18th December 2016, 07:29 | #23 | Link |
Edit: Damn! Beaten to the punch twice. I didn't see the thread had a second page.
The "no delay" option can't be used with HE encoding. It's naughty of MeGUI to let you do it. I'll submit a bug report. Edit: Bug report. https://sourceforge.net/p/megui/bugs/865/ https://github.com/nu774/qaac/wiki/Command-Line-Options --no-delay Compensate encoder delay by prepending 960 samples of silence, then trimming 3 AAC frames from the beginning (and also tweak iTunSMPB). This option is mainly intended for resolving A/V sync issue of video. --num-priming (Experimental) Set arbitrary number of priming samples in range from 0 to 2112 (default 2112). Applicable only for AAC LC. --num-priming=0 is the same as --no-delay. Doesn't work with --no-smart-padding. Last edited by hello_hello; 18th December 2016 at 07:43. |
20th December 2016, 22:57 | #24 | Link |
OK, last try went fine but the bitrate was too variable, I targeted 64 kbps and I obtained 66 kbps, which can be a problem if a reallt want a specific 700 MB for example. I think I should use CBR to avoid this, or is there another way to have a 'precise' VBR like in video encoding?
21st December 2016, 06:39 | #25 | Link |
Which encoding method did you use? For Constrained VBR I think you're setting the minimum average bitrate, but it's allowed to increase, although then it wouldn't be the average bitrate, but that's how Apple seem to explain it. They say it might result in a higher bitrate than ABR encoding.
https://developer.apple.com/library/...1-SUBSECTION11 A 2kbps difference is only about 1.75MB for a 2 hour movie though. I tried a few quick tests, re-encoding a stereo movie soundtrack, HE-AAC, 64kbps. ABR - 63.3kbps CVBR - 66.2kbps CBR - 64kbps By the way, QAAC has built in dynamic range compression. I've never used it myself, but you should be able to add it to the custom command line section in MeGUI's encoder configuration. If you do, it might be an idea not to check the normalise option and get QAAC to do the normalising instead. I don't know if it'd change the result. You'd have to test it. The command line option for enabling normalising is -N There's an example of how to configure the dynamic range compression here: https://github.com/nu774/qaac/wiki/D...ge-compression Not that I've used this function either, but you can specify your own downmix matrix. I don't know if MeGUI would complain if the encoding script it creates contains multiple audio channels but the encoder only outputs stereo. https://github.com/nu774/qaac/wiki/Matrix-mixer There's a few utilities for "compressing" the audio that don't use standard compression techniques. They work by increasing the volume of the quiet parts rather than compressing the loud bits. I find that works far better as there's no need to adjust the compression threshold for each source. Once you have the "compression" configured the way you like it, it should be fairly set and forget. I use a Winamp DSP courtesy of ffdshow's audio decoder to compress on playback rather than do it when encoding (Potplayer can load them itself). foobar2000 can add DSPs to it's conversion chain so I mainly use it for audio encoding. There's a matrix mixer DSP for downmixing and a WinAmp bridge DSP for loading WinAmp plugins if you want to compress. There's even a plugin for opening Avisynth scripts with foobar2000. If you're interested, there's a few examples of compression attached to this post, and if you scroll up you'll find links and info on setting up foobar2000. http://forum.videohelp.com/threads/3...=1#post2462994 Last edited by hello_hello; 21st December 2016 at 07:30. |
22nd December 2016, 22:58 | #26 | Link |
Thanks for your explanations. I use the profile that I showed a snap of it in previous post with CVBR 64 kbps
Actually, i'm doing multitracks mkv, and 2 audio files with 4 MB more can result in a +703 MB file... I know for most people it's not a cotnraint, but for some personal reasons I have to make a CD size file, so it can cause some problems ^^ I think i'll stick with the same profile and I'll just change CVBR to CBR to avoid oversized files, thanks again for your help! For DRC, I just checked the box in the profile options, but I don't know if it's the same principle you're talking about or not... |
23rd December 2016, 00:58 | #27 | Link |
I think the DRC option simply applies any DRC info that may or may not be present in an AC3 stream. It's there for hardware players to apply DRC for AC3 correctly and I assume it's also applied when re-encoding if the option is checked. Someone else may know if it applies to any other source types. DTS possibly?
23rd December 2016, 11:06 | #28 | Link | |
@LeMoi
If you want sacrify the quality, using CBR instead CVBR for a 2 Kb/s difference, is your choice, of course is not my advice. @hello_hello Is correct your comment. About DTS: Yes, it can have DRC info when this flag is activated: Quote:
In Dolby Digital streams is mandatory the use of DRC, but encoding with free tools to AC3 (ffmpeg, Aften) is not recommended (bad implemented) at all.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 23rd December 2016 at 11:16. |
25th December 2016, 15:56 | #30 | Link |
I checked to make sure my memory was okay and Wikipedia says a 700MiB CD should hold 703MiB. ImgBurn says 702.8MiB for the CD I looked at, so there's a small margin for error there. https://en.wikipedia.org/wiki/CD-ROM#Capacity
