18th September 2009, 15:24 | #521 | Link |
The B frame must be based only on the I frame that is presentationally AFTER it (i.e. the I frame appears BEFORE it in the file/encoding order). The B frame is not based on any earlier frames (there are none) - that's what a closed GOP means. If they were based on earlier frames which were not present then the GOP is open. Note that this applies to MPEG-2 also so you may need to look at how the video delay for MPEG-2 is calculated aswell.
Of course there may be 1 or 2 B frames (or more?) presentaionally before the I frame. I suggest something like .... look forward from the start of file for the first I frame, then continue searching forward for the next video frame whose PTS is greater than the I-frame's PTS - during the search count the number of frames you find whose PTS is less than the I-frame's PTS. That will give you the number of B frames that are presentationally before the I frame, but it won't tell you whether the decoder WILL output the preceeding B frames. For that you need to look for the closed-gop flag in MPEG-2. Unfortunately for H.264 (MTS) I don't know where the corresponding flag is (I would love to know). |
5th October 2009, 20:52 | #523 | Link |
For your consideration; This 7.1 TrueHD audio sample is detected as only having 6 channels. Current FFDshow (rev3094) releases detect all 8 channels.
5th October 2009, 21:46 | #524 | Link | |
Life's clearer in 4K UHD
Cheers
13th October 2009, 16:44 | #525 | Link |
I'm getting strange results with a MTS file recorded with a Panasonic TZ7:
General ID : 0 Complete name : F:\Test\TZ7.MTS Format : BDAV Format/Info : Blu-ray Video File size : 8.46 MiB Duration : 4s 672ms Overall bit rate : 15.2 Mbps Maximum Overall bit rate : 18.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : No Format settings, ReFrames : 1 frame Duration : 4s 640ms Bit rate : 14.4 Mbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Standard : NTSC Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.624 Stream size : 7.95 MiB (94%) Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 4s 672ms Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Stream size : 110 KiB (1%) And also MPC-HC, TsMuxer and MP4Box are all saying that the file is 50 FPS. Example from MPC-HC: Code:
Video: MPEG4 Video (H264) 1280x720 50.00fps [Video] Audio: Dolby AC3 48000Hz stereo 192Kbps [Audio] http://www.megaupload.com/?d=4PFDDYK4 |
13th October 2009, 17:27 | #526 | Link | |
Software Developer
13th October 2009, 17:34 | #527 | Link |
Hi Brazil2,
In order for these Panasonic 1280x720 video streams to comply with the Blu-ray specification they contain an implementation called "frame repeats". This raises the frame speed from 25fps to 50fps but not the number of "actual" progressive frames. I guess it can be further described as a form of pull-down. EDIT: After re-muxing the elementary stream into the .MP4 container, here's what AVInaptic reports. Is there any data listed here that could explain why MediaInfo thinks it's an NTSC stream: - Code:
[ Relevant data ] Resolution: 1280 x 720 Width: multiple of 32 Height: multiple of 16 Average DRF: 21.931623 Standard deviation: 1.875284 Std. dev. weighted mean: 1.746235 [ Video track ] Codec: avc1 Resolution: 1280 x 720 Frame aspect ratio: 16:9 = 1.777777 Pixel aspect ratio: 1:1 = 1 Display aspect ratio: 16:9 = 1.777777 Framerate: 50 fps Number of frames: 117 Bitrate: 28402.984615 kbps [ About H.264 encoding ] SPS id: 0 Profile: High@L4 Num ref frames: 1 Aspect ratio: Square pixels Chroma format idc: YUV 4:2:0 PPS id: 0 (SPS: 0) Entropy coding type: CAVLC Weighted prediction: No Weighted bipred idc: No 8x8dct: No Custom intra4X4 luma: 5 7 10 12 7 10 12 16 10 12 16 20 12 16 20 20 Custom intra4X4 chromau: 5 8 12 16 8 12 16 16 12 16 20 24 16 20 24 24 Custom intra4x4 chromav: 5 8 12 16 8 12 16 16 12 16 20 24 16 20 24 24 Custom inter4X4 luma: 10 15 24 30 15 24 30 36 24 30 36 36 30 36 36 36 Custom inter4X4 chromau: 9 13 20 25 13 20 25 30 20 25 30 30 25 30 30 30 Custom inter4x4 chromav: 9 13 20 25 13 20 25 30 20 25 30 30 25 30 30 30 135 110 211 247 129 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Number of frames: 117 Drop/delay frames: 0 Corrupted frames: 0 P-slices: 108 ( 92.308 %) ####################### B-slices: 0 ( 0.000 %) I-slices: 9 ( 7.692 %) ## SP-slices: 0 ( 0.000 %) SI-slices: 0 ( 0.000 %) [ DRF analysis ] Average DRF: 21.931623 Standard deviation: 1.875284 Max DRF: 33 DRF<18: 0 ( 0.000 %) DRF=18: 1 ( 0.855 %) DRF=19: 0 ( 0.000 %) DRF=20: 27 ( 23.077 %) ###### DRF=21: 18 ( 15.385 %) #### DRF=22: 42 ( 35.897 %) ######### DRF=23: 12 ( 10.256 %) ### DRF=24: 7 ( 5.983 %) # DRF=25: 5 ( 4.274 %) # DRF=26: 4 ( 3.419 %) # DRF=27: 0 ( 0.000 %) DRF=28: 0 ( 0.000 %) DRF=29: 0 ( 0.000 %) DRF=30: 0 ( 0.000 %) DRF=31: 0 ( 0.000 %) DRF=32: 0 ( 0.000 %) DRF=33: 1 ( 0.855 %) DRF>33: 0 ( 0.000 %) P-slices average DRF: 21.888888 P-slices std. deviation: 1.553570 P-slices max DRF: 26 I-slices average DRF: 22.444444 I-slices std. deviation: 4.058218 I-slices max DRF: 33
