Old 6th October 2020, 07:56   #1  |  Link
Selur
Selur's Avatar
xvid_encraw how to use pipe input?
Looking at 'xvid_encraw -help':
xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert
xvid_encraw built at 20:58:26 on Apr  9 2020
Usage : xvid_encraw [OPTIONS]
Input options:
 -i      string  : input filename (stdin)
 -type   integer : input data type (yuv=0, pgm=1, avi/avs=2) (0)
 -w      integer : frame width ([1.4096])
 -h      integer : frame height ([1.4096])
 -csp    string  : colorspace of raw input file i420, yv12 (default)
 -frames integer : number of frames to encode (all)
Output options:
 -dump           : save decoder output
 -save           : save an Elementary Stream file per frame
 -o      string  : save an Elementary Stream for the complete sequence
 -avi    string  : save an AVI file for the complete sequence
Rate control options:
 -framerate        float      : target framerate (auto)
 -bitrate          [integer]  : target bitrate in kbps (700)
 -size             integer    : target size in kilobytes
 -single                      : single pass mode (default)
 -cq               float      : single pass constant quantizer
 -pass1            [filename] : twopass mode (first pass)
 -full1pass                   : perform full quality first pass (disabled)
 -pass2            [filename] : twopass mode (2nd pass)
 -max_key_interval integer    : maximum keyframe interval (300)
 -zones            [zones]    : use `-help zones' for usage guidelines
 -zq     starting_frame float : bitrate zone; quant
 -zw     starting_frame float : bitrate zone; weight
Single Pass options:
 -reaction         integer    : reaction delay factor (16)
 -averaging        integer    : averaging period (100)
 -smoother         integer    : smoothing buffer (100)
Second Pass options:
 -kboost           integer    : I frame boost (10)
 -kthresh          integer    : I frame reduction threshold (1)
 -kreduction       integer    : I frame reduction amount (20)
 -ostrength        integer    : overflow control strength (5)
 -oimprove         integer    : max overflow improvement (5)
 -odegrade         integer    : max overflow degradation (5)
 -chigh            integer    : high bitrate scenes degradation (0)
 -clow             integer    : low bitrate scenes improvement (0)
 -overhead         integer    : container frame overhead (0)
 -vbvsize          integer    : use vbv buffer size
 -vbvmax           integer    : vbv max bitrate
 -vbvpeak          integer    : vbv peak bitrate over 1 second
BFrames options:
 -max_bframes      integer    : max bframes (2)
 -bquant_ratio     integer    : bframe quantizer ratio (150)
 -bquant_offset    integer    : bframe quantizer offset (100)
Other options
 -noasm                       : do not use assembly optimized code (use)
 -turbo                       : use turbo presets for higher encoding speed (don't use)
 -quality          integer    : quality ([0..6]) (6)
 -vhqmode          integer    : level of R-D optimizations ([0..4]) (1)
 -bvhq                        : use R-D optimizations for B-frames (don't use)
 -metric           integer    : distortion metric for R-D opt (PSNR:0, PSNRHVSM:1) (0)
 -qpel                        : use quarter pixel ME (don't use)
 -gmc                         : use global motion compensation (don't use)
 -qtype            integer    : quantization type (H263:0, MPEG4:1) (0)
 -qmatrix          filename   : use custom MPEG4 quantization matrix
 -interlaced       [integer]  : interlaced encoding (BFF:1, TFF:2) (1)
 -nopacked                    : disable packed B-frames mode (enabled)
 -noclosed_gop                : disable closed GOP mode (enabled)
 -masking          [integer]  : HVS masking mode (None:0, Lumi:1, Variance:2) (0)
 -stats                       : print stats about encoded frames (don't print)
 -ssim             [integer]  : print ssim for every frame (accurate: 0 fast: 4) (2)
 -ssim_file        filename   : output the ssim stats into a file
