Old 29th November 2022, 16:44   #1761  |  Link
Dogway
Major update today that I've been holding back for a few months.
QTGMC+: Implemented EEDI3CL for faster EEDI3 deinterlacing
TransformsPack: Refined illuminant chromaticities. Fixed chroma placement algo (finally). More robust range and gamma conversions. Still need to finish CAT.
ResizersPack: Fixes on chroma placement and pixel center shifts in nnedi3/eedi3. New functions/wrappers (eedi3resize, RAVUresize, FSRresize, RIFEwrap, EEDI3wrap)
Please test and report since I won't be working much further on these anymore.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 29th November 2022, 18:22   #1762  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
Thanks Dogway!
Doing a lot of DVD stuff soon. I always let QTGMC+ as part of Ceppo's tools run in these scripts to take care of nasty phase shifts which a lot of the ordinary deinterlacers can't handle properly. Will let you know if I see something unusual.
Btw. what about NNEDI3CL and subpixel=4? Is the issue still present?
https://forum.doom9.org/showthread.p...47#post1976247
LeXXuz is offline   Reply With Quote
Old 29th November 2022, 20:12   #1763  |  Link
Dogway
I tested again and it's working fine for me, no errors. However I noticed a ghosting artifact caused by big pixel center shift with high pel. That is because by default the center shift is not being fixed for nnedi3 in SMDegrain, as that matches the internal motion vectors shift. But with high pel the deviation is higher, so I better fix it for that case. I will update tomorrow with a few other cosmetics.
Old 30th November 2022, 13:37   #1764  |  Link
kedautinh12
Your latest ver can't fix with propSet("_FieldBased",0) anymore
- When i use with tfm().tdecimate() i got this error
- After add propSet("_FieldBased",0), i got this error (fine with older vers)
Old 30th November 2022, 15:08   #1765  |  Link
Dogway
Thanks for the report! Test now.
Old 30th November 2022, 16:32   #1766  |  Link
kedautinh12
Ok, error gone with propSet("_FieldBased",0) but error still have without propSet("_FieldBased",0)
Old 30th November 2022, 17:18   #1767  |  Link
Dogway
Yes, TIVTC needs to be updated for frameprops support.
BTW I'm updating SMDegrain in a moment.
Old 1st December 2022, 08:55   #1768  |  Link
madey83
Posts: n/a
@Dogway,
Your last release give me below errors:
Script Error
Script error: There is no function named 'libplacebo_Resample'.
(E:\4k_encode\Avisynth-Scripts-master\TransformsPack - Main.avsi, line 927)
(E:\4k_encode\Avisynth-Scripts-master\TransformsPack - Main.avsi, line 1302)
(E:\4k_Encode\Avisynth-Scripts-master\ResizersPack.avsi, line 230)
(E:\4k_Encode\Avisynth-Scripts-master\ResizersPack.avsi, line 274)
(E:\myVideo.avs, line 159)
line 159 of avs script is: deep_resize(1920,edge="Zopti1080")
my plugns:
import("E:\4k_Encode\Avisynth-Scripts-master\MIX mods\GradFun3plus.avsi")
import("E:\4k_Encode\Avisynth-Scripts-master\ExTools.avsi")
import("E:\4k_encode\Avisynth-Scripts-master\SMDegrain v3.5.6d\SMDegrain v3.5.6d.avsi")
Import("E:\4k_encode\Avisynth-Scripts-master\ResizersPack.avsi")
Import("E:\4k_encode\Avisynth-Scripts-master\MIX mods\LSFplus.avsi")
Import("E:\4k_encode\Avisynth-Scripts-master\MIX mods\SharpenersPack.avsi")
Import("E:\4k_encode\Avisynth-Scripts-master\GradePack.avsi")
Import("E:\4k_encode\Avisynth-Scripts-master\ScenesPack.avsi")
Import("E:\4k_encode\Avisynth-Scripts-master\MasksPack.avsi")
