Thread Tools Display Modes
Old 9th November 2025, 03:27   #1901  |  Link
isidroco
Originally Posted by rgr View Post
I found the cause. If I leave the default path in the Deshaker filter ("C:\Users\Właściciel\AppData\Local\Deshaker"), VDub crashes when saving the project. Until I save the project, VDub (or rather the filter) saves everything correctly to that path.
Maybe it's caused by non ascii user: "Właściciel" had problems before with Paths/names including spanish: áéíóúñ in both AVIsynth and deshaker... Now I avoid using those.
isidroco is offline   Reply With Quote
Old 9th November 2025, 07:37   #1902  |  Link
v0lt
I think in VirtualDub2 v2.5.0.1005+ this problem may no longer exist.
v0lt is offline   Reply With Quote
Old 10th November 2025, 16:02   #1903  |  Link
jay123210599
How do I add subtext and assrender as plugins for VirtualDub2?
jay123210599 is offline   Reply With Quote
Old 10th November 2025, 16:17   #1904  |  Link
LigH
LigH's Avatar
Not at all. They are for VapourSynth, which is a Python based scripting engine. You can load a VPY script in VirtualDub2, but the VapourSynth script will have to load the source file and handle all the filtering outside, and VirtualDub2 will only pass the result through to the encoders and save the result.
New German Gleitz board
Old 11th November 2025, 15:19   #1905  |  Link
rgr
This problem has been gone for a long time, I don't even remember which version it was.
rgr is offline   Reply With Quote
Old 11th November 2025, 17:38   #1906  |  Link
jpsdr
In fact, the "plugins32" and "plugins64" folders were never needed.
But for me it's pratical, it gives some kind of order, not putting every files in haphazardly.
My github.
Old 12th November 2025, 21:09   #1907  |  Link
blob2500
is it possible that one day you will also update the integrated x264 codec (vdplugin) ?
x264 - Core 157 r2935 is quite dated (feb. 2019).
Thanks
Originally Posted by LigH View Post
An updated plugin has been posted in the VideoHelp forum, did not test yet...
I tested this plugin update (core 164 r3191) it works well, but the encoding is slightly slower; approximately around 3-4%.
blob2500 is offline   Reply With Quote
Old 12th November 2025, 21:56   #1908  |  Link
Washka
Washka's Avatar
I also using x264, x265 have a little too smooth image for vhs even on higher bitrate.
Washka is offline   Reply With Quote
Old 13th November 2025, 04:10   #1909  |  Link
v0lt
Originally Posted by blob2500 View Post
The source code is here - https://sourceforge.net/p/vdfiltermo...i/master/tree/
Need:
1. Rework the old project file for Visual Studio 2019 or 2022.
2. Automate the x264 library build.
3. Merge codec_8 and codec_10 (I think this separation is no longer necessary, and the bit depth could be selected in the x264.vdplugin settings).
4. Make the updated project publicly available.
Old 13th November 2025, 11:06   #1910  |  Link
blob2500
If I'm not mistaken, the version of the plugin currently present in virtualdub2 is based on the latest "official" vfw version (2017):
https://sourceforge.net/projects/x264vfw/files/
To avoid too much work, wouldn't it be possible to build directly on this?
https://sourceforge.net/projects/mpxplay/files/x264vfw/
It's updated to 2025, and I think many things are already ready, such as the 8/10-bit color depth unification.
(there is also the x265vfw version on the same author's site)
Old 13th November 2025, 11:09   #1911  |  Link
LigH
LigH's Avatar
The VDub2 codec plugin is not a VfW codec. It is not to be installed in Windows. And I guess it has a more flexible interface to integrate into VDub2 better.
Old 13th November 2025, 11:30   #1912  |  Link
blob2500
Yes, I know that. But it's irrelevant. Maybe I didn't explain myself well, sorry.
I meant to base the plugin version on the most recent vfw version of x264. The plugin version, including the current one (core 157 r2935), is derived from vfw r2851, then updated by the previous VirtualDub2 author to r2935.
