31st May 2020, 14:24 | #41 | Link |
Just curious - Do you ignore Defender or do you just not use the program at all because of the rejection?
Groucho's Avisynth Stuff |
31st May 2020, 15:06 | #43 | Link |
Sounds like Defender is acting similarly to some of the worst viruses out there. Deleting files, impeding productivity, etc.
Sometimes I wonder how you guys get anything done with AV, UAC and whatnot. I don't have defender or any other AV software and certainly disabled UAC, I just have a properly configured firewall (comodo). Never caught any nasty creepy crawler. OK, I did catch the Blaster thingy 20 years ago when I did not have any firewall software. Anyway, that was sorted out in a few minutes by restoring the OS image from the previous day.
31st May 2020, 15:17 | #45 | Link |
I see. I thought it was some type of masochism.
10th July 2020, 20:22 | #46 | Link |
v1.1.2
- Suppress report of duplicate functions from the GrunT plugin
11th July 2020, 16:04 | #47 | Link |
Looks like you fixed the false positive detections, too. There's only one no-name AV flagging it on VirusTotal, and Windows Defender doesn't automatically delete the file upon running. Sweet. I can finally start recommending it again.
12th July 2020, 21:59 | #49 | Link |
Sorry, I did not fix that. At this stage, with byte patterns in the 100 thousands or even millions, it has become virtually random whether these virus detection engines report a something or not. Give it another few years and you won't be able to download anything.
2nd January 2021, 18:50 | #50 | Link | |
When I run version 112 after a fresh AVS+ install and setup of QTGMC, I get this:
2nd January 2021, 19:08 | #51 | Link | |
See My Avisynth Stuff |
31st March 2021, 18:52 | #52 | Link |
v1.1.3
- Updated libcpuid to the latest version
19th April 2021, 04:54 | #53 | Link |
I seen ver 1.1.3 was detected by some antivirus software: https://www.virustotal.com/gui/file/...67f0/relations
19th April 2021, 13:08 | #54 | Link |
According to VirusTotal, 7 said bad, 60 said good.
Of the bad, 2 said suspicious, and 1 heuristic, both pretty much meaning suspicious, and 1 (Microsoft) said PUA; possibly unwanted app, ie system tool. Its not uncommon on a system tool to have some AV making bad judgements. Nothing at all to be alarmed about. I once got a bunch of false +ve detections on a VB program that had 49 GUI buttons neatly arranged [7x7], I moved one or two to make them not so ordered, and no detections at all, sad but there you go.
18th July 2021, 02:32 | #55 | Link |
Trying to get a new computer configured for AviSynth and using the tool to check. I get this: [Plugin errors/warnings] ________________________________________________________________________________ Function duplicates: "DirectShowSource" : "[InternalFunction]" "DirectShowSource" : "[PluginFunction]" "TCPServer" : "[InternalFunction]" "TCPServer" : "[PluginFunction]" "TCPSource" : "[InternalFunction]" "TCPSource" : "[PluginFunction]" I have no idea what any of it means, if it's serious and preventing me from opening a number of scripts, and wondering if and how I can fix it. Can the tool be run on individual scripts and, if so, how? |
18th July 2021, 04:01 | #56 | Link |
@manono
I guess you are trying to install AVS 2.6 (not AVS+)? If so, those functions were internal functions, whereas in AVS+ they are now independent plugins (hence PluginFunction), why it is complaining about duplication, it is because your plugin dir is set to a folder whose AVS+ plugins in it (DirectShowSource.dll, TCPDeliver.dll). So in my opinion, you may want to remove (uninstall) AVS+ plugins (or simply move them to other folder). |
18th July 2021, 07:17 | #58 | Link |
Thank you both for the prompt responses. As far as I know, only AviSynth 2.6.0 has been installed.
There are the 2 DLLs mentioned as being in the 'C:\Program Files (x86)\AviSynth+\plugins\' folder, but I know nothing about that or why it's there. There's an 'Uninstall.cmd' in there which offers to uninstall AviSynth (not AviSynth +), but I don't want to do that. Also, I don't autoload anything, but load and import all DLLs and functions into my scripts, most of which are premade templates I use in my projects. What prompted me to install and use Groucho2004's AviSynth Info Tool was the trouble I was having getting RGTools to work, of all things. Maybe I needed to reboot after installing the Microsoft Visual C++ 2019 Redistributable Package it requires because it's working now. So, unless there's a reason to move or delete the duplicates, I'll leave well enough alone. Again, thanks to you both for taking the time to respond. |
