#5441 | Link |
Athlon II @ 2.2Ghz w/HD6570, Win7 x64 Ult
HD: 77fps DXVA2: stops at the end of the first pass, no stats, same as the failure I listed above for the 6520. Yeah, I'm pretty sure it just stops, I waited a couple of minutes, it says :18/:18 and then it just sits there, GraphStudio is responsive at that point. Not sure what to make of that. |
#5442 | Link |
Does this mean there is no hope for ATI HW deinterlacing with MadVR? For now the workaround for me is to use EVR.CP when I want to watch an interlaced video (which thankfully for me is a minor thing). I could alternatively run ffdshow raw video filter + yadif SW deinterlacing but I'd rather keep my filter chain as direct as possible. (LAV splitter - Lav Video - MadVR/EVR)
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S |
#5443 | Link | |
Maybe there also are some tricks to make it faster, but i don't have any ATI hardware to test things on. The odd thing is, somehow VLCs DXVA works on ATI/AMD as well, and they copy the image back from a D3D surface as well, so there must be some trick.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 10th September 2011 at 23:35. |
#5444 | Link |
Same for me, with DXVA2 its pretty much a slide show.
Just hope the AMD HD 7xxx will solve this.
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) |
#5446 | Link |
Not that I care much for interlaced content, or think the aged hardware can handle it, but both my laptop's integrated Intel and nVidia graphics are failing with same kind of error:
Intel GMA HD http://tinypaste.com/32bd1 nVidia 310M http://tinypaste.com/59667 |
#5447 | Link | |
![]() Anyway, the main point of info i got today was that ATI/AMD is still too slow in this area, and sadly doesn't even support DXVA-HD at all. Personally, i use NVIDIA in all my systems, so i don't care that much of a great deal. That Intel supports DXVA-HD is nice, although its also too slow (NVIDIA 200 fps, Intel 30 fps) - but it leaves me hopeful for future Intel drivers/IGPs Since i want to move away from hardware decoding due to some limitations and annoyances of the black-box decoders, i'll continue this idea, and see where it brings me. LAV Video + DXVA-HD processing to deinterlace .. sounds like a good plan!
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 11th September 2011 at 00:05. |
#5448 | Link |
Nev, do you have any idea why I only got ~93 fps with the test build? I have the same gfx card as you do.
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 |
#5449 | Link | |
You probably have a slower CPU. EDIT: nvmind. missed your CPU image. nevcairiel's comment cleared it. Last edited by Superb; 11th September 2011 at 00:19. |
#5450 | Link | |
Its probably some setting in the NVIDIA control panel, like forcing a high level of AA system-wide, or enabling things like noise reduction/edge enhancement. Its also running in the "Playback" preset, which means it doesn't go up into the next performance mode as long as its fast enough for the FPS i gave it.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 11th September 2011 at 00:20. |
#5452 | Link |
I thought I had disabled all that stuff so I took a screenshot of the settings, please see screenshots below:
General settings (combined two pictures so that you see all settings) video image settings video color settings
#5453 | Link |
No video visible and alot of
LAVVideo.ax(tid b2c) 174340 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174373 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174407 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174440 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174473 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174507 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174540 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174573 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174607 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174640 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174673 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174707 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174740 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174774 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174807 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174840 : VideoProcessBltHD failed (hr: 80070057) LAVVideo.ax(tid b2c) 174873 : VideoProcessBltHD failed (hr: 80070057) else normal it runs 160 fps and with this build 140 fps (null renderer) Core i-5 2400 Driver Version: 8.15.10.2476 Operating System: Windows 7 Service Pack 1(6.1.7601) Default Language: German (Germany) DirectX* Version: 10.1 Physical Memory: 8039 MB Minimum Graphics Memory: 128 MB Maximum Graphics Memory: 1760 MB Graphics Memory in Use: 163 MB Intel(R) HD Graphics 2000 Video BIOS: 2080.0
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 11th September 2011 at 01:05. |
#5454 | Link |
DVD Playback
I've been trying to get regular DVD iso images to playback via LAV. Is this not supported (menu and such)? No problems using default MPC-HC setup.
My External Filters setup: Lav Splitter v.35 Lav Splitter Src v.35 Lav CUVID v.12 Lav Audio v.35 Am I missing something? Thanks.
nvidia gts 450 (270.61), Asus P7H55-M Pro MB, Denon 988 AVR MPC-HC v.3456: filters: LAV Audio/CUVID/Splitter .35, MadVR .73 |
#5456 | Link |
Yeah to watch DVD's you need to have another video decoder installed in system which can decode DVD. I use ffdshow libavcodec and it works just fine with DVD Navigator + Lav Audio. I can play DVD's with either MPC-HC or PotPlayer just fine. I'd imagine you could also use your video player's internal codecs as well if they have some that support DVD decoding (MPEG2 + DVD decoding).
Oh yeah I forgot to add, if you bypass the DVD menu's and just open the individual movie VOB files, then Lav Splitter + Lav Video + Lav Audio work just fine for me.
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S Last edited by fairchild; 11th September 2011 at 07:00. |
#5457 | Link | |
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
#5458 | Link |
It requires Windows 7, on XP it won't even load.
Sounds to me its just not finding the required libraries (which are not present on XP)
#5459 | Link |
Win7x64 here.
#5460 | Link | |
Firefox User
Direct3DCreate9Ex() in d3d9.dll, according http://msdn.microsoft.com/en-us/library/cc656710.aspx you have to use Direct3DCreate9() instead. DXVAHD_CreateDevice() in dxva2.dll, you may use dynamic loading instead. |
| Tags |
| decoders, directshow, filters, splitter |
| Thread Tools | |
| Display Modes | |
