11th June 2020, 23:11 | #801 | Link | |
The 1st video has almost 12 hours (Youtube limits to 12 hours or 128 GB). This I believe has 60-70 GB: LINK REMOVED. A NEW ONE IS BEING SENT RIGHT NOW, AND I ALREADY CONFIRMED IT'S OK. THIS ISSUE WAS FIXED BY FOLLOWING THESE TIPS The 2nd video has 3 hours and more or less 22 GB: LINK REMOVED. A NEW ONE IS BEING SENT RIGHT NOW, AND I ALREADY CONFIRMED IT'S OK. THIS ISSUE WAS FIXED BY FOLLOWING THESE TIPS ***************** (Update: problem solved, I changed the audio to W64 and now the newer MKVtoolnix versions handle it just fine. Youtube is also showing the full video without issues: https://www.youtube.com/watch?v=I-hAea-eYz8 - no more stuttering, probably caused by the old audio track). For the moment I gave up the idea of reencoding the video (in H.265 it would still be as much as good as it is now), which would in my calculations be reduced to 50% of its current size, because it would take too much time in my 2014 PC. ***************** I recorded this content (Metal Gear Solid PS1 game) using an old software many will know... called FRAPS (which is crap and for years no one uses anymore). Unfortunately I didn't use OBS at the time so the files end up being very big and reencoding the whole thing isn't something I am willing to do at this point (if it's done then the resulted file would have to be 98% similar in terms of PQ). But in this case I suspected before you posted this had nothing to do with the video, since in the past I remember having a similar problem: https://forum.doom9.org/showthread.p...81#post1786481 In this case the total filesize is 95 GB and almost 15 hours. I had to split into 15 GB parts because that's the Google Drive free account max disk space, I use multiple accounts for backup. That's why I splitted back then. When I wanted to watch the whole thing I just had to append. Last edited by Perenista; 13th June 2020 at 19:40. |
12th June 2020, 18:43 | #802 | Link | ||
MKVToolNix author
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
12th June 2020, 19:44 | #803 | Link |
李姗倩 Lǐ Shān Qiàn
@foxyshadis
@lvqcl Thanks for the great info. I tried --no-md5-sum and it works perfectly (though a WARNING is shown when encoding). If the correct MD5s are desired, I guess one can still append/split FLAC.mkv by 1 demuxing FLAC 2 decoding it to WAV (*) 3 remuxing it with the original MKV while disabling FLAC track(s) 4 MKVToolNix can append/split this 5 replace the audio in the resulted file(s) with FLAC, by demuxing WAV, compressing, and remuxing. (*) or transcode it to WavPack so Step 5 will be unnecessary @Mosu Something very minor, not practicaly important: When the "second" is not integer in DateUTC, Header Editor's behavior is slightly inconsistent, e.g. the same time 01:23:45.9 may be shown as 01:23:45 or 01:23:46 depending on the year: Original Date 2000-12-31 01:23:45.9 -> Header Editor shows 01:23:46 Original Date 2001-12-31 01:23:45.9 -> Header Editor shows 01:23:45 Header Editor doesn't refuse to write a "bad" Date not expressible as EBML, when it is specified by the user. New Date 2293-04-11 23:47:16 -> Header Editor writes x = 0x7FFFFFFFCD0D2800 correctly. New Date 2293-04-11 23:47:17 -> Header Editor overflows: 0x8000000008A7F200 = x + 10^9 is written (=1708-09-22 00:12:43.290448384). If Matroska lives long, eventually the year 2293 problem will occur... |
16th June 2020, 18:49 | #805 | Link |
Pig on the wing
You just have to follow the proper naming scheme to make your batch muxing work Bulk Rename Utility is something I also use quite a lot with mkvmerge related things.
16th June 2020, 20:20 | #806 | Link | |
MKVToolNix author
For past jobs you can go to the "job queue" tool, right-click on the job that contains warnings/errors and select "view output" from the context menu. This will open a new tab in the "job output" tool and switch to that new tab. That tab will only contain the output/warnings/errors generated by that one job.
17th June 2020, 10:58 | #808 | Link |
Acid fr0g
I have tried to mux some HEVC video to Matroska and I've found the orientation is lost, i.e. a vertical video on mobile becomes horizontal.
