Old 16th March 2020, 03:49   #1  |  Link
abd
xvid_encraw 1.3.7 64bit build for windows 64bit
my xvid_encraw 1.3.7 64bit build for windows 64bit
http://www.mediafire.com/file/o30084....3.7_64bit.zip
https://www.dropbox.com/s/9vq1pji05e...64bit.zip?dl=0
abd is offline   Reply With Quote
Old 5th October 2020, 11:20   #2  |  Link
Selur
Selur's Avatar
using:
"I:\Hybrid\64bit\ffmpeg.exe" -y -loglevel fatal -i "F:\TestClips&Co\files\test.avi" -map 0:0 -an -sn -pix_fmt yuv420p -f rawvideo - | "c:\Users\Selur\Desktop\xvid_encraw 1.3.7 64bit\xvid_encraw.exe" -cq 3 -w 640 -h 352 -csp i420 -framerate 25 -o "E:\Temp\2020-10-05@10_53_45_5810_01.m4v"
I only get:
xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert
xvidcore build version: xvid-1.3.7
Bitstream version: 1.3.7
Detected CPU flags: ASM MMX MMXEXT SSE SSE2 SSE3 SSE41 TSC
Detected 16 cpus, using 16 threads.
   -1: key=0, time=      0, len=      -5 | type=I, quant=  0, len=       0
Tot: enctime(ms) =   0.00,               length(bytes) =       0
Avg: enctime(ms) =  -1.00, fps =-1000.00, length(bytes) =      -1
N frames:      1 frames, size =       0/      0
-> does this work for anyone with pipe input?
