Old 23rd May 2024, 08:23   #981  |  Link
LigH
LigH's Avatar
Originally Posted by LigH View Post
PS: MP4Box can create an MP4 containing VVC video. But VLC with plugin does not decode the video in it.
That day (June 9, 2022) I created VLC issue 27055; today a developer got assigned.
PS: Reading the history of comments in it again makes me sigh deeply.
New German Gleitz board
Old 23rd May 2024, 20:58   #982  |  Link
kurkosdr
Generally, when it comes to VLC, you should assume a given bug is going to be fixed whenever or never. Those people have no process to rank bugs according to importance or popularity, so VLC is basically a hobby project with a professional-looking website. Hence the "send patches" response.
A characteristic example of this is how they still haven't implemented DVD-Video forced subtitles decades after DVD-Video support was added to VLC, which makes any DVDs that use forced subs to subtitle a foreign language/elvish/alienspeak unwatchable. The bug for this issue (#1135) is still open 17 years later.
I just moved to Kodi for my DVD-watching needs, and I suggest you do something similar: Find a player that can play VVC today or risk waiting for decades for VLC to add it.
kurkosdr is offline   Reply With Quote
Old 3rd June 2024, 12:27   #983  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
VVdec has added support for the "film grain synthesis" attribute: https://github.com/fraunhoferhhi/vvdec/pull/178
Add film grain synthesis (based on VFGS). When an FGC SEI message is found in the bitstream, it is decoded and used to synthesize grain on top of the regular decoded picture. No specific commandline options are added, everything is automatic and hardwired = currently there is no way to disable FG synthesis if an FGC SEI message is received.
birdie is offline   Reply With Quote
Old 4th June 2024, 05:08   #984  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
Just announced Intel Lunar Lake / Xe2-LPG has been confirmed to support hardware VVC decoding. Finally.
Old 4th June 2024, 06:26   #985  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
I really hope an option is introduced to prevent reintroducing the already removed grain. It would make everyone happy: those who like grain can leave it on and those who prefer cleaner pictures like me just need to disable it, while both of us get the compression efficiency by coding a smoother picture.
As for hardware decoding, that's very good to know from Intel. Feels like we're slowly getting to the point in which H.266 is actually getting usable.
Old 4th June 2024, 07:58   #986  |  Link
Jamaika
"Also disclosed was the Intel NPU 4, which Intel claims delivers up to 48 TOPS, surpassing Microsoft's Copilot+ requirements for the new age of AI PCs."
What does new age of AI PCs mean?
"The main change affecting this is the addition of an additional 8 MB side cache, which allows for reduced traffic in the system memory for multimedia-based tasks."
Is this extra memory on the motherboard?
"Intel Lunar Lake has been even further rebuilt in terms of the Media Engine and Display Engine, which is probably the most extensive system in this matter among laptops.
In addition, there is support for HDMI 2.1 and DisplayPort 2.1 (we are talking about full support, i.e. UHBR10, UHBR13.5 and UHBR20, but the type of DP 2.1 supported in a given laptop will depend on the specific OEM) and eDisplayPort 1.5."
Are these power-saving processors just for laptop?
Jamaika is offline   Reply With Quote
Old 4th June 2024, 09:34   #987  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
That's just a term made up by Microsoft to justify shipping Copilot in as many things they could.
Essentially, the era of "AI PC" started with ARM in which you had the normal parts of the CPU doing normal computations and then dedicated accelerators (you can think about them as part of the CPU) to perform AI-related tasks. This, in Microsoft's view, would offload some of the calculations from their datacenter GPUs to the dedicated co-processor unit inside the CPU in the consumer device for the most basic stuff. They set a target and both AMD and Intel did something to reach that so that they could be part of this "AI PC" or "Copilot+" marketing nonsense.
Old 4th June 2024, 11:12   #988  |  Link
MoSal
PCs that do mostly-useless low-precision bad math fast in the name of intelligence.
" In addition, there is support for HDMI 2.1 and DisplayPort 2.1 (we are talking about full support, i.e. UHBR10, UHBR13.5 and UHBR20, but the type of DP 2.1 supported in a given laptop will depend on the specific OEM) and eDisplayPort 1.5."
It's not full support if Intel can't partner with others to pressure the HDMI forum to allow support for 2.1 on Linux, and threaten a future boycott if they don't budge (AMD tried alone and failed). Otherwise, "full support" and "no support" are equivalent for us, an admittedly small but significant percentage of users. Directing the cost incurred towards something else would actually be more beneficiary to us. This also applies to dedicated GPUs, which Intel also sells nowadays.
https://github.com/MoSal
MoSal is offline   Reply With Quote
Old 4th June 2024, 11:43   #989  |  Link
Jamaika
Thanks for your replies.
It will be more profitable to buy AMD or Intel. What amounts are we talking about?
As I understand it, AVX512 will replace AVX10. What economical power supply is needed for this? I understand that we will not buy 800W. How to configure it yourself?
Old 4th June 2024, 14:50   #990  |  Link
kurkosdr
HDMI is a front for Hollywood studios to make arbitrary demands to the consumer electronics industry (enabled by the DMCA's "anti-circumvention provisions"). If you don't obey, no HD or 4K HDR Hollywood content for you.
