23rd May 2015, 00:58 | #2221 | Link | |
Troubleshooter
New version, D3D exclusive lockup, and XYSubFilter bug
On another note XYSubFilter seems to be a problem in the new version. When subtitles are on the screen the rest of the screen (aside from the subtitles) turns black. When characters stop talking (thus no subtitles) the video appear back on the screen, but the minute the subtitles appear again the screen turns black again until the subtitles disappear off the screen.
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. |
23rd May 2015, 02:45 | #2223 | Link |
Suptitle, MediaPlayer.NET
Did you guys use the installer? I suspect it may be due to a bad XySubFilter version. I'll investigate later when I get done time. In the meantime, try downloading another version of the filter and install that instead.
@animeviewer did you manage to get the dump file when it locked up? It should crash on purpose when it detects a lockup after about 5 seconds. You'll then get a dump file. Check my post a few pages back. |
23rd May 2015, 03:41 | #2230 | Link |
2.26.2 -> works great
2.26.3 -> turn on any render script even blank one=no video only audio and xysubfilter blinking picture as explained by Anime Viewer By blank one I mean you can select image processor with no shaders and the moment you press apply blank picture. Great player BTW :-) Last edited by japa; 23rd May 2015 at 03:46. |
23rd May 2015, 04:24 | #2232 | Link |
Troubleshooter
It doesn't appear to create any dump file (I'm not sure that it detects a crash). Since it locks the screen (keyboard still works for capslock, numlock , ctrl+alt+delete, alt-tabing (even though it will not switch to anything else. Unless you choose ctrl+alt+del and choose log-off. At that time you can alt-tab between windows, but can't interact or navigate on any of them. The MPDN app shows in the taskbar, but right-clicking on it and choosing close all windows will not do anything (it doesn't react). The only way to shut out of it is to tell it to switch users (or restart). As far as I can tell it didn't create any file in the user config folder, nor the install location of MPDN.
23rd May 2015, 11:07 | #2234 | Link |
So my TV accepts 12 bit input at <24hz but Nvidia's drivers don't remember the previous setting at that refresh rate.
Any chance of having MPDN be able to set the bit depth output of the graphics card via the display changer? |
23rd May 2015, 11:10 | #2235 | Link | |
23rd May 2015, 13:08 | #2236 | Link |
Troubleshooter
No, the mouse cursor does not show during the MPDN freeze. I've waited longer than 30 seconds (a few minutes with nothing changing).
23rd May 2015, 15:21 | #2238 | Link |
OK try this when you have the chance. When it locks up, double click the full screen windows a few time. Then wait for 30 seconds. If it still doesn't auto-terminate, it probably means something terminal has occurred...
23rd May 2015, 18:49 | #2239 | Link | |
Troubleshooter
It froze again, and I double clicked (when there is a nonexistent mouse cursor during the initial freeze), and nothing ever happened). After I did switch user to were it is still running, and I double clicked on it on the taskbar (again with no change, and it not switching to it) I again waited 30+ seconds but nothing ever happened. Task Manager in that state reports it as not responding, but it never times out (and just like how I can't interact with MPDN I can't interact act with any other programs except to switching to them with alt-tab, but I can't do anything other than display their windows - for example I can't scroll or type anything on this forum), and can't close out of them during that non-responsive MPDN state. Edit: Odd. It doesn't appear to occur with one file I have tested (with the following properties). Code:
Unique ID : 0 Complete name : (file name omitted) Format : Matroska File size : 157209197 Duration : 1452199 Overall bit rate : 866048 Encoded date : 2/22/2010 9:41:29 PM Writing application : no_variable_data Writing library : no_variable_data Video ID : 1 Format : AVC Format profile : Main@L3.1 Format settings : CABAC / 6 Ref Frames Codec ID : V_MPEG4/ISO/AVC Duration : 1452202 Bit rate : 0 Width : 848 Height : 480 Display aspect ratio : 1.006 Frame rate mode : CFR Frame rate : 23.976 Chroma subsampling : 4:2:0 Bit depth : 8 Scan type : Progressive Bits/(Pixel*Frame) : 0 Stream size : Writing library : x264 - core 120 r2120 0c7dab9 Encoding settings : cabac=1 / ref=6 / deblock=1:1:1 / analyse=0x1:0x111 / me=umh / subme=8 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=768 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=1536 / vbv_bufsize=3840 / nal_hrd=none / ip_ratio=1.40 / aq=1:0.60 Language : Audio ID : 2 Format : AAC Codec ID : A_AAC Duration : 1452199 Bit rate mode : Bit rate : 0 Channel(s) : 2 Sampling rate : 44100 Bit depth : 0 Compression mode : Lossy Stream size : 0 Language : Subtitle ID : 3 Format : ASS Muxing Mode : Codec ID : S_TEXT/ASS Language : Code:
Unique ID : 199100304361845660068191694678274133701 Complete name : (file name ommited) Format : Matroska File size : 474810722 Duration : 1440000 Overall bit rate : 2637837 Encoded date : 5/17/2015 11:53:54 AM Writing application : mkvmerge v7.7.0 ('Six Voices') 32bit built on Feb 28 2015 23:23:00 Writing library : libebml v1.3.1 + libmatroska v1.4.2 Video ID : 18041449390369659311 Format : AVC Format profile : Main@L4.1 Format settings : CABAC / 6 Ref Frames Codec ID : V_MPEG4/ISO/AVC Duration : 1439982 Bit rate : 0 Width : 1280 Height : 720 Display aspect ratio : 1 Frame rate mode : CFR Frame rate : 23.976 Chroma subsampling : 4:2:0 Bit depth : 8 Scan type : Progressive Bits/(Pixel*Frame) : 0 Stream size : Writing library : x264 - core 142 r2479 dd79a61 Encoding settings : cabac=1 / ref=6 / deblock=1:1:1 / analyse=0x1:0x111 / me=hex / subme=7 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2432 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=62500 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:0.60 Language : ja Audio ID : 15032933852594981766 Format : AAC Codec ID : A_AAC Duration : 1440000 Bit rate mode : Bit rate : 0 Channel(s) : 2 Sampling rate : 48000 Bit depth : 0 Compression mode : Lossy Stream size : 0 Language : ja Subtitle On the frozen video screen if I have CTRL+J active it shows the Render queue at 0/12 at the point it switched and froze. Running with "Use new windowed mode rendering path when possible" unchecked the problem doesn't appear to occur in the second video - that normally freezes. **edit: scratch that...it still occurred with new mode unchecked, but for some reason that one time it didn't. Edit: Anyone else noticing Fluid Motion fluctuating on and off almost every second when watching 23.976Hz files on 59/60Hz screens? (Its actually causing Judder (and tons of dropped and delayed frames - probably as a result of the constant switching on and off) on my screen as opposed to the same video running smoothly with it turned off).
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. Last edited by Anime Viewer; 24th May 2015 at 04:22. Reason: added code for non-crashing and crashing videos |
direct3d, mpdn, nnedi3, opencl, reclock |