Is there any manual setting we can use to set back the original rotation or any tweak you can introduce? Thanks.
@turment on Telegram |
17th June 2020, 14:28 | #810 | Link | |
Acid fr0g
I have looked at HEVC file with MediaInfo and there is a Video TAG, such as Rotation : 90° Isn't possible to have MKV GUI to automatically recognize Rotation and set the correct tag?
@turment on Telegram Last edited by tormento; 17th June 2020 at 14:48. |
17th June 2020, 18:38 | #811 | Link |
Using the delay for audio tracks usually works everywhere? Sometimes I introduce a negative delay for some audio tracks. Other times I put a positive one, also for subtitles. I know we can edit both cases and avoid using the delay field from MKVToolnix, but I think this will imply a reencode at least for audio.
What I find odd is that I once uploaded a video excerpt to Vimeo and the delay was ignored. The same video sent to Dailymotion worked as intended. And for both services I uploaded the same file. |
17th June 2020, 19:31 | #812 | Link |
Most often it works. But not always (as you found out). If you want to be sure you have to take the extra steps to pre-pend silence outside MKVToolNix. (Negative audio delays usually work because mkvmerge does delete audio frames, then).
Subtitle delays should always work, at least with text subtitles. Depends on the format and software you are using. Softwares like eac3to and delaycut may delay audio without re-encoding. If that doesn't work ffmpeg may be able to encode some silence which you can manually prepend in mkvmerge. |
17th June 2020, 22:34 | #813 | Link | |
Matroska find' ich toll
You can use my chapterEditor -> MatroskaTools->Tags In a SimpleTag set TagName = ROTATE TagString = 90 or -90 TargetUID = the type is TagTrackUID and the UID is the video track UID |
20th June 2020, 16:05 | #814 | Link |
Not sure if this is a bug or if I'm just not understanding how it's supposed to work, but I have some audio files and some video files, the latter consisting of a single frame each. I'm trying to combine them into a file where each image displays for the duration of one of the audio files. I tried changing the duration/FPS, but since they're different lengths, that didn't work. I tried stretching them, but if I stretch them by the proper amount (which took a fair amount of trial and error to figure out), they show for the proper durations, but the file is twice as long as it's supposed to be. In this case, if the first audio file is e.g. 90s long, and therefore the first chapter in the final file should also be 90s, the chapter is actually 180s long and when it reaches 90s it jumps to the next chapter. But if I click in the timeline between 90s and 180s, it just "plays" all the way to chapter 2. If I cut the stretch factors in half, the total and chapter lengths are correct, but the images only display half as long as they're supposed to, so the image for chapter two in the above example would display at 45s.
Any ideas either on how to do this or whether this is actually a bug? It seems like one to me, but apparently I have to know for sure before reporting it as such. |
20th June 2020, 17:26 | #815 | Link |
Hard to answer without having a sample file at hand. Video timings are usually(*) not related to chapters. You could try to manually set the timings for the video via timestamp (v2) files. https://mkvtoolnix.download/doc/mkvm...imestamp_files
(To check your output file let mkvextract create a timestamp v2 file for your video track or look into mkvinfo.) If it still does not work I would say it is a problem of your player. (*) if we ignore ordered chapters |
27th June 2020, 20:15 | #818 | Link |
MKVToolNix author
MKVToolNix v48.0.0 released
Hey everyone,
summer's upon us, and surely we're all itching to stay at home some more, aren't we? Well, despair not, at least you can update your MKVToolNix version to the latest & shiniest there ever was. This release features massive improvements to the handling of Blu-ray playlists (MPLS files) & corresponding MPEG transport streams (M2TS files), both bug fixes and real enhancements. See the news below for details. Important news for package managers are the new reuquirements for libEBML/libMatroska & the main development branch having been renamed in my source code repo. Again, see the news for details. Here are the usual links: the MKVToolNix home page, the Windows installer/portable version & macOS DMG & Linux AppImage and the source code. The Windows and macOS binaries as well as the Linux AppImage are available already. The other Linux binaries are still being built and will be available over the course of the next couple of hours. Here are the NEWS since the previous release: Version 48.0.0 "Sick Of Losing Soulmates" 2020-06-27 New features and enhancements
Bug fixes
Build system changes
Other changes
Have fun
matroska |
