Thread Tools Display Modes
Old 3rd February 2010, 13:17   #121  |  Link
Darkwhisperer
An update perhaps?
If your'll don't mind my asking, how are the tests going? Is there a planned release date perhaps?
Darkwhisperer is offline   Reply With Quote
Old 3rd February 2010, 13:47   #122  |  Link
J_Darnley
J_Darnley's Avatar
Why does something that was committed need updating?
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 3rd February 2010, 15:09   #123  |  Link
burfadel
The all-in-one x264 is a great idea, however it does rely on a third party decoder that is under continual development. Since the third party tool is under continual development x264 will need to have that component continually updated to include the features added/fixed in the third party provision. The solution would be to simply update those components each time x264 components are updated, in order to stay current.
Old 14th February 2010, 21:06   #124  |  Link
smok3
brontosaurusrex
smok3's Avatar
do we have osx and/or ubuntu-karmic builds?
smok3 is offline   Reply With Quote
Old 15th February 2010, 02:59   #125  |  Link
Audionut
http://doom10.org/index.php?topic=3.0
http://www.7-zip.org/
Old 16th February 2010, 13:09   #126  |  Link
hajj_3
Does this mean we could have a 64bit of MeGUI and use a 64bit of x264.exe with LAVF/FFMS integrated into it? Do we know what kind of speed improvements we would get using this x264 beta compared to using regular x264.exe and avisynth 2.5.8 or 2.6.0 MT alpha?
Old 16th February 2010, 13:17   #127  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
I'm having great results with these new features! I've been doing lots of high speed transcodes of my movie / TV backups to baseline profile H.264 (for the iPhone).
Being able to directly open files in x264 without help from AviSynth, all in "pure" 64 bit is extremely convenient, and is pretty durn cool too
~MiSfit
Old 16th February 2010, 16:42   #128  |  Link
rack04
I'm trying to mux a 264 stream generated by x264 using LAVF as the input method. The source file is mov. When I try to mux to mkv using eac3to it complains that the stream does not contain fps information. Is this intentional or a bug? Using avs input the file muxes without error. I am using this build.
Here is a sample, x264 stats, and vui_parameters:
ffms [info]: 848x480p 0:1 @ 24000/1001 fps (vfr)
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64
x264 [info]: profile High, level 3.1
x264 [info]: frame I:51    Avg QP:18.35  size: 41968
x264 [info]: frame P:1235  Avg QP:23.91  size:  8045
x264 [info]: frame B:2309  Avg QP:28.10  size:  2366
x264 [info]: consecutive B-frames:  6.5% 18.9%  6.3% 63.8%  2.0%  2.5%
x264 [info]: mb I  I16..4: 31.8% 18.9% 49.2%
x264 [info]: mb P  I16..4:  8.4%  8.3%  3.9%  P16..4: 22.0%  8.9%  4.6%  0.0%  0.0%    skip:43.9%
x264 [info]: mb B  I16..4:  0.8%  1.5%  1.0%  B16..8: 20.0%  1.4%  1.6%  direct: 1.6%  skip:72.1%  L0:39.1% L1:47.7% BI:13.2%
x264 [info]: 8x8 transform intra:38.7% inter:59.2%
x264 [info]: direct mvs  spatial:99.3% temporal:0.7%
x264 [info]: coded y,uvDC,uvAC intra: 48.0% 59.4% 29.1% inter: 7.3% 10.9% 3.6%
x264 [info]: i16 v,h,dc,p: 44% 27% 11% 18%
x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 17% 19% 18%  6%  7%  8%  8%  7% 10%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 20% 11%  6%  9%  8%  9%  7% 10%
x264 [info]: Weighted P-Frames: Y:7.9%
x264 [info]: ref P L0: 72.3%  9.1%  9.2%  2.9%  2.6%  1.5%  1.0%  0.5%  0.5%  0.4%  0.0%  0.0%
x264 [info]: ref B L0: 90.8%  4.4%  2.1%  0.9%  0.6%  0.5%  0.4%  0.2%  0.1%
x264 [info]: ref B L1: 98.5%  1.5%
x264 [info]: kb/s:935.79
encoded 3595 frames, 10.60 fps, 935.79 kb/s
   vui_parameters_present_flag: 1
    aspect_ratio_info_present_flag: 0
    overscan_info_present_flag: 0
    video_signal_info_present_flag: 0
    chroma_loc_info_present_flag: 0
    timing_info_present_flag: 1
     num_units_in_tick: 1
     time_scale: 5994
     fixed_frame_scale: 0
    nal_hrd_parameters_present_flag: 0
    vcl_hrd_parameters_present_flag: 0
    pic_struct_present_flag: 0
    motion_vectors_over_pic_boundaries_flag: 1
    max_bytes_per_pic_denom: 0
    max_bits_per_mb_denom: 0
    log2_max_mv_length_horizontal: 11
    log2_max_mv_length_vertical: 11
    num_reorder_frames: 2
     max_dec_frame_buffering: 10
rack04 is offline   Reply With Quote
Old 16th February 2010, 18:26   #129  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
In VFR mode x264 does not write fixed_frame_rate_flag for obvious reasons.
