Thread Tools Display Modes
Old 23rd January 2024, 15:39   #1481  |  Link
Avisynth Wiki:- http://avisynth.nl/index.php/Main_Page
External AviSynth+ x64 plugins:- http://avisynth.nl/index.php/AviSynth%2B_x64_plugins
External AviSynth+ x86 plugins:- http://avisynth.nl/index.php/External_filters
Internal filters:- http://avisynth.nl/index.php/Internal_filters
NOTE, Warpsharp is deprecated, use Warpsharp2.
EDIT:
[Uncategorized files]
C:\Program Files (x86)\AviSynth+\plugins64+\colors_rgb.txt [2022-10-07]
Delete that.
Old 24th January 2024, 05:05   #1482  |  Link
BabaG
ok. so, i'm in the middle of, one-by-one, bringing filters and functions into my plugins64 folder and, sure enough, have hit a snag with this line (230):
denoised=stabcrop.MDegrain2(super, bvec1,fvec1,bvec2,fvec2,thSAD=denoising_strength).levels(0,gamma,255,0,255).tweak(sat=saturation).unsharpmask(PRE_sharp_ness,PRE_radi_us,0)
the error is:
Script error: There is no function named 'unsharpmask'.
not sure how to get past this as pdr has recommended to use another filter for this. do i have to change something in the line (230) to match the syntax of the substitute filter?
as i look into this, it's looking to me as if the warpsharp2 suggestion is what would address this? how woul the 230 line be changed?
edit:
thanks, stainlesss. i deleted the file you pointed out.
thanks,
babag
BabaG is offline   Reply With Quote
Old 24th January 2024, 05:16   #1483  |  Link
poisondeathray
You can replace unsharpmask with updated functions that support high bit depth, so you don't have to downgrade your prores. The original unsharpmask in warpsharp is a 2.5 plugin and does not support other avs+ pixel types like YUV422P10 . You can change the function name to UnsharpMask or change the script UnsharpMask calls to UnsharpMask_avsi
https://github.com/realfinder/AVS-St...Mask_avsi.avsi
Or dogway's sharpener's pack has a variation
https://github.com/Dogway/Avisynth-S...enersPack.avsi
Old 24th January 2024, 06:32   #1484  |  Link
BabaG
hey! that's awesome! it finally opens. very dark, though. will look into that later. thanks so much for all the help! (unfortunately, i'll probably be back soon.)
thanks again,
babag
Old 24th January 2024, 06:38   #1485  |  Link
poisondeathray
Levels filter. 10bit goes 0 to 1023. Edit all the lines with levels . There might be a few more
black_level=0 white_level=255 output_black=0 output_white=255 #manual levels, when returning result2 & result4
result2= PreBorderFrame.levels(black_level,gamma,white_level,0,255).coloryuv(autowhite=true).addborders(bord_left+in_bord_left, bord_top+in_bord_top, bord_right+in_bord_right, bord_bot+in_bord_bot)
Old 24th January 2024, 06:56   #1486  |  Link
BabaG
that's got it! thanks!
Old 24th January 2024, 20:14   #1487  |  Link
johnmeyer
If it is darker than the original, try one of the two settings that doesn't use autolevels. I usually see no change in gamma, but I almost always use the number 4 setting which doesn't touch either levels or color.
Old 24th January 2024, 20:20   #1488  |  Link
BabaG
thanks, johnmeyer! great tip. much appreciated. changing 255 to 1023 seems to have worked here.
i think the last thing i need to try in order to really test this on my materials is to get the change from setmtmode to setfiltermtmode working. for example, with this line:
setmtmode(5, threads)
what should the replacement setfiltermtmode line be? if i just say:
SetFilterMTMode(5, threads)
it throws an error. wrong syntax, i suppose. not sure what to put into it.
edit:
this seems to allow the clip to load:
SetFilterMTMode("source1", 2)
i only replaced the first instance of setmtmode with this and the clip does load. don't understand if i should replace the remaining instances of setmtmode with it. they are currently commented.
thanks again, all!
babag
Old 24th January 2024, 23:14   #1489  |  Link
johnmeyer
Here is a link to my current script:
John Meyer Film Restoration Script 2024
It is designed for the more modern versions of AVISynth which no longer use the SetMTMode version of multithreading.
This version used GamMac for color, and provides the option of using SpotLess instead of RemoveDirt for getting rid of film dirt.
(Note: I added SpotLess only a few years ago but forgot to update my revision log at the beginning of the script.)