 -psnrhvsm                    : print PSNRHVSM metric for every frame (don't print)
 -debug            integer    : activate xvidcore internal debugging output (don't activate)
 -vop_debug                   : print some info directly into encoded frames (don't print)
 -nochromame                  : disable chroma motion estimation (enabled)
 -notrellis                   : disable trellis quantization (enabled)
 -imin             integer    : minimum I Quantizer (1..31) (2)
 -imax             integer    : maximum I quantizer (1..31) (31)
 -bmin             integer    : minimum B Quantizer (1..31) (2)
 -bmax             integer    : maximum B quantizer (1..31) (31)
 -pmin             integer    : minimum P Quantizer (1..31) (2)
 -pmax             integer    : maximum P quantizer (1..31) (31)
 -drop             integer    : frame Drop Ratio (0..100) (0)
 -start            integer    : starting frame number (0)
 -threads          integer    : number of threads (auto)
 -slices           integer    : number of slices (1)
 -progress         [integer]  : show progress updates every n frames (10)
 -par       integer[:integer] : set Pixel Aspect Ratio (1)
                                1 = 1:1
                                2 = 12:11 (4:3 PAL)
                                3 = 10:11 (4:3 NTSC)
                                4 = 16:11 (16:9 PAL)
                                5 = 40:33 (16:9 NTSC)
                            other = custom (width:height)
 -help                        : print this help message
NB: You can define up to 8192 zones via both the -zones and the -z[qw] options as needed.
I assumed:
"I:\Hybrid\64bit\ffmpeg.exe" -y -loglevel fatal -i "F:\TestClips&Co\files\test.avi" -map 0:0 -an -sn -pix_fmt yuv420p -f rawvideo - | "I:\Hybrid\64bit\xvid_encraw.exe" -cq 3 -w 640 -h 352 -csp i420 -framerate 25 -o "E:\Temp\test.m4v"
should work, but it only gives me:
xvidcore build version: xvid-1.3.7
Bitstream version: 1.3.7
Detected CPU flags: ASM MMX MMXEXT SSE SSE2 SSE3 SSE41 TSC
Detected 16 cpus, using 16 threads.
   -1: key=0, time=      0, len=      -5 | type=I, quant=  0, len=       0
Tot: enctime(ms) =   0.00,               length(bytes) =       0
Avg: enctime(ms) =  -1.00, fps =-1000.00, length(bytes) =      -1
N frames:      1 frames, size =       0/      0
as output.
The ffmpeg decoding part works fine. (saving to a file instead of piping properly saves yuv data)
I tried '-csp yv12', which didn't help.
I tried adding '-type 0', which didn't help.
I tried adding '-i stdin' or '-i -' but those aborted with 'Error opening input file stdin' and 'Error opening input file -'.
=> Does anyone know how to use xvid_encraw with pipe input?
Cu Selur
Ps.: I know when doing no filtering and the input is avi, directly using xvid_encraw might work, but I'd like to use vspipe and ffmpeg to pipe content to xvid_encraw.
Old 6th October 2020, 10:27   #2  |  Link
ChaosKing
Try with -f yuv4mpegpipe instead of rawvideo.
Old 6th October 2020, 10:27   #3  |  Link
LigH
LigH's Avatar
@Selur:
I guess that xvid_encraw is unable to determine the number of frames of a pipe stream (because it cannot seek to the end of a file and possibly returns a size of 0 bytes), so you may have to add the number of frames explicitly as parameter...
@ChaosKing:
The sources of xvid_encraw don't look like Y4M header parsing is implemented. Even PGM header parsing appears in TODO's.
New German Gleitz board
Old 6th October 2020, 10:37   #4  |  Link
Selur
Selur's Avatar
@LigH: adding '-frames 429'
"I:\Hybrid\64bit\ffmpeg.exe" -y -loglevel fatal -i "F:\TestClips&Co\files\test.avi" -map 0:0 -an -sn -pix_fmt yuv420p -f rawvideo - | "I:\Hybrid\64bit\xvid_encraw.exe" -cq 3 -w 640 -h 352 -csp i420 -frames 429 -framerate 25 -o "E:\Temp\test.m4v"
doesn't help either. :/
@ChaosKing: yuv4mpegpipe doesn't work either and I agree with LigH doesn't seem like there's code to parse y4m headers.
