Thread Tools Display Modes
Old 12th February 2014, 20:31   #19181  |  Link
jdobbs
Originally Posted by slvrsrfr View Post
I'm actually trying all 4 DVD discs from Season 1 (13 episodes) to one 25 GB BD...that's what your first test was right?
It seems to only be when BDRB has to reencode the episodes that they get out of sync. When the total content is less than 25 GB and it keeps the original content I don't have any issues (This happened with The Simpsons Season 4).
In any event, I can wipe my machine over the weekend and try fresh...
That's how I did it the first time, so this time I only imported and reencoded Disc 1... I was trying to save time. It works the same either way. I set FORCE_ENCODE=1 to make sure it did the encode.
I'm certain it isn't BD Rebuilder causing the issue. There's really nothing else I can do.
jdobbs.softworks@gmail.com
Old 12th February 2014, 20:33   #19182  |  Link
slvrsrfr
That's how I did it the first time... I was trying to save time. It works the same either way. I set FORCE_ENCODE=1 to make sure it did the encode.
OK, thanks again...I'll get working on a rebuild....I really appreciate all of your help!
slvrsrfr is offline   Reply With Quote
Old 12th February 2014, 20:39   #19183  |  Link
jdobbs
You're absolutely POSITIVE you are only using the versions of AVISYNTH, HAALI, and FFSHOW that I have linked on the first post of this thread, right?
Old 12th February 2014, 20:47   #19184  |  Link
slvrsrfr
Yes, in fact when I uninstalled/reinstalled the other day I downloaded HAALI and FFSHOW from the first page here...I think I downloaded AVISYNTH from the http://www.avisynth.org website, though. I then went through steps 1-8.
As far as running BDRB in admin mode the first time I believe I did that as well, but to be certain that the codecs were set right in the registry can you let me know what it's supposed to set and where..that's one other thing I could look at, unless there are other settings in FFDSHOW, etc., to check.
Old 12th February 2014, 20:49   #19185  |  Link
jdobbs
Make sure you are running AVISYNTH v2.58. v2.6.0 is still in alpha, and if you have it installed it is probably you problem. I have no idea how it's DirectshowSource() interprets pulldown signals.
Old 12th February 2014, 20:58   #19186  |  Link
HWK
HWK's Avatar
On main screen of BD-Rebuilder, click help and there is an option check system setting and right next to it says inspect in bracket. Post info over here or just upload scrrenshot of add and remove programs section.
If you fail to plan; you plan to fail, would you not agree? Think about it.
HWK is offline   Reply With Quote
Old 12th February 2014, 21:28   #19187  |  Link
soneca
Jdobbs, this conversion a crash occurs at the end of the first stream (04:41) where only the image is locked for a few seconds but then continues to play.
I thought it was some corrupt data extraction(AnyDVD) but the original is playing without crashes.
Maybe a problem with muxing...
[02/12/14] BD Rebuilder v0.46.11 (beta)
[11:08:03] Source:  THE_COUNSELOR_00800
  - Input BD size: 33,50 GB
  - Approximate total content: [01:57:14.026]
  - Windows Version: 6.1 [7601]
  - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled
  - Mode: MKV Container, 1280x720, Intact Audio
  - Automatic cropping of borders enabled
  - Output folder: E:\VIDEOS\
  - Decoding/Frame serving: DGDecNV [3-way]
[11:08:06] PHASE ONE, Encoding
 - [11:08:06] Processing: VID_00500 (1 of 3)
 - [11:08:06] Extracting A/V streams [VID_00500]
 - [11:14:16] Reencoding video [VID_00500]
   - Rate/Length: 23,976fps, 6.753 frames
 - [11:14:16] Reencoding: VID_00500, Pass 1 of 1
 - [11:16:24] Video Encode complete
 - [11:16:24] Processing audio tracks
   - Track 4352 (eng): Reencoding audio to AC3...
