Old 19th March 2007, 02:40   #21  |  Link
bigotti5
Spielberger
bigotti5's Avatar
Offset to the next SP_DCSQ are wrong
regionTest1.sup
0x9FA should be 0xA11
regionTest5.sup
Subpicture 1: same as above
Subpicture 2: 0x16D8 should be 0x16EF
Correct it and muxman will do the job
bigotti5 is offline   Reply With Quote
Old 19th March 2007, 08:29   #22  |  Link
Paddington
Author of SubtitleCreator
Paddington's Avatar
Thanks a lot, bigotti5 - I will try it immediately when I get home tonight!
And indeed - you were right! After I fixed, it works like a charm. I will post a beta of SubtitleCreator so others can test it too.
Last edited by Paddington; 19th March 2007 at 22:41. Reason: Tested the statement and concluded it worked
Paddington is offline   Reply With Quote
Old 20th March 2007, 05:20   #23  |  Link
mpucoder
MuxMan no doubt got lost trying to find the last SP_DCSQ, a step that is needed during import to determine the duration.
btw your unusual display area showed up a bug in the 0.18 viewer/editor
mpucoder is offline   Reply With Quote
Old 20th March 2007, 22:12   #24  |  Link
Paddington
Paddington's Avatar
Good to hear that it helped you improve your code to, mpucoder!
BTW, for all interested parties, I've uploaded the beta release here (requires .NETv2 installed).
Old 21st March 2007, 16:52   #25  |  Link
mpucoder
Can you post the corrected sup files? I made some corrections to them here, but test5 has some overlapping and backwards movement in time, it would be nice to see what you intended the track to look like.
Old 21st March 2007, 18:07   #26  |  Link
bigotti5
Spielberger
bigotti5's Avatar
The beta at sourceforge.net is entitled as 2.2.1 but the download is 2.1.1 without karaoke...
Old 21st March 2007, 23:38   #27  |  Link
Paddington
Paddington's Avatar
Here you go. Using your project file, you will probably not see the first subtitles since they start before your start time of 10s. See the image for the original input.
Old 21st March 2007, 23:41   #28  |  Link
Paddington
Paddington's Avatar
The original upload went sour on SourceForge - I've uploaded it again. The filename should be Setup_SubtitleCreator_v2_1b1.exe, size 1,880,011 bytes: it will actually install SCv2.2.1 - please give it another go!
Old 22nd February 2008, 00:48   #29  |  Link
manusse
SubtitleCreator's Co-Dev
manusse's Avatar
13 color subpicture
Using the same method, with DVDSubEdit, an hex editor plus a small SUP Analysing proggie I'm currently being developping for my support of SubtitleCreator, I've made a 13 color subpicture for the fun. I could have done more but it's already fun. There are 12 different colors used plus the background.
Compared to mpucoders'subtitle, there are 3 areas using 2 LN_CTLI in the CHG_COLCON command.
I could watch the result using WinDVD 4 but couldn't make a screen copy because of color keying.
I've remuxed mpucoders'DVD with this new SUP.
Enjoy.
Manusse
manusse is offline   Reply With Quote
Old 27th May 2022, 02:07   #30  |  Link
dixxfixx
256
Just to see if I could do it, 14 years later. Doesn't do it in VLC, but standalone works and PowerDVD works. Some fun.
dixxfixx is offline   Reply With Quote