Old 6th October 2020, 14:17   #5  |  Link
filler56789
SuperVirus
filler56789's Avatar
Ouch, that suxxx indeed
I have just run a fast encoding test... yes, xvid_encraw reads Avisynth files, but does not accept the output(s) from avs2yuv
Anyway, that's not so unexpected from devilopers who think "nobody will ever need more than 64 zones" and believe Cygwin still is relevant
filler56789 is offline   Reply With Quote
Old 6th October 2020, 14:54   #6  |  Link
LigH
LigH's Avatar
So, @Selur, your best chance is probably to use Xvid inside ffmpeg...
Old 6th October 2020, 15:04   #7  |  Link
Selur
Selur's Avatar
@LigH: last time I checked ffmpeg doesn't support vhq and some other options. (iirc mbd is similar to vhq) -> I'll check that again just to be sure
So atm. I'm stuck with mencoder for xvid encoding.
Comparing https://www.ffmpeg.org/ffmpeg-codecs.html#libxvid and http://www.mplayerhq.hu/DOCS/man/en/mplayer.1.txt mencoder clearly wins.
A few examples:
mencoder                         ffmpeg
vhq=<0-4>                      mbd=<simple,bits,rd>
qmin/qmin or I/P/B           qmin/qmax same for all (or just I ?)
quant_intra/inter_matrix   no custom matrix as far as I see
+ some more missing options in ffmpegs libxvid support.
=> It's a pain, but either I find a modified xvid_encraw or I'm stuck with mencoder.
Cu Selur
Old 6th October 2020, 16:06   #8  |  Link
Selur
Selur's Avatar
@LigH: since you got an environment setup where you can compile xvid, could you try to compile xvid_encraw with the source from squid_80 http://forum.mediacoderhq.com/viewto...714de0c57709d7 ?
That source seems to define stdin for Windows, but the binary in that thread doesn't seem to work with current xvidcore.dll and the link to the xvidcore.dll which it should work with doesn't work anymore. :/
squid_80 (http://members.optusnet.com.au/squid_80/) also has a 64bit xvid_encraw and a xvid64bit but sadly that doesn't seem to work either.
experimenting with the xvid64 and xvid_encraw64 from squid_80:
.. | "C:\Users\Selur\Desktop\xvid_test\xvid_encraw.exe" -o "E:\Temp\test.m4v"
gives:
xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003
Trying to retrieve width and height from input header
xvid [error]: Bad Framerate 0.000000 (25/1)
.. | "C:\Users\Selur\Desktop\xvid_test\xvid_encraw.exe" -w 640 -h 352 -o "E:\Temp\test.m4v"
gives:
.. | "C:\Users\Selur\Desktop\xvid_test\xvid_encraw.exe" -w 640 -h 352 -framerate 25 -o "E:\Temp\test.m4v"
gives:
xvid [warn]: Single pass defaulting to quant 4.00
xvid [info]: Input is 640 x 352, 25.000fps (25/1), starting from frame 0
xvid [info]: xvidcore build version: xvid-1.2.0-dev
xvid [info]: Bitstream version: 1.2.-127
xvid [info]: Detected CPU flags: ASM MMX MMXEXT SSE SSE2 TSC
xvid [info]: Detected 16 cpus, using 16 threads.
    3: key=0, time=      4, len=    3399 | type=I, quant=  4, len=   16093
this creates only one output frame.
same with:
.. | "C:\Users\Selur\Desktop\xvid_test\xvid_encraw.exe" -w 640 -h 352 -framerate 25 -frames 429 -type 0 -o "E:\Temp\test.m4v"
adding '-debug' doesn't work,...