 - [11:19:11] Processing: VID_00501 (2 of 3)
 - [11:19:11] Extracting A/V streams [VID_00501]
 - [11:19:18] Reencoding video [VID_00501]
   - Rate/Length: 23,976fps, 788 frames
 - [11:19:18] Reencoding: VID_00501, Pass 1 of 1
 - [11:19:29] Video Encode complete
 - [11:19:29] Processing: VID_00502 (3 of 3)
 - [11:19:29] Extracting A/V streams [VID_00502]
 - [11:26:47] Reencoding video [VID_00502]
   - Rate/Length: 23,976fps, 161.107 frames
 - [11:26:47] Reencoding: VID_00502, Pass 1 of 1
 - [12:07:16] Video Encode complete
[12:07:16]PHASE ONE complete
[12:07:16]PHASE TWO - Rebuild Started
 - [12:07:16] Building ALTERNATE OUTPUT Structure
[12:10:33] - Encode and Rebuild complete
[12:10:33] JOB: THE_COUNSELOR finished.
[Status]
LABEL=THE_COUNSELOR
VERSION=v0.46.11 (beta)
SOURCE_SIZE=35971627008
SOURCE_VIDEO_SIZE=35971627008
TARGET_SIZE=4697620480
REDUCTION=.130592382684143
RESIZE_1080=-1
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=por;
BACKUP_MODE=1
MOVIEONLY_TYPE=34
USE_LAVF=0
INSTANCES=3
DGDECNV=-1
SSIF_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=3
REBUILD_COMPLETE=1
[00500]
AUDIO=100000000
PGS=000000000100000000
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=192567909
SPLITS=1
NSIZE=0
FLINK=-1
MLINK=0
[00501]
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=16110578
SPLITS=1
AUDIO=100000000
NSIZE=0
FLINK=-1
MLINK=0
[00502]
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=4488941993
SPLITS=3
AUDIO=100000000
NSIZE=0
FLINK=0
MLINK=0
soneca is offline   Reply With Quote
Old 12th February 2014, 21:34   #19188  |  Link
jdobbs
The fact that it plays means nothing, if there is a crash during processing it is highly probable that the source is corrupt. Players are designed to ignore errors and move on. Encoders can't do that.
With that said... I don't see a crash in your log?
Old 13th February 2014, 00:17   #19189  |  Link
soneca
Jdobbs, another conversion done on another pc.
The crash occurred at the end of first stream, or between streams.
[19:10:53] Source:  CRIMSON_TIDE_00000
  - Input BD size: 30,47 GB
  - Approximate total content: [01:55:46.439]
  - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=448
[19:10:53] PHASE ONE, Encoding
 - [19:10:53] Processing: VID_00000 (1 of 3)
 - [19:10:53] Extracting A/V streams [VID_00000]
 - [19:13:58] Reencoding video [VID_00000]
   - Rate/Length: 23,976fps, 72.876 frames
 - [19:13:58] Reencoding: VID_00000, Pass 1 of 1
 - [20:03:13] Video Encode complete
 - [20:03:13] Processing audio tracks
 - [20:03:40] Processing: VID_00001 (2 of 3)
 - [20:03:40] Extracting A/V streams [VID_00001]
 - [20:04:48] Reencoding video [VID_00001]
   - Rate/Length: 23,976fps, 53.688 frames
 - [20:04:48] Reencoding: VID_00001, Pass 1 of 1
 - [20:33:41] Video Encode complete
 - [20:33:41] Processing: VID_00002 (3 of 3)
 - [20:33:41] Extracting A/V streams [VID_00002]
 - [20:34:26] Reencoding video [VID_00002]
   - Rate/Length: 23,976fps, 39.984 frames
 - [20:34:26] Reencoding: VID_00002, Pass 1 of 1
 - [20:54:38] Video Encode complete
[20:54:38]PHASE ONE complete
[20:54:38]PHASE TWO - Rebuild Started
 - [20:54:38] Building ALTERNATE OUTPUT Structure
[20:57:27] - Encode and Rebuild complete
 - WORKFILES folder removed.
[20:57:27] JOB: CRIMSON_TIDE finished.
Old 13th February 2014, 00:39   #19190  |  Link
jdobbs
What do you mean by "crash" -- it isn't making much sense to me. If you're talking about the playback glitches you're showing -- that's not a "crash". It looks like there may be glitches in the source to me. The chance that it is a muxing issues it unlikely -- as it would be unusual for a mux to cause pixelation like that, especially with a muxer as established as MERGEMKV. The only other possibility might be a X264 problem. Again, though, that is very unlikely.
Can you play back the AVS files and see if you get that noise at the same point?
Have you tried playing back the MKV with another player to rule out this one? As you may already know, I'm always highly suspicious of software players.
Any chance your computer is causing the issue? Are you doing a lot of other activity on the computer at the time of the encode?