Old 24th January 2024, 23:35   #1490  |  Link
BabaG
wow! thanks johnmeyer. just downloaded it. would like to get the version i've been currently working with fully functional before i jump into something new. guess i should study it while waiting for info on these last few questions about the version i've had up to now.
thanks again!
babag
Old 25th January 2024, 16:47   #1491  |  Link
johnmeyer
The main reason for making the script available was to answer your question about getting multithreading to work in more modern versions of AVISynth. These versions use the more modern version of multithreading so you should be able adapt whatever you almost have working. The "Prefetch(threads)" line is the main thing. It needs to be the very last statement in the main body of the script (the function calls, of course, can be put anywhere, so "last statement" doesn't apply to them).
I assume you have read this:
AVISynth+ Multithreading
Old 26th January 2024, 07:26   #1492  |  Link
BabaG
thanks again, johnmeyer.
sadly, it's all getting to be a bit more than i can handle. the differences between setmtmode and setfiltermtmode and avisynth 32 and 64. i'm terrible at anything like coding but keeping this all in line is just too much for me. i just can't figure it out. i don't know how you do it.
thanks,
babag
Old 26th January 2024, 17:12   #1493  |  Link
johnmeyer
You seem to have gotten pretty far, so I think you can do it. A few suggestions.
1. If you still have a computer using Windows 7, use that.
2. Don't use 64-bit. I still have yet to see any compelling reason why that would be better. You will find that the 32-bit version will have fewer compatibility problems.
3. Turn off all multi-threading options until you have it working. This means commenting out the "Prefetch" line (for the current versions of AVISynth).
Old 26th January 2024, 19:49   #1494  |  Link
manolito
manolito's Avatar
Please forgive me if it looks like I want to highjack this discussion. I am asking about this film restauration script because a few days ago a good friend asked me if I had any ideas if this video from 1979 could be improved.
It is an amateur live recording from a band called "Jump Street" shot at the Catalyst in Santa Cruz, the quality is awful, but it does have a sentimental value for my friend (and for me).
Here is the link:
https://www.youtube.com/watch?v=NBxB...Y2F0YWx5c3Q%3D
I am not too optimistic if this is even worth the effort, but if you think that this clip could be improved using this script, please let me know...
Cheers
manolito
Old 26th January 2024, 21:05   #1495  |  Link
BabaG
unfortunately, no windows 7 here.
this is one of the areas with which i have difficulty: distinguishing between things intended for either version. can they be run alongside each other? how would one make clear which is being called? pretty much everything in my system is 64 bit so i went with 64 bit avisynth+.
i thought i'd pretty much gotten to that point. that's why i was trying to get the multithreading up now. setting the max memory made a huge difference, though. one thing i noted between your two scripts was that, i think it was for autolevels, the earlier version that used setmtmode had a comment about turning autolevels off and then back on. the newer version didn't seem to have any use of the replacement, setfiltermtmode, at all so i couldn't figure out how to update setmtmode in the earlier script.
@manolito, i think this script, and variants, are intended for captured film, in the case of the videofred version, film captured at good quality and, in the johnmeyer version, maybe more tolerant of source quality. obviously, i'm not someone to pay too much attention to but, in this case, i think i have it right.
thanks again,
babag
Old 27th January 2024, 16:41   #1496  |  Link
If you load avs file with 64 bit MPC-HC/VirtualDub2/AvsPMod/etc, then it uses Avisynth 64 bit, which in turn uses (AND REQUIRES) 64 plugins in 64 bit plugins directory,
similarly, 32 bit players require 32 bit everything.
EDIT: Also, 64 bit MegUI (or other encoder), uses 64 bit Avisynth etc, and 32 bit ecoder uses 32 bit avisynth etc.
Above bittage requirements apply to all Windows executables and dll's, not just avisynth, n-bit executables require n-bit dll's.
Old 28th January 2024, 00:51   #1497  |  Link
BabaG
thanks stainlesss. that's helpful.
Old 21st October 2024, 16:57   #1498  |  Link
rod93
hi
try to restore a 8mm with "John Meyer Film Restoration Script 2024" but it's a mp4 file so i put "source1= DirectShowSource(film, fps=25, convertfps=true)" don't know if it is ok, then ive got a script error " there is no function named "prefetch" thk for your help
rod93 is offline   Reply With Quote
Old 21st October 2024, 17:04   #1499  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Full script, please. And, for starters:
And you will want to use LSmashVideoSource(), even better LWLibavVideoSource() instead of DirectShowSource().
and: converting any film source to 25fps within the sourcefilter, even later based on MVTools2 might do more harm than good.
Old 21st October 2024, 17:25   #1500  |  Link
rod93
thk i turn off "prefetch" line the video loading into virtualdub but nothing happen...
try to run the script with virtualdul in x86 but got an another error "mu_binarize:masktools:unsupported color space" thk
Thread Tools