... | "C:\Users\Selur\Desktop\xvid_test\xvid_encraw.exe" -w 640 -h 352 -framerate 25 -frames 2 -o "E:\Temp\test.m4v"
xvid [info]: Number of frames to encode: 2
    1: key=0, time=      2, len=       6 | type=I, quant=  4, len=   16093
   -1: key=0, time=      0, len=      -5 | type=P, quant=  4, len=       6
Tot: enctime(ms) =   4.00,               length(bytes) =   16099
Avg: enctime(ms) =   2.00, fps = 500.00, length(bytes) =    8049
I frames:      1 frames, size =   16093/  16093, quants =  4 / 4.00 /  4
N frames:      1 frames, size =       6/      6
outputs 2 frames, using '-frames X' with X > 2 any I only get 1 frame :/
Old 6th October 2020, 21:49   #9  |  Link
filler56789
SuperVirus
Hummm, I have tried some modifications on xvid_encraws's code, but they didn't work as expected :-/
According to squid80's mod, adding "include io.h ++ include fcntl.h" apparently is sufficient only if the compiler = MSVC :-/
Evidently I replaced "MSVC" with "_WIN32" so that the recipe could be used by MinGW, but the effectivel «trick» is less simple than I thought.
Old 7th October 2020, 10:30   #10  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
I've got something working here using this build within yuv4mpegpipe & stdin switches...
ffmpeg .... -f yuv4mpegpipe - | xvid -type 0 .... -i stdin -o output.m4v
Old 7th October 2020, 12:58   #11  |  Link
filler56789
SuperVirus
and
First, the good part
Now encraw.exe's -i stdin accepts the outputs from avs2yuv.
Secondly, the bad part :-/
encraw.exe swaps the chroma channels (U & V) when avs2yuv uses the -raw switch and does even worse things when avs2yuv doesn't use the -raw option.
My conclusion: now it should be clear that xvid_encraw is just an EXAMPLE application, not a production-model frontend. Therefore in my humble opinion trying to fix it is not worth the hassle :-/
By the way, and just for a comparison, the Theora fanboys were smarter for creating a frontend based on ffmpeg (ffmpeg2theora), instead of trying to reinvent the wheel.
Old 7th October 2020, 13:55   #12  |  Link
Selur
Selur's Avatar
output from:
"I:\Hybrid\64bit\ffmpeg.exe" -y -loglevel fatal -i "F:\TestClips&Co\files\test.avi" -map 0:0 -an -sn -pix_fmt yuv420p -f yuv4mpegpipe - | "C:\Users\Selur\Desktop\xvid-1.3.7\examples\xvid_encraw.exe" -cq 3 -i stdin -w 640 -h 352 -csp i420 -framerate 25 -o "E:\Temp\test.m4v"
looks fine here.
@filler5689: have you tried with '-csp i420'?
Cu Selur
Ps.: strange thing is that '-w 640 -h 352' is still required.
Old 7th October 2020, 14:45   #13  |  Link
filler56789
SuperVirus
You are right, with "-csp i420" the stupid EXE finally worked as expected.
As I always say, evil devilopers love to choose stupid default settings
Lazy (lack of) coding, granted
Old 7th October 2020, 16:02   #14  |  Link
Selur
Selur's Avatar
Okay, somwhere I mixed stuff up,
"I:\Hybrid\64bit\ffmpeg.exe" -y -loglevel fatal -i "F:\TestClips&Co\files\test.avi" -an -sn -pix_fmt yuv420p -f yuv4mpegpipe - | "C:\Users\Selur\Desktop\xvid-1.3.7\examples\xvid_encraw.exe" -type 0 -w 640 -h 352 -csp i420 -framerate 25 -frames 10 -i stdin -o "E:\Output\test.m4v"
doesn't work, but (using rawvideo):
"I:\Hybrid\64bit\ffmpeg.exe" -y -loglevel fatal -i "F:\TestClips&Co\files\test.avi" -an -sn -pix_fmt yuv420p -f rawvideo - | "C:\Users\Selur\Desktop\xvid-1.3.7\examples\xvid_encraw.exe" -type 0 -w 640 -h 352 -csp i420 -framerate 25 -frames 10 -i stdin -o "E:\Output\test.m4v"
thought I copy&pasted the command line before, but apparently I didn't.