Old 13th February 2014, 01:28   #19191  |  Link
soneca
Crash really would not be the correct term... That's right, playback glitches.
I would have to redo the conversion, the temporary folder is marked to be deleted.
I also use PotPlayer, the screens below at the time of failure.
The second conversion(Crimson Tide) was done in another pc, completely free activity at the time of conversion.
Old 13th February 2014, 11:17   #19192  |  Link
Sharc
Quick menu issue
Source: BD with 4 Episodes + Extras
Case 1: (working correctly)
Import/Quick Play Settings: Thresholds = 10
=> The 4 episodes are shown in the Menu Editor
=> The Extras are skipped, as expected
Backup and Quick-Menu are all ok.
Case 2: (Problem)
Import/Quick Play Settings: Thresholds = 6
=> The 4 Episodes + Extras are listed in the Quick-Play Menu Title Editor, as expected. The Preview of the Episodes and Extras is also correct.
Now I deselect the Extras in the Editor and Save
=> Importing starts, but only the deselected Extras are imported, and the selected Episodes are skipped.
So something gets messed up.
Case 3: (working correctly)
Same as case 2, but instead of deselecting all the Extras I select the Episodes and keep at least one of the Extras
=> Import and Menu creation are correct
So the problem seems to exist only when I unselect all the Extras.
The cases are reproducible.
Edit:
I seem to have been too optimistic with Case 3.
In General:
- The Quick-Menu proposal when importing a BD, let's call it 'Version A'
- My Quick-Menu edit (text edit and titles selection) is 'Version B'
- What gets then imported into the IMPORT Folder is 'Version C'
- What I finally get -- as a surprise -- on the burned disc is 'Version D'
So the only method which seems to work reliably is Case 1 above, i.e. selecting the import threshold high enough such that only the episodes are selected, and forget any Extras.
The issue is probably related to the weird menu & playlist structure of this disc, I believe.
Edit2:
Hmm.... could the screwing up be caused by the truncation (max. number of characters) of the Quick-Menu text strings ...?
Old 13th February 2014, 16:15   #19193  |  Link
jdobbs
Any chance that the real issue is that the names saved during the first import are attempting to be used in the second -- meaning the times/titles etc. aren't applied to the correct playitem? If you are changing the import parameters, try deleting the titles.inf file between changes. If that's it I'll look at a way to ignore it when the parameters change.
Old 13th February 2014, 17:04   #19194  |  Link
Sharc
I thought I purged the title.inf between attempts, but I'll try again to be sure after the current encode finalizes.
I noticed that the first title.inf (original and edited) is written to the source folder. It gets then copied to the IMPORT folder, where it can be edited again while the title.inf in the source folder remains intact. I don't think this matters though.
Old 13th February 2014, 19:56   #19195  |  Link
Sharc
@jdobbs
I purged all the title.inf, but it didn't help.
title.inf with the deselcted Extras (in source folder):
[Titles]
Title=BD_BREAK_BAD_FINAL_SEASON_D2
Threshold=16200000
00001=01. BD BREAK_BAD_FINAL_SEASON_D2 [00:46:13
00002=02. BD BREAK_BAD_FINAL_SEASON_D2 [00:47:13
00003=03. BD BREAK_BAD_FINAL_SEASON_D2 [00:53:26
00004=04. BD BREAK_BAD_FINAL_SEASON_D2 [00:55:14
00005=05. BD BREAK_BAD_FINAL_SEASON_D2 [00:09:36
00006=06. BD BREAK_BAD_FINAL_SEASON_D2 [00:14:24
00007=07. BD BREAK_BAD_FINAL_SEASON_D2 [00:10:01
00008=08. BD BREAK_BAD_FINAL_SEASON_D2 [00:07:27
00009=09. BD BREAK_BAD_FINAL_SEASON_D2 [00:09:47
00010=10. BD BREAK_BAD_FINAL_SEASON_D2 [00:08:01
00011=11. BD BREAK_BAD_FINAL_SEASON_D2 [00:07:25
[Position]
00001=1
00002=2
00003=3
00004=4
00005=0
00006=0
00007=0
00008=0
00009=0
00010=0
00011=0
[Selected]
00001=-1
00002=-1
00003=-1
00004=-1
00005=0
00006=0
00007=0
00008=0
00009=0
00010=0
00011=0
title.inf written to the IMPORTS folder (note the truncated strings)
[Titles]
Threshold=16200000
The DB-RB log:
[19:35:15] Importing BDs: BD_BREAK_BAD_FINAL_SEASON_D2
 - Analyzing source playlists...
