Old 3rd October 2009, 11:27   #1  |  Link
Poutnik
Useless idea generator
Poutnik's Avatar
MPC-HC - shaders - usage help/guide/manual
I cannot find any help doc how to use shaders in MPC-HC, even with uncle Google's help.
Could you point me to some useful info ?
Vista64 Premium SP2 / C2D E4700 2.6GHz/ 6GB RAM/ Intel GMA 3100 / DTV Leadtek DONGLE GOLD USB2 /
focused to DVB-T MPEG2 PS capture -> ProjectX -> M2V/MP2 -> MeGUI/AVS -> MP4[AVC/AAC]
Poutnik is offline   Reply With Quote
Old 3rd October 2009, 14:31   #2  |  Link
shiloto
You click play>shaders>combine shaders - you add the one you want to use
i use 16-235>0-255 + sharpen complex 2
the others shaders are weaker or not needed
then with control+p you enable/disabled them to see the difrence
shiloto is offline   Reply With Quote
Old 3rd October 2009, 18:47   #3  |  Link
Poutnik
Poutnik's Avatar
thanks for reply.
I have some idea about shader effects, that info is known to me.
I was focused rather on settings than on shaders themselves.
E.g
What is difference between shader and screen space shader ?
Is one for windowed and one for full screen playback mode ?
Or source versus screen pixels ?
Or source color space versus screen color space ?
Old 3rd October 2009, 20:30   #4  |  Link
shiloto
I dont know what the screen space shader is for.
But no they are not for full/win mode
source colors - color range of file
screen color - color range of screen
16-235 for SDTVs
0-255 for CRT and LCD monitors/tvs
Old 3rd October 2009, 20:49   #5  |  Link
chros
chros's Avatar
With screen space shader, resize first then shaders are applied.
With simple shaders, shaders are applied then resize.
So, eg. with a sharpen shader it's better to go with screen space shader ...
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 3rd October 2009, 23:56   #6  |  Link
Poutnik
Poutnik's Avatar
Thanks, it seems as I thought it could be.
The fact is than sharpening one is one of few useful.
mpc-hc, shaders