So, with that in mind, it's a case of the HDMI Forum boycotting anyone who doesn't comply with their demands, not the other way around.
Old 5th June 2024, 05:40   #991  |  Link
MoSal
Boycotts/Threats is how we got a single high-capacity compact disc standard (DVD):
https://web.archive.org/web/19981202...pr.rel.cd.html
And if boycotts/threats don't work, hardware vendors/manufacturers could rally around and push for an alternative new standard if they wanted to. We have historical examples of same-gen but later-appearing standard B ending up killing standard A due to vendors not wanting to deal with A.
Hardware vendors/manufactures simply don't consider the current situation a deal breaker for them to want to take such steps.
Old 5th June 2024, 18:43   #992  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
I've found a treasure trove of sample VVC clips for testing:
https://dvb.org/specifications/verif...-test-content/
They need some name and email, you can type anything.
Old 5th June 2024, 20:42   #993  |  Link
benwaggoner
I've looked at some degrained-for-FGS content with FGS turned off, and it can look pretty weird and unpleasant. The signal-noise ratio is quite low for a lot of grainy content, particularly 16mm and Super35. The degrained versions can kind of look soft and textureless, like a mediocre upscale.
The results aren't as good as a real high-quality noise reduction that mutes the excess grain, but leaves enough texture to keep things from looking abnormally flat.
Wonderful news indeed!
Ben Waggoner
My Compression Book
Old 6th June 2024, 01:50   #994  |  Link
Yups
Hardware decoding in action:
https://youtu.be/-2yxPal4wQI?t=1951
Yups is offline   Reply With Quote
Old 7th June 2024, 15:13   #995  |  Link
kurkosdr
You mean like how Hollywood studios picked the winner of the HD-DVD vs Blu-Ray format war by deciding one day to only throw content at one format (Blu-Ray) while letting the other rot (HD-DVD)? This happened shortly after BD+ gave studios the hope of unbreakable DRM. Whatever studio support HD-DVD had dried up right there and then.
Or how Hollywood studios cut out MacOS X from Blu-Ray and HD-DVD support because MacOS X didn't provide the DRM infrastructure Hollywood studios demanded for Blu-Ray and HD-DVD?
It doesn't matter what happened in the distant past, today pre-recorded content is king and DRM is legally empowered by the DMCA. Hollywood studios can cut out from their encrypted content whatever OS and hardware combination doesn't comply with their arbitrary demands. I mean, what can AMD and Intel do? "Boycott" HDMI 2.1 and come out and say "Nvidia GPUs as well as every $400 console out there support HDMI 2.1 but our flagship GPUs don't, please buy our flagship GPUs"? If they do that, they might get that 2% of users running Desktop Linux but will lose the much bigger market of Windows users who want their new GPU to support HDMI 2.1.
The weird thing in this case is that HDMI 2.1 is required only if you want 4K@120fps, and Hollywood doesn't serve any 4K@120fps content, but they can still mandate all kinds of DRM requirements by acting as gatekeepers to the HDMI spec. DisplayPort is technically a thing but isn't a thing on TVs (due to lack of eARC support), so you want at least one HDMI 2.1 port if you want to output 4K@120fps to a TV (which means GPU vendors can't boycott HDMI 2.1). And then there is the open question of whether encrypted 8K content will be allowed on DisplayPort or be HDMI 2.1-only.
Old 7th June 2024, 18:14   #996  |  Link
ksec
Great, excluding CPU and GPU that is probably around 2W decoding 4K. Good for Desktop, Good Enough for Laptop. not quite Smartphone ready yet. But hopefully next year for Qualcomm Mediatek and Apple.
Now we need encoders.
Previously iwod
ksec is offline   Reply With Quote
Old 7th June 2024, 19:19   #997  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Hold on a second, I thought that the whole thing about HDMI 2.1 not being allowed on Linux was only because AMD tried to make the support part of its open source driver.
I might be wrong here, but I remember reading people suggesting AMD to ship a binary blob instead so that it would have been accepted.
Did I get it wrong?
Old 7th June 2024, 23:28   #998  |  Link
Yups
Maybe less because the RAM is included in the package power on Lunar Lake. Encoding hopefully on Xe3.
Old 8th June 2024, 16:23   #999  |  Link
ksec
I would expect at least 1W during active use. That puts decoding into 1W category. Sub 1W when deciding 1080P / 2K content. Pretty impressive. That doesn't take into account the bitrate it was decoding. Sounds like good enough for me!
Bring me x266!
Previously iwod
Old 10th June 2024, 14:18   #1000  |  Link
oibaf
Dolby Laboratories to acquire GE Licensing in $429m deal
Technology company Dolby Laboratories has announced a definitive agreement to acquire GE Licensing from GE Aerospace in an all-cash deal valued at $429m.
The inclusion of GE Licencing’s video codec technology patents such as HEVC and VVC will complement and expand Dolby's existing intellectual property portfolio.
oibaf is offline   Reply With Quote