 - Title Editing Dialog...
 - Importing BD: BD BREAK_BAD_FINAL_SEASON_D2 [ 1 of 1]
   - Importing Playlist 00465 [00:09:36.158]
   - Importing Playlist 00466 [00:14:24.071]
   - Importing Playlist 00469 [00:10:01.100]
   - Importing Playlist 00476 [00:07:27.847]
   - Importing Playlist 00477 [00:09:47.286]
     - Skipped title per user setting...
   - Importing Playlist 00478 [00:08:01.180]
   - Importing Playlist 00479 [00:07:25.211]
   - Importing Playlist 00800 [00:46:13.812]
   - Importing Playlist 00801 [00:47:13.872]
   - Importing Playlist 00802 [00:53:26.244]
   - Importing Playlist 00803 [00:55:14.352]
 - Creating Quick-Play Menu...
   - Building menu structure...
[19:39:15] Import completed successfully
Playlists of the short Extras are kept; the long episodes are skipped.
Old 13th February 2014, 20:47   #19196  |  Link
jdobbs
That's really weird.
The truncated strings will have no effect -- they're just shortened because of the maximum width of the menu text at the given font size.
Old 14th February 2014, 14:55   #19197  |  Link
mparade
[02.14.14] BD Rebuilder v0.46.07 (beta)
[00:50:46] Source: PRINCESSANDTHEFROG
- Input BD size: 39,71 GB
- Approximate total content: [03:36:00.278]
- Target BD size: 46,26 GB
- MOVIE and MENUS mode enabled
- Quality: Highest (Very Slow), CRF
- Decoding/Frame serving: X264/LAVF
- Resuming from previously started job.
[00:51:24] PHASE ONE, Encoding
- [00:51:24] Processing: VID_00066 (55 of 102)
- [00:51:24] Extracting A/V streams [VID_00066]
- Error in attempt to MKVMERGE.
[00:52:05] - Failed to retrieve audio, aborted
Any idea what could be the reason of that?
Thanks in advance!
mparade is offline   Reply With Quote
Old 14th February 2014, 15:12   #19198  |  Link
jdobbs
Thanks in advance!
Could you turn "Verbose Status Reporting" and post the log again? I'd like to see what kind of source it is encountering so I can find out why it needs to use MKVMERGE. I'm guessing it is either a secondary stream or a field-based VC-1 source.
Old 14th February 2014, 18:34   #19199  |  Link
mparade
[17:56:37] Source:  PRINCESSANDTHEFROG
  - Input BD size: 32,46 GB
[17:56:37] PHASE ONE, Encoding
 - [17:56:37] Blanking: VID_00002 (1 of 102)
 - [17:56:37] Blanking: VID_00004 (2 of 102)
 - [17:56:37] Blanking: VID_00005 (3 of 102)
 - [17:56:37] Blanking: VID_00009 (4 of 102)
 - [17:56:37] Blanking: VID_00010 (5 of 102)
 - [17:56:37] Blanking: VID_00011 (6 of 102)
 - [17:56:37] Blanking: VID_00012 (7 of 102)
 - [17:56:37] Blanking: VID_00013 (8 of 102)
 - [17:56:37] Blanking: VID_00014 (9 of 102)
 - [17:56:37] Blanking: VID_00015 (10 of 102)
 - [17:56:37] Blanking: VID_00016 (11 of 102)
 - [17:56:37] Blanking: VID_00017 (12 of 102)
 - [17:56:37] Blanking: VID_00018 (13 of 102)
 - [17:56:37] Blanking: VID_00019 (14 of 102)
 - [17:56:37] Blanking: VID_00020 (15 of 102)
 - [17:56:37] Blanking: VID_00021 (16 of 102)
 - [17:56:37] Blanking: VID_00022 (17 of 102)
 - [17:56:37] Blanking: VID_00023 (18 of 102)
 - [17:56:37] Blanking: VID_00024 (19 of 102)
 - [17:56:37] Blanking: VID_00025 (20 of 102)
 - [17:56:37] Blanking: VID_00026 (21 of 102)
 - [17:56:37] Blanking: VID_00027 (22 of 102)
 - [17:56:37] Blanking: VID_00028 (23 of 102)
 - [17:56:37] Blanking: VID_00029 (24 of 102)
 - [17:56:37] Blanking: VID_00030 (25 of 102)
 - [17:56:37] Blanking: VID_00031 (26 of 102)
 - [17:56:37] Blanking: VID_00033 (27 of 102)
 - [17:56:37] Blanking: VID_00034 (28 of 102)
