Thread Tools Display Modes
Old 15th September 2025, 18:03   #25401  |  Link
Orf
YAP author
nevcairiel, got it, thanks again
Orf is offline   Reply With Quote
Old 16th September 2025, 04:34   #25402  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by Orf View Post
nevcairiel,
In a custom renderer I'm trying to implement support for getting D3D11 texture samples from LAV video decoder directly. I'm utilizing your ID3D11DecoderConfiguration and IMediaSampleD3D11 interfaces for that purpose.
Connection media subtype NV12 is used and LAV Video decoder correctly calls GetD3D11AdapterIndex (I return 0) and
ActivateD3D11Decoding so I have d3d11 interfaces. At the point the DS graph is built LAV video decoder reports 'd3d11 native' is used.
But at point when first sample arrived LAV video decoder get switched to software decoding and first sample is never IMediaSampleD3D11 but IMediaSample instead. At this time it also reports 'avcodec' is used.
I try to investigate why it happens and found that it is not hardware related because:
1) if I return error from ActivateD3D11Decoding LAV video decoder switched to 'd3d11 cb native' and it works fine
2) if I build graph with madVR as a renderer at first and then disconnect LAV Video decoder from madVR and connect it to my renderer 'd3d11 native' starts work with my renderer just fine too
I seems to me that LAV video decoder expects from renderer to do something else, which madVR does and my renderer doesn't.
I try to find what it might be examining LAV source code but didn't find anything that gives me a clue.
So I need your favour with that, can you please shed some light on this?
You can check here how work with D3D11 Native Decoder
https://github.com/Aleksoid1978/VideoRenderer
AMD Ryzen 7 7700 /ASRock B650M Pro RS /G.Skill RIPJAWS 32 ГБ /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Denon AVR-X2800H+NS-555+NS-C444+NS-333+YST-SW215+Klipsch R-40SA
Aleksoid1978 is offline   Reply With Quote
Old 16th September 2025, 09:33   #25403  |  Link
nevcairiel
Originally Posted by lvqcl View Post
No latest nightly build?..
I didn't update the build machine when I upgraded my security keys (so the upload failed), it should be working again now.
Old 16th September 2025, 13:09   #25404  |  Link
Orf
YAP author
nevcairiel already solved the problem I have, but I will check your sources too, thanks
Old 16th September 2025, 21:34   #25405  |  Link
mzso
Hello!
I've not been paying attention for a good while. Is it possible to decode and render correctly (for headphones preferably) Atmos/DTS:X nowadays with LAV? Or any other free software?
Old 16th September 2025, 23:12   #25406  |  Link
HRTF mixing is not a feature.
Old 18th September 2025, 03:35   #25407  |  Link
halcom
Trouble downloading ffmpeg lav0.80.zip from gitea.1f0.de
Anyone else had trouble downloading lav0.80.zip (the LAV ffmpeg fork) from
https://gitea.1f0.de/LAV/FFmpeg
Been trying for about a week now. Just get the spinning wait icon with nothing downloaded. I let it run all night and still nothing.
Tried firefox & chrome but both behave the same. Is there an alternate location to download it?
Any help greatly appreciated!
halcom is offline   Reply With Quote
Old 18th September 2025, 06:04   #25408  |  Link
LigH
LigH's Avatar
This is a source code repo. I cannot find any ZIP archive there.
New German Gleitz board
Old 18th September 2025, 06:59   #25409  |  Link
halcom
More Details
- In the upper right press "tags"
- takes you to a page where you should be able to download zips of the sourcecode for all the versions.
- normally you can simply right click and do a save but the download never starts.
Old 18th September 2025, 08:49   #25410  |  Link
LigH
LigH's Avatar
You are right.
The same does not work for the "Download ZIP" link in the menu dropping out of the blue "<> Code" button. Let me try using git clone ... worked.
Mirror: gitea_LAV_FFmpeg.7z (182 MB)
Old 18th September 2025, 11:03   #25411  |  Link
nevcairiel
That should hopefully work again, for some reason there were thousands of dead requests that were blocking it.
Old 18th September 2025, 14:23   #25412  |  Link
Orf
YAP author
nevcairiel,
few more things I noticed about d3d11 native:
1) when video coded with h264, and 'H.264' checkbox unchecked in 'Codecs for HW decoding' decoder status says it falls back to 'avcodec' but it get stuck then and never outputs any samples
2) the description of ID3D11DecoderConfiguration mentions:
// To facilitate dynamic switching of the adapter used for decoding, the
// renderer should disconnect the decoder and re-connect it. At that
// point the decoder should query GetD3D11AdapterIndex() again and
// create a new decoder on the new device, as appropriate.
but if I disconnect decoder from renderer and try to reconnect it back connect fails with VFW_E_BUFFERS_OUTSTANDING error. Happens only in d3d11 native mode. As far as I see decoder calls GetAllocator and then instead of NotifyAllocator it calls BreakConnect.
This is not implemented yet?
Old 18th September 2025, 16:03   #25413  |  Link
halcom
Thanks for the help!
LigH: Thank you, just downloaded from mediafire !
Nev: Just checked it. Link is working now.
Many thanks to you both!
Old 21st September 2025, 04:28   #25414  |  Link
JarrettH
Just wondering something.....is the hardware deinterlacing better quality than me choosing one of the software options? I was probably going to go with bwdif. Thanks.
btw, I see there were some updates to bwdif back in 2023, likely nev saw that.
Old 21st September 2025, 10:42   #25415  |  Link
a properly working hardware decoding is massively better then the lavfilter software deinterlacer.
but they don't always work or at all.
the nvidia one sometimes works and the AMD one is pretty much broken forever at this point making it sometimes worse then bilinear bob.
the software deinterlacer on the other hand always work as advertised and are fine for true interlaced content with no mixed stuff or telecine.
Old 21st September 2025, 13:47   #25416  |  Link
CruNcher
CruNcher's Avatar
The Problem on the hardware side is the software stack compatibility and Nvidias way of doing things and keeping secrets in their Layers and API functions.
A lot of Nvidias work also comes from Vanguard on the IP
It is about Time
Old 21st September 2025, 15:08   #25417  |  Link
Sunspark
AMD's is broken, don't even try, use software if you have an AMD GPU.
Intel's does work and you can use it, but it's a deinterlacer, not inverse telecine so you still need software for that. If you're receiving e.g. satellite broadcast, then it's perfectly fine to use the deinterlacer. Old film content on DVD, you want software IVTC.
Old 21st September 2025, 18:06   #25418  |  Link
JarrettH
Ah ok, I'm trying it (NVIDIA GT 1030) and all modes are broken Wasn't something broken with D3D11 for a long time? I can't remember if that was resolved. Anyway, bwdif is just fine for the odd time I need to play a DVD.
Old 22nd September 2025, 00:29   #25419  |  Link
CruNcher
CruNcher's Avatar
Could you check if some proprietary stack also shows playback problems in case of Nvidia always a good interop test is Cyberlink PowerDVD, if it also fails for your use case it becomes interesting.
you could and should also try other player implementations like zoomplayer, potplayer ect it could be a very specific combination of setup causing detection and proper VPU Hardware decoding problems.
But the first test should be a complete different stack and here Cyberlink PowerDVD is the first choice.
It is about Time
Old 22nd September 2025, 19:31   #25420  |  Link
lvqcl
Do you use MadVR? It doesn't support deinterlacing in D3D11 mode.
lvqcl is offline   Reply With Quote
Thread Tools