Old 7th October 2020, 16:31   #15  |  Link
Selur
Selur's Avatar
Argh,... now that xvid_encraw works MP4Box fails me.
A simple:
MP4Box -add "E:\Temp\2020-10-07@17_16_39_1610_01.m4v" -tmp "E:\Temp" -new "E:\Output\2020-10-07@17_16_39_1610__02.mp4"
gives me:
[Importer] Error probing E:\Temp\2020-10-07@17_16_39_1610_01.m4v
Error importing E:\Temp\2020-10-07@17_16_39_1610_01.m4v: Filter not found for the desired type
-> I opened an issue for it in the gpac bug tracker (https://github.com/gpac/gpac/issues/1609).
Cu Selur
Old 7th October 2020, 16:43   #16  |  Link
filler56789
SuperVirus
FWIW,
MP4Box - GPAC version 0.8.0-rev1-gc1990d5c-master is what I've been using since "ages ago".
Evidently that happened because the GPAC guys became exceedingly-busy
https://sourceforge.net/p/gpac/discu...read/43881fa9/
Old 7th October 2020, 19:02   #17  |  Link
Selur
Selur's Avatar
Okay, muxing to mkv using mkvmerge (v51) doesn't work either,..
Seems like MPEG4 ASP raw streams are not supported by mkvmerge. (https://gitlab.com/mbunkus/mkvtoolnix/-/issues/270)
iirc xvid_encraw doesn't use opendml so file size is limited to 2GB which kind of kills .avi as output for me. :/
So to mux to mp4 or mkv one either needs a xvid_encraw version which supports mkv or one needs to use ffmpeg for muxing,.. :/
Old 8th October 2020, 07:26   #18  |  Link
LigH
LigH's Avatar
MeGUI needs this workaround too: xvid_encraw doesn't create OpenDML AVIs >2GB (and MKV support is marginal, if enabled at all), so it has to create raw MPEG-4 ASP, and then it can't mux it with the optimal tools. Somehow, xvid_encraw is really only a test tool, not a production application.
As already mentioned: It may not even have a YUV4MPEG parser. Hence it doesn't expect any header.
@Kurtnoise: Is your magic available as patch, or may it not even work with GCC?
Old 8th October 2020, 09:45   #19  |  Link
Kurtnoise
Kurtnoise's Avatar
here is the pach I did :
Index: xvidcore/examples/xvid_encraw.c
--- xvidcore/examples/xvid_encraw.c	(revision 2196)
+++ xvidcore/examples/xvid_encraw.c	(working copy)
@@ -38,6 +38,14 @@
  *  Use ./xvid_encraw -help for a list of options
+#ifdef _WIN32
+/* The following two defines must be located before the inclusion of any system header files. */
+#define WINVER       0x0500
+#define _WIN32_WINNT 0x0500
+#include <windows.h>
+#include <io.h>       /* _setmode() */
+#include <fcntl.h>    /* _O_BINARY */
+#endif
 #include <stdio.h>
 #include <stdlib.h>
@@ -350,6 +358,7 @@
 	double totalenctime = 0.;
 	float totalPSNR[3] = {0., 0., 0.};
+	FILE *in_file = stdin;
 	FILE *statsfile;
 	frame_stats_t framestats[7];
@@ -991,6 +1000,12 @@
 		  if (avi_in_stream) AVIStreamRelease(avi_in_stream);
 		  AVIFileExit();
+	  else if (ARG_INPUTFILE == NULL || strcmp(ARG_INPUTFILE, "stdin") == 0) {
+#ifdef _WIN32
+    _setmode(_fileno(stdin), _O_BINARY);
+#endif
+		in_file = stdin;
       else
 #endif
Yes it works w/ gcc.
Sources including this patch are available in the package linked previously...
Old 8th October 2020, 10:02   #20  |  Link
LigH
LigH's Avatar
I'll suggest this to media-autobuild suite, including their previously applied sed patch for 8192 zones max.