 - [17:56:37] Blanking: VID_00035 (29 of 102)
 - [17:56:37] Blanking: VID_00036 (30 of 102)
 - [17:56:37] Blanking: VID_00037 (31 of 102)
 - [17:56:37] Blanking: VID_00038 (32 of 102)
 - [17:56:37] Blanking: VID_00040 (33 of 102)
 - [17:56:37] Blanking: VID_00041 (34 of 102)
 - [17:56:37] Blanking: VID_00042 (35 of 102)
 - [17:56:37] Blanking: VID_00043 (36 of 102)
 - [17:56:37] Blanking: VID_00044 (37 of 102)
 - [17:56:37] Blanking: VID_00045 (38 of 102)
 - [17:56:37] Processing: VID_00050 (39 of 102)
 - [17:56:37] Extracting A/V streams [VID_00050]
 - [17:56:55] Reencoding video [VID_00050]
 - [17:56:55] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 7*088 frames
 - [17:57:38] Encoding using constant rate factor.
 - [18:02:44] Video Encode complete
 - [18:02:44] Processing audio tracks
   - Track 4354 (hun): Keeping original audio
   - Track 4356 (eng): Keeping original audio
 - [18:02:44] Multiplexing M2TS
 - [18:02:53] Processing: VID_00051 (40 of 102)
 - [18:02:53] Extracting A/V streams [VID_00051]
 - [18:02:59] Reencoding video [VID_00051]
 - [18:02:59] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 501 frames
 - [18:03:01] Encoding using constant rate factor.
 - [18:03:20] Video Encode complete
 - [18:03:20] Processing audio tracks
 - [18:03:20] Multiplexing M2TS
 - [18:03:24] Processing: VID_00052 (41 of 102)
 - [18:03:24] Extracting A/V streams [VID_00052]
 - [18:03:32] Reencoding video [VID_00052]
 - [18:03:32] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 1*688 frames
 - [18:03:41] Encoding using constant rate factor.
 - [18:04:51] Video Encode complete
 - [18:04:51] Processing audio tracks
 - [18:04:51] Multiplexing M2TS
 - [18:04:56] Processing: VID_00053 (42 of 102)
 - [18:04:56] Extracting A/V streams [VID_00053]
 - [18:05:04] Reencoding video [VID_00053]
 - [18:05:04] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 1*560 frames
 - [18:05:11] Encoding using constant rate factor.
 - [18:06:04] Video Encode complete
 - [18:06:04] Processing audio tracks
 - [18:06:04] Multiplexing M2TS
 - [18:06:08] Processing: VID_00054 (43 of 102)
 - [18:06:08] Extracting A/V streams [VID_00054]
 - [18:06:15] Reencoding video [VID_00054]
 - [18:06:15] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 1*107 frames
 - [18:06:23] Encoding using constant rate factor.
 - [18:07:08] Video Encode complete
 - [18:07:08] Processing audio tracks
 - [18:07:08] Multiplexing M2TS
 - [18:07:12] Processing: VID_00055 (44 of 102)
 - [18:07:12] Extracting A/V streams [VID_00055]
 - [18:07:19] Reencoding video [VID_00055]
 - [18:07:19] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 802 frames
 - [18:07:24] Encoding using constant rate factor.
 - [18:07:54] Video Encode complete
 - [18:07:54] Processing audio tracks
 - [18:07:54] Multiplexing M2TS
 - [18:07:59] Processing: VID_00056 (45 of 102)
 - [18:07:59] Extracting A/V streams [VID_00056]
 - [18:08:09] Reencoding video [VID_00056]
 - [18:08:09] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 2*868 frames
 - [18:08:27] Encoding using constant rate factor.
 - [18:10:17] Video Encode complete
 - [18:10:17] Processing audio tracks
 - [18:10:17] Multiplexing M2TS
 - [18:10:23] Processing: VID_00057 (46 of 102)
 - [18:10:23] Extracting A/V streams [VID_00057]
 - [18:10:32] Reencoding video [VID_00057]
 - [18:10:32] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 2*131 frames
 - [18:10:44] Encoding using constant rate factor.