Import("E:\4k_encode\Avisynth-Scripts-master\MIX mods\Spresso.avsi")
import("E:\4k_encode\Avisynth-Scripts-master\EX mods\GrainFactory3mod.avsi")
import("E:\4k_encode\Avisynth-Scripts-master\EX mods\DeblockPack.avsi")
import("E:\4k_encode\Avisynth-Scripts-master\TransformsPack - Main.avsi")
import("E:\4k_encode\Avisynth-Scripts-master\TransformsPack - Models.avsi")
import("E:\4k_encode\Avisynth-Scripts-master\TransformsPack - Transfers.avsi")
import("E:\4k_Encode\Avisynth-Scripts-master\ResizersPack.avsi")
loadplugin("E:\4k_encode\BM3DCUDA_AVS-test9\x64\BM3DCPU_AVS.dll")
loadplugin("E:\4k_encode\BM3DCUDA_AVS-test9\x64\BM3DCUDA_AVS.dll")
loadplugin("E:\4k_encode\BM3DCUDA_AVS-test9\x64\BM3D_VAggregate_AVS.dll")
loadplugin("E:\4k_encode\dgdecnv_244\DGDecodeNV.dll")
loadplugin("E:\4k_encode\vsTCanny-1.1.8\x64\Release\vsTCanny.dll")
loadplugin("E:\4k_Encode\neo_FFT3D_r11\x64\neo-fft3d.dll")
loadplugin("E:\4k_Encode\fmtconv-r30\win64\fmtconv.dll")
Do i miss something? Your previous release worked fine with the same AVS settings.
Old 1st December 2022, 08:57   #1769  |  Link
kedautinh12
You need load this plugin
https://github.com/Asd-g/avslibplacebo
Old 1st December 2022, 09:08   #1770  |  Link
madey83
Posts: n/a
Thank you. It was so quick
Old 1st December 2022, 10:23   #1771  |  Link
madey83
Posts: n/a
now i have got this:
Script Error
System exception - Access Violation
(E:\4k_encode\Avisynth-Scripts-master\EX mods\DeblockPack.avsi, line 239)
(E:\myVideo.avs, line 164):: CCD(15)
function CCD (clip a, float "thres", bool "interlaced", int "U", int "V") - function definition.
Old 1st December 2022, 10:31   #1772  |  Link
kedautinh12
Are you got avs+ and vc++ latest ver???
https://gitlab.com/uvz/AviSynthPlus-Builds
https://github.com/abbodi1406/vcredist
Old 1st December 2022, 10:40   #1773  |  Link
madey83
Posts: n/a
i will test this out later today.
Thank you for support
Old 1st December 2022, 11:57   #1774  |  Link
LeXXuz
LeXXuz's Avatar
Dogway, when I use globals in SMDegrain for 2-stage denoising I can't use subpixel=3 in the 2nd stage.
Error message:
Scrip error: the named argument "pelclip" to MSuper had the wrong type. Lines 299 and 656.
I have to use subpixel=2 for the 2nd stage if globals are active.
Old 1st December 2022, 13:08   #1775  |  Link
madey83
Posts: n/a
i did encode with CCD and without deep_resize(1920,edge="Zopti1080")
and it went fine and i did not change anything regarding AVS and VC versions.
Old 2nd December 2022, 08:05   #1776  |  Link
madey83
Posts: n/a
Good morning,
you were right. thank you
Old 2nd December 2022, 21:01   #1777  |  Link
Dogway
Error message:
Sure, with globals some parameters must match, read docs.
You are trying to reinterpret the same motion vectors you are loading.
Old 2nd December 2022, 21:10   #1778  |  Link
LeXXuz
LeXXuz's Avatar
Yeah I know they have to match. First stage was also set to subpixel=3, of course.
It only works if both are set to 2.
It does not work when both are set to 3.
(And of course it doesn't work when they don't match.)
Old 2nd December 2022, 21:42   #1779  |  Link
Dogway
Thanks, I spotted the issue, promoted to v3.5.7. Not sure what was the logic of my !GlobalR ternary but I removed it and works now. Also fixed Globals=3 and a typo on nnedi3 pixel_shift.
Old 2nd December 2022, 23:06   #1780  |  Link
LeXXuz
LeXXuz's Avatar
Nice! Will give it a go again soon.
avisynth, dogway, filters, hbd, packs
