935516350657022109326458464 (0xAD8B8DEEC111A49E04D6F61FC0333E60)
Complete name               : C:\Dracula - Sovereign of the Damned [No Audio].mkv
Format                      : Matroska
Format version              : Version 4 / Version 2
File size                   : 963 MiB
Duration                    : 1 h 29 min
Overall bit rate            : 1 502 kb/s
Encoded date                : UTC 2018-02-28 16:06:37
Writing application         : mkvmerge v20.0.0 ('I Am The Sun') 64-bit
Writing library             : libebml v1.3.5 + libmatroska v1.4.8
Video
Format                      : MPEG-4 Visual
Format profile              : Simple@L1
Format settings, BVOP       : No
Format settings, QPel       : No
Format settings, GMC        : No warppoints
Format settings, Matrix     : Default (H.263)
Codec ID                    : V_MS/VFW/FOURCC / FMP4
Bit rate                    : 1 500 kb/s
Width                       : 704 pixels
Height                      : 480 pixels
Display aspect ratio        : 4:3
Frame rate                  : 29.970 (30000/1001) FPS
Standard                    : NTSC
Color space                 : YUV
Bit depth                   : 8 bits
Scan type                   : Progressive
Compression mode            : Lossy
Bits/(Pixel*Frame)          : 0.148
Stream size                 : 962 MiB (100%)
Writing library             : Lavc51.40.4
Default                     : Yes
Forced                      : No
Guessing it is the codec?
Update: also same error with a MPEG-4 Visual (DIV3) file.
Both worked after encoding them to H.264 RF0 in HandBrake
Side note: moving an encode up 400 positions (not wanting to turn everything else off) is a lot of work. Some better queue management would be the last thing I think RipBot is missing IMO.
Old 28th February 2018, 20:01   #15576  |  Link
FuzzyNutz
audio and subtitles not demuxing for .mkv files
My v1.22.2, which was recently tweaked by the Auto-update function, no longer demuxes audio or subtitle tracks when loading .mkv files.
FuzzyNutz is offline   Reply With Quote
Old 28th February 2018, 20:14   #15577  |  Link
Atak_Snajpera
@byteshare
upload job492 folder (without audio, video and subtitles)
Old 28th February 2018, 20:15   #15578  |  Link
Atak_Snajpera
See if option "SKIP DEMUXING PROCESS" is not checked.
Old 28th February 2018, 20:22   #15579  |  Link
FuzzyNutz
It is not checked.
Old 28th February 2018, 20:24   #15580  |  Link
Atak_Snajpera
Try this.
1) Check it
2) Apply
3) Uncheck it
4) Apply