 - [18:11:58] Video Encode complete
 - [18:11:58] Processing audio tracks
 - [18:11:58] Multiplexing M2TS
 - [18:12:03] Processing: VID_00058 (47 of 102)
 - [18:12:03] Extracting A/V streams [VID_00058]
 - [18:12:12] Reencoding video [VID_00058]
 - [18:12:12] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 2*040 frames
 - [18:12:21] Encoding using constant rate factor.
 - [18:13:33] Video Encode complete
 - [18:13:34] Processing audio tracks
 - [18:13:34] Multiplexing M2TS
 - [18:13:38] Processing: VID_00059 (48 of 102)
 - [18:13:38] Extracting A/V streams [VID_00059]
 - [18:13:44] Reencoding video [VID_00059]
 - [18:13:44] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 444 frames
 - [18:13:46] Encoding using constant rate factor.
 - [18:14:04] Video Encode complete
 - [18:14:04] Processing audio tracks
 - [18:14:04] Multiplexing M2TS
 - [18:14:08] Processing: VID_00060 (49 of 102)
 - [18:14:08] Extracting A/V streams [VID_00060]
 - [18:14:23] Reencoding video [VID_00060]
 - [18:14:23] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 5*684 frames
 - [18:14:59] Encoding using constant rate factor.
 - [18:19:01] Video Encode complete
 - [18:19:01] Processing audio tracks
 - [18:19:01] Multiplexing M2TS
 - [18:19:09] Processing: VID_00061 (50 of 102)
 - [18:19:09] Extracting A/V streams [VID_00061]
 - [18:19:16] Reencoding video [VID_00061]
 - [18:19:16] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 1*082 frames
 - [18:19:23] Encoding using constant rate factor.
 - [18:20:06] Video Encode complete
 - [18:20:06] Processing audio tracks
 - [18:20:06] Multiplexing M2TS
 - [18:20:11] Processing: VID_00062 (51 of 102)
 - [18:20:11] Extracting A/V streams [VID_00062]
 - [18:20:31] Reencoding video [VID_00062]
 - [18:20:31] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 10*006 frames
 - [18:21:36] Encoding using constant rate factor.
 - [18:28:44] Video Encode complete
 - [18:28:45] Processing audio tracks
 - [18:28:45] Multiplexing M2TS
 - [18:28:57] Processing: VID_00063 (52 of 102)
 - [18:28:57] Extracting A/V streams [VID_00063]
 - [18:29:03] Reencoding video [VID_00063]
 - [18:29:03] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 840 frames
 - [18:29:08] Encoding using constant rate factor.
 - [18:29:36] Video Encode complete
 - [18:29:36] Processing audio tracks
 - [18:29:36] Multiplexing M2TS
 - [18:29:40] Processing: VID_00064 (53 of 102)
 - [18:29:40] Extracting A/V streams [VID_00064]
 - [18:29:49] Reencoding video [VID_00064]
 - [18:29:49] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 2*592 frames
 - [18:30:00] Encoding using constant rate factor.
 - [18:31:34] Video Encode complete
 - [18:31:34] Processing audio tracks
 - [18:31:34] Multiplexing M2TS
 - [18:31:39] Processing: VID_00065 (54 of 102)
 - [18:31:39] Extracting A/V streams [VID_00065]
 - [18:31:46] Reencoding video [VID_00065]
 - [18:31:46] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 1*363 frames
 - [18:31:52] Encoding using constant rate factor.
 - [18:32:42] Video Encode complete
 - [18:32:42] Processing audio tracks
 - [18:32:42] Multiplexing M2TS
 - [18:32:46] Processing: VID_00066 (55 of 102)
 - [18:32:46] Extracting A/V streams [VID_00066]
[18:33:27] - Failed to retrieve audio, aborted
I hope it helps.
Old 14th February 2014, 21:15   #19200  |  Link
Capsbackup
Just curious, I have noticed ever since BD-RB began using the new tsMuxer, after movie only backups to AVCHD there is two clipi and mpls files in each respective folders. One is named 00000.clpi and 00000.mpls, the other is just .clpi and .mpls.
Is there a reason for this?
Capsbackup is offline   Reply With Quote
Thread Tools
