#521 | Link | |
Midnight Artist
http://forum.doom9.org/showthread.php?t=161493 I tried to cram a lot of stuff inside, and may have gone a bit overboard. Comments & suggestions welcome :-) |
#522 | Link | |
Midnight Artist
Maybe this is a little bit late, but probably some of the notions explained in my new topic (see previous post) could be adapted to your case... |
#524 | Link |
wide screen / aspect ratio question
Hi.
I have been making nice progress with the script, thanks very much for this magical software. My difficulty has come from the fact that some of my captures were done in 16:9 (wide screen) and some in "regular" 4:3 aspect ratio. After the script has run , I cannot get the wide screen captures to play in a wide format, so everyone looks thinner than they should be ![]() The settings I am wondering about are on this line: "W=720 H=576 #final size from the returned clip" I was thinking maybe I need to change these setting for wide screen, but I am not sure. Also what would one change these settings to if one were to capture in HD? 1920 X 1080 ? (planning for the future.. ![]() Any comments are welcome, and I appologise if this is a video newbie question. regards Clive |
#525 | Link | |
Location: Terneuzen, Zeeland, the Netherlands, Europe, Earth, Milky Way,Universe
Fred.
About 8mm film: http://www.super-8.be Film Transfer Tutorial and example clips: https://www.youtube.com/watch?v=W4QBsWXKuV8 More Example clips: http://www.vimeo.com/user678523/videos/sort:newest |
#526 | Link | |
http://www.gyroshot.com/simpleslug.htm |
#527 | Link | |
For web use, it's usual to render square pixels - e.g. 768x576 for 4x3, 1024x576 for 16x9. The "NTSC" frame sizes are more usual on the web - e.g. 640x480 for 4x3 and 640x360 or something like 856x480 for 16x9. It's quite common to upscale to 1280x720 for YouTube to make it deliver higher quality, even if the original isn't HD. Cheers, David. |
#531 | Link | |
You will find that he temporarily adds a border before doing the Autolevels in order to "soften" (his words) the effect. I seem to remember that I played around with that quite a bit and ended up with something similar to what you posted, namely that a frame would suddenly go very dark, and then, a few frames later, the levels would "pop" back up to normal again. I was initially using the script on 8mm film which is almost exactly square. Because of this, you end up with pillar borders when you capture and edit using a 4:3 aspect ratio. These pillars resulted in very bad things happening with the Depan motion stabilization, so I modified his script to permit you to remove them before submitting the video to the script, and then adding them back in as the last step. That solved the Depan problems, and seemed to make everything else in the script "happier." If you look at my version of the script, posted in one of my first responses in this thread, and you'll see how I did that. Last edited by johnmeyer; 14th July 2011 at 21:11. Reason: Added a clarifying phrase immediately after posting |
#532 | Link | |
#533 | Link | |
I have my new scripts ready, the are all using the modified autolevels filter. I have also improved the stabilizing and the sharpening. And I have made a new helpfile. Upload is coming soon ![]() Fred.
#534 | Link | |
#535 | Link | |
Fred.
#536 | Link | |
Maybe it's a problem with the DLL.. is that function part of mvtools 2? Last edited by mathmax; 16th July 2011 at 18:50. |
#537 | Link | |
MVAnalyseMulti() is part of -guess what- MVToolsMulti. MVToolsMulti is a modified version of the original MVTools. The dll is named MVTools.dll. Perhaps it would be better to rename it to MVToolsMulti.dll.But there are several MVToolsMulti dll files, optimised for different computer systems. I just took the one that was working on all my computers. XP and Vista, I have not checked the script on Win7 yet. Anyhow, you will find all these versions in the 'Source' directory of the package. Perhaps another dll will solve your problem. Be careful because they all have the same name: MVTools.dll. Fred.
#538 | Link | |
The dll are all from 2008.. aren't there new version? Which one do you think I should use? |
#539 | Link | |
![]() MVToolsMulti() is from Josey_Wells and you will find it in the MVTools thread around page 50. As far as I know there are no newer versions. Fred.
#540 | Link |
widescreen sd capture confusion
Thanks Pieter8mm and 2Bdecided for your feedback regarding my widescreen capture. Its a bit strange that wide screen SD is the same resolution as 4:3 in SD. The pixels are actually rectangular, giving it the extra width.
I have decided to recapture in normal 4:3 aspect ratio as I now realise that by capturing in widescreen I have effectively reduced the number of vertical pixel resolution by 30%. Thanks again regards Clive |
| Thread Tools | |
| Display Modes | |