15th October 2009, 12:28 | #529 | Link | ||
I currently don't parse the "HD" part, because I don't have any specifcations, so only the "Core" part is analyzed. I look at ffmpeg code in order to see how they parse this HD part, and I hope to be able to display the "HD" part. Quote:
MediaInfo was not designed to handle multiple Channel count or sampling rate values for 1 stream, I try to see how I can handle this (for both AC-3 and DTS)
Want to know all about your media files? http://mediaarea.net/MediaInfo |
15th October 2009, 12:52 | #530 | Link | ||||
After demuxing: Code:
00000001 access_unit_delimiter (5 bytes) (...) 00000007 seq_parameter_set (46 bytes) 00000007 Header (4 bytes) 00000007 sync: 1 (1) 0000000A nal_ref_idc: 3 (3) 0000000A nal_unit_type: 7 (7) 0000000B profile_idc: 64 (100) (...) 00000013 vui_parameters_present_flag (34 bytes) 00000013 vui_parameters_present_flag: Yes (...) 00000015 video_signal_type_present_flag (2 bytes) 00000015 video_signal_type_present_flag: Yes 00000015 video_format: 2 (2) - NTSC 00000015 video_full_range_flag: No 00000016 colour_description_present_flag: No (...) * not present * or egal to 5 (no format) But Panasonic decided to put this item in the stream, and to set it as NTSC. I report this. Quote:
* There is "frame doubling", I indicate it in the "Easy view": "(Frame doubling / 1 Ref Frames)", but I noticed this is not in the other views, I will modify other views. * Time clock is set to 100 fps. So with Frame doubling AND progressive sequence, this is 50 fps (25 fps if frame doubling AND interlaced sequence)
15th October 2009, 12:53 | #531 | Link | |
I am moving to Qt, which is a lot better for this kind of stuff, but it is unfortunatly not yet ready.
17th October 2009, 15:45 | #532 | Link |
Sample: http://rapidshare.com/files/29345782...n-mpc.mp2.html
MediaInfo reports the DAR as 2.35:1 : Code:
General Complete name : F:\Test\no-audio-in-mpc.mp2 Format : MPEG-PS File size : 2.63 MiB Duration : 3s 168ms Overall bit rate : 6 966 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, Matrix : Default Duration : 3s 120ms Bit rate mode : Constant Bit rate : 6 500 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 2.35:1 Frame rate : 25.000 fps Standard : PAL Colorimetry : 4:2:0 Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.627 Stream size : 2.42 MiB (92%) Audio ID : 128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Duration : 3s 168ms Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Video delay : -48ms Stream size : 173 KiB (6%) Code:
Video: MPEG2 Video 720x576 (16:9) 25.00fps 6500Kbps [Video] Audio: Dolby AC3 48000Hz 6ch 448Kbps [Audio] Code:
Format : MPEG-PS File size : 2.63 MiB Container DAR : 2.35:1 Duration : 3s 168ms Overall bit rate : 6 966 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, Matrix : Default Duration : 3s 120ms Bit rate mode : Constant Bit rate : 6 500 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 16:9 |
17th October 2009, 16:18 | #533 | Link | ||
00000821 sequence_header (12 bytes) 00000828 aspect_ratio_information: 3 (3) - 1.778 0000082D extension_start - Sequence (10 bytes) 00000832 horizontal_size_extension: 0 (0) 00000833 vertical_size_extension: 0 (0) 00000837 extension_start - Sequence Display (12 bytes) 0000083F display_horizontal_size: 21C (540) 00000840 display_vertical_size: 240 (576) "Sequence Display" description in specifications is not very precise, my formula is (if there is a "Sequence Display" extension): (0x1000*horizontal_size_extension+horizontal_size_value)/(0x1000*vertical_size_extension+vertical_size_value)*Mpegv_aspect_ratio2[aspect_ratio_information]/(display_horizontal_size/display_vertical_size) FYI, specifications say "display_horizontal_size and display_vertical_size do not affect the decoding process but may be used by the display process that is not standardised in this specification." (funny, isn't it?) I think this formula is right or at least the more common (I trust a lot VLC), because both VLC and MPC (not HC) display it as 2.35 (picture is streched, because picture is actually recorded in 16:9 in your case). If I don't handle "Sequence Display" extension, some other files are not well detected. If "Sequence Display" extension is not handled, DAR is "16:9", but there is a "Sequence Display" extension... If I remember well, there already was here a discussion about "Sequence Display" extension and the problems with it. Quote:
* "Display Aspect Ratio" is the displayed DAR. * "Original Display Aspect Ratio" is the DAR from the stream if different. But this file has only one DAR value (the raw video DAR). Edit: Your solution is not possible: how do you display data for multiple video stream in one container? "General" container can't have video information, because there are only 1 general item (data about the container) even if there are 30 video streams (this is possible, e.g. MPEG-TS from satellites)
Want to know all about your media files? http://mediaarea.net/MediaInfo Last edited by Zenitram; 17th October 2009 at 16:23. |
17th October 2009, 18:20 | #534 | Link | |
18th October 2009, 00:40 | #536 | Link | |
VLC is not a tiny software in a garage, they are not newbees... This is VLC/ffmpeg team vs Cyberlink/MPC! Anyway, I am interested in your vision about how to interpret "Sequence Display" bytes. Theses bytes exist, I handle them, I need a formula or the signification of theses bytes. For what reason your encoder put theses bytes in the stream? Ignoring completely "Sequence Display" is not so easy, some other files have wrong DAR if I do this, decision creates a winner and a looser. So I propose something: I am not as expert as the VLC/ffmpeg team, send this bug report to VLC/ffmpeg team, if you succeed VLC/ffmpeg team to accept that VLC has a bug with your file, I change directly my code and ignore "Sequence Display" without discussion. Another possibility is to have a reply from your encoder creator about the signification of theses bytes in the stream and have an argument about how the creator of the stream imagine theses bytes. Else I don't see what is the purpose of theses bytes if I don't handle them as I currently do, so I prefer to handle them, as VLC/ffmpeg does: if theses bytes are in the stream, there is a reason, ignoring them is not a good solution.
18th October 2009, 13:52 | #537 | Link |
I haven't encoded the file myself, it's only a sample that I've found on some forums. Here is another one showing the same issue:
http://rapidshare.com/files/28936871...itle2.vob.html I'm not sure it's a ffmpeg issue since the files are playing with the correct aspect ratio in Mplayer so it looks more like a splitter issue. But is it an issue or a feature ? I don't know. I'm not saying MediaInfo is wrong, in fact without MediaInfo I wouldn't be able to see this 2.35:1 DAR but since other tools and players are ignoring this Sequence Display it might be a good idea to show both aspect ratios in MediaInfo, the Sequence Display and the Aspect Ratio Information. So it will be easier to spot such conflicts. |
18th October 2009, 14:02 | #538 | Link | |
I will try to add this feature when I implement "multiple values" support with AC-3 / TrueHD (Core / HD values) proposed by SeeMoreDigital.
18th October 2009, 14:12 | #539 | Link |
Software Developer
Zenitram, a quick question: What exactly do the following pre-processor defines do?
NDEBUG; MEDIAINFO_MINIMIZESIZE; MEDIAINFO_LIBCURL_NO; MEDIAINFO_LIBMMS_NO
18th October 2009, 14:20 | #540 | Link | |
MEDIAINFO_MINIMIZESIZE: reduce binary size because it removes the trace feature (this feature is not yet completely ready, work in progress, this is the trace I display sometimes here in order to display what is the bytestream of files, no public GUI) MEDIAINFO_LIBCURL_NO: don't use libcurl (for read from HTTP/FTP instead of HDD files) (works well on Linux but is not currently the default, "all in one" package is not yet ready on Windows, work in progress, but if you compile yourself libcurl you can remove this define) MEDIAINFO_LIBMMS_NO: don't use libmms (for read from MMS/MMSH instead of HDD files) (this feature will not be available on Windows because libmms is not Windows-compatible, works well on Linux but is not currently the default)