You can use --force-cfr to get Avisynth's behavior in LAVF/FFMS.
Old 17th February 2010, 08:01   #130  |  Link
lucassp
Why does it always default to VFR?
[Intel] Core i5 8500|[ASUS] ROG STRIX Z390-I GAMING|[Noctua] NH-U12S|[GSkill] DDR4 2400 2x16GB|[MSI] RTX2060 Super Gaming X|[Samsung] 970 Pro 512Gb|[Seasonic] Focus SGX 650|[NZXT] H400|[LG] 27GL850
lucassp is offline   Reply With Quote
Old 17th February 2010, 08:50   #131  |  Link
Snowknight26
Originally Posted by kemuri-_9 View Post
5char.
Snowknight26 is offline   Reply With Quote
Old 19th February 2010, 09:49   #132  |  Link
PowerGamer
Currently (x264 rev. 1442) FFMS can't handle raw H.264 streams. x264 opens them with LAVF but is not able to determine total amount of frames in the video being encoded. I wonder if that (inability to determine total amount of frames) has any negative effect on quality/speed of the encoding process (because if it has I can always specify total amount of frames with --frames switch)?
PowerGamer is offline   Reply With Quote
Old 19th February 2010, 10:01   #133  |  Link
Dark Shikari
x264 developer
No negative effect currently. In the future this may in theory change when using 1-pass ABR mode.
Old 23rd February 2010, 04:26   #134  |  Link
bnshrdr
Hey where can I get a completely up-to-date version of ffmpeg so that I can compile x264 with lavf support?
I would have thought git clone git://git.ffmpeg.org/ffmpeg/ would be as up-to-date as it is needed to be but keep getting this warning from x264's ./configure:
Warning: libavformat is too old, update to ffmpeg r18351+
bnshrdr is offline   Reply With Quote
Old 23rd February 2010, 04:38   #135  |  Link
Dark Shikari
x264 developer
You likely have an older ffmpeg installed that x264 is trying to link to.
Old 23rd February 2010, 05:02   #136  |  Link
bnshrdr
Well I actually opened up the x264 ./configure file and saw that it was checking for the function avcodec_decode_video2 in one of the libavformat header files. I went and checked, and what do you know, x264 is right. Is there a chance that the master ffmpeg revision isn't truly the master revision.
Old 23rd February 2010, 06:36   #137  |  Link
Mr VacBob
ffmpeg git is up to date (r21977). You probably have an older version installed somewhere else.
Mr VacBob is offline   Reply With Quote
Old 23rd February 2010, 06:45   #138  |  Link
bnshrdr
As much as I understand your logic, I am using a clean system and have not installed anything.
On line 529 of x264's configure script, it checks for most likely a critical function:
        if cc_check libavformat/avformat.h "$LAVF_CFLAGS $LAVF_LIBS" "avcodec_decode_video2( NULL, NULL, NULL, NULL );" ; then
            lavf_input="yes"
            define LAVF_INPUT
        else
            echo "Warning: libavformat is too old, update to ffmpeg r18351+"
I took the liberty of opening libavformat/avformat.h myself to search for this function prototype and it cannot be found. In fact I scanned the whole source code tree to find out where it actually appears, and found it to be in the header file libavcodec/avcodec.h.
I'll try editing the configure script to check that file instead of the other header file and see what happens.
Edit: I seemed to have tricked it successfully. I compiled x264 with lavf support and tested it and it works. Might wanna take a look at that configure script.
Needs a diff that basically does this:
-if cc_check libavformat/avformat.h "$LAVF_CFLAGS $LAVF_LIBS" "avcodec_decode_video2( NULL, NULL, NULL, NULL );" ; then
+if cc_check libavcodec/avcodec.h "$LAVF_CFLAGS $LAVF_LIBS" "avcodec_decode_video2( NULL, NULL, NULL, NULL );" ; then
Old 23rd February 2010, 14:02   #139  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
A) libavformat/avformat.h includes "libavcodec/avcodec.h"
B) we're specifically using both libavformat and libavcodec
C) you removed the check to see if the critically required libavformat/avformat.h header is actually available/correct
so your change is incorrect and can cause issues. fix your installation rather than hack the configure.
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 23rd February 2010, 15:08   #140  |  Link
smok3
brontosaurusrex
smok3's Avatar
Originally Posted by Audionut View Post
http://doom10.org/index.php?topic=220.0
i have to do everything myself.
beta, ffmpegsource, libavformat, test, x264
Thread Tools
