28th February 2009, 22:48 | #61 | Link | |
I forgot about the number of packets bug in TSMUXER. I'd fixed it in BD-RB but not in FIXCLPI. I'll put another version up shortly that fixes that too (as long as FIXCLPI runs in folder mode and the BDMV\STREAM folder can be found). Last edited by jdobbs; 28th February 2009 at 22:52. |
28th February 2009, 23:08 | #62 | Link | |
I am trying it in a minute on a ripbot avchd (BDMV folder on a DVD). When I play it them in a Sony S350. The picture freezes when trying to ff/rwd. Skip chapters work but there is no sound for a few seconds and then it plays normally. I have been blaming the player as the same disc works perfectly in a Samsung 1500 player. |
28th February 2009, 23:22 | #63 | Link | |
28th February 2009, 23:39 | #64 | Link |
I think the new version has improved the ripbot files. Both the Sony S350/S550 doesn't have great navigation with discs. Even at full speed it is pretty slow going through a film but it jumps from one bit to another as it freezes periodically on frame while the counter does the same thing. It can be quite hard to find certain bits sometimes. The new Fixclpi has managed to make the navigation a little smoother.
I am going to compare a TsMuxed BD that has the first fixclpi done to it and then redo it with the 2.2 version. |
1st March 2009, 00:27 | #65 | Link | |
1st March 2009, 03:36 | #67 | Link |
And here is one more release (v2.30) of FixCLPI. In this one if you pass it a folder as the parameter, it will also automatically fix the packet_count variable (the one written by TSMUXER is often if not always wrong). Of course it will only correct it if the CLPI is in a standard BD format (CLPI is in either the BACKUP/CLIPINF or the CLIPINF folder, and the M2TS is in the STREAM folder). The program is verbose, so if it gets changed, you'll know it.
1st March 2009, 03:55 | #68 | Link | |
1st March 2009, 09:10 | #69 | Link |
fixclpi 2.30 worked great on Panasonic BD30, ff, rw, chapter skips work like retail BD's which is a lot better then no fixclpi.
previous fixclpi broke playback in this player. Last edited by turbojet; 1st March 2009 at 09:19. |
1st March 2009, 12:56 | #71 | Link |
Looks like we're good to go then.
I'm removing all previous versions of FixCLPI from my site. So v2.30 should be the one to use. Thanks to all for testing and to anode for his very observant and helpful report. Last edited by jdobbs; 1st March 2009 at 13:39. |
1st March 2009, 15:17 | #75 | Link |
Aging Video Hobbyist
It appears "fixclpi" is built-in to BD-RB and not an external Tool, so can we expect you will update that shortly? It seems the new version does not work "over" BD-RB output as it stands right now. Thanks jdobbs for all the energy you put-in to this the last couple days!
1st March 2009, 15:35 | #76 | Link | |
2nd March 2009, 00:43 | #77 | Link |
Hi all... i have done quite a few encodes with BD-RB, and yes they dont work on the Panasonic BD35 (or the 55)
Is there anyway I can copy them back to my pc and correct them in anyway without reencoding them again? And how do i do it?? Many Thanks! |
2nd March 2009, 01:14 | #78 | Link |
Hmmm... I'll update FixCLPI.EXE to recognize that condition and rewrite the CLPI files. I have quite a few that, even though they work for me, need to be corrected. I like things to be straight on my backups. Luckily I keep an ISO for almost all my backups on a harddrive.
[EDIT] Ok. I stand corrected. As long as they weren't done by one of the versions from the past couple of days, you can run FIXCLPI v2.30 against them and it should fix them. I just did it on a couple of mine. So, no need for a new version. Example (for APOCALYPTO): 1. Create a folder called c:\APOCALYPTO 2. Copy the root folders (BDMV and CERTIFICATE) to the new APOCALYPTO folder. 3. run "c:\path\to\fixclpi.exe" c:\APOCALYPTO 4. you'll see messages for CLPI files that are corrected 5. Reburn or rewrite to UDF 2.5 ISO or disc. [EDIT AGAIN] Not positive if this will work for the Panasonic on previously "fixed" files, waiting for feedback. Last edited by jdobbs; 2nd March 2009 at 01:48. |
2nd March 2009, 01:29 | #79 | Link |
EDIT!!! YOU STAR!!! Thank you will try in the morning!
Thanks for that - i have about 30 i might need to redo... eek! Just donated aswell... i encourage others to also LMK when a simpleton like me can redo em all LOL Last edited by MB2; 2nd March 2009 at 01:38. |
2nd March 2009, 01:31 | #80 | Link |
I tell you what ive done
Ive ripped everything using TSremux 1.8.8 movie only... stored on hd. Then gone to mainly the v.1.9.01 of rebuilder and done quite a few... Excuse my igorance, what do i then do? Copy the BDMV folders etc to pc and run FixCLPI.EXE I double click on it and im not sure whats its doing... Ive also started your new version of BDRB on 2 films - these should play ok now on the BD35/55 if im correct?? |
