Old 16th February 2009, 04:35   #1  |  Link
LongkerDandy
MPC-HC Api
Hi, I know some mpc-hc developers are hanging here.
Since the posts on SF are not well discussed, I think I can put it here.
The MPC-HC has a beta api, and it works well.
But it really lack of functionality, please please improve it.
For the basic usage,
I need a way to redirect video output to a specific window,
and I need the control of the volume.
LongkerDandy is offline   Reply With Quote
Old 16th February 2009, 09:30   #2  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
Sounds more like you need an embeddable player to me, which MPC-HC simply isn't...
now playing: [artist] - [track] ([album])
Leak is offline   Reply With Quote
Old 18th February 2009, 08:23   #3  |  Link
LongkerDandy
Thanks for Reply.
In fact there is an older post about this, talking using MPC-HC in C#, (which you can say it embedded into another program)
And that is how the API start.
Because the API is already part of there marked as beta.
I just want it to be improved.
I already integrated mplayer and vlc in my program.
But I think it will be better if I can have a dxshow based player, support dxva and so on.
Thanks
Old 18th February 2009, 10:01   #4  |  Link
Leak
Leak's Avatar
Care to post a link?
(In case you didn't notice, there's a lot of posts on this forum on things that never got finished, have only been proposed or outright don't work...)
Old 20th February 2009, 06:19   #5  |  Link
LongkerDandy
Yes, maybe you are right.
http://forum.doom9.org/archive/index.php/t-134336.html
Is there any other open source dxshow based player, or player with decent API?
In fact I can use WMP, (which somehow has api and a dxshow player) but it has so many disadvantages.
Regards
mpc-hc