If I replace the vfw's .dll extension with .vdplugin and place it in the plugins folder, it works like a normal VirtualDub2 codec plugin. However, some superfluous features remain available that should be removed from the plugin version, such as the vfw/external file drop-down menu, typical of the vfw interface.
https://forum.doom9.org/showpost.php...9&postcount=89
Originally Posted by shekh
What is x264 plugin (actually 2 plugins for each bitdepth): this is basically x264vfw from https://sourceforge.net/projects/x264vfw/ with some cosmetic changes:
VFW API is extended to support format negotiation etc.
File output is removed.
Decode support is removed.
Format conversion is disabled (handled by VD).
In fact some arbitrary vfw codec can be simply renamed as vdplugin, this may be useful to have many portable versions of same codec.
Old 13th November 2025, 14:37   #1913  |  Link
LigH
LigH's Avatar
I guess I should notify autodidact in the VideoHelp forum if he may be able to participate here.
Old 13th November 2025, 15:44   #1914  |  Link
blob2500
Thank you very much for your interest, LigH
Old 13th November 2025, 16:20   #1915  |  Link
v0lt
It works, but only as an encoder (decoding does not work).
https://github.com/shekh/VirtualDub2/issues/7
Old 13th November 2025, 19:14   #1916  |  Link
blob2500
xvid, however, is an encoder that can already be used as a plugin by placing it in the virtualdub2 plugins folder. Of course, the decoder code remains inside, and as you mentioned, it doesn't work.
Moreover, the x264-8.vdplugin / x264-10.vdplugin plugins also don't work as decoders. For that, we can use the other libraries already present in virtualdub2;but it is not possible to make cuts without recoding
The new x264vfw by mpxplay can already be used as a plugin, but unlike Xvid, there are still some ambiguous entries in the user interface that should be removed and can cause problems, such as those related to "virtualdub hack," which shekh had removed to derive the plugin from the original vfw version.
"virtualdub hack" should always be enabled with virtualdub's native avi output, but should certainly be disabled in other cases if I remember correctly (certainly if you choose "output file" from the vfw interface) otherwise you get an incorrect frame order. Options removed; rightly so, for a codec that is intended to be "integrated" into virtualdub2, a second output file in encoder interface makes no sense.
Old 14th November 2025, 04:56   #1917  |  Link
v0lt
Test build VirtualDub2 v2.5.0.1026
Improved Unicode support.
Updated avlib_vdplugin 1.1.0.426
- Fixed a crash when opening AviSynth+ scripts in some rare situations.
Old 14th November 2025, 08:13   #1918  |  Link
LigH
LigH's Avatar
At least, autodidact published an April 2025 build of x264 plugins (0.165.3215 32c3b80).
Old 14th November 2025, 20:32   #1919  |  Link
rgr
Test build VirtualDub2 v2.5.0.1005
Set "activeCodePage=UTF-8" in the application manifest. This will add support for AviSynth+ scripts with Unicode character paths.
Unfortunately, I don't know if a complete transition to UTF-8 is premature.
I see some Avisynth plugins don't accept UTF8 filenames, such as TimeCodeFPS. Such a script loads correctly in VDub, but "ffmpeg -i script.avs" throws an error when the plugin reads the file.
So far I have been using code page 1250 and there was no problem (apart from the lack of national characters in the VDub editor).
I'll add the "ProductVersion" field, but I doubt this will fix the Windows bug for VirtualDub2. Perhaps the very fact of changing the executable file had an impact.
Well, it didn't help. But I'll check after restarting the computer.
Old 15th November 2025, 07:05   #1920  |  Link
v0lt
Have you tested these encoders?
I can add them to the next VD2 build...
Your observation shows that "activeCodePage=UTF-8" works well for VD2 and should be applied to ffmpeg.exe as well (perhaps this can be done via an external manifest file).
Thread Tools
