Old 28th October 2024, 06:49   #21  |  Link
jay123210599
Originally Posted by _Al_ View Post
If you do what was just confirmed in VirtualDub2, then strictly no.
But it is important for a vapoursynth previewers, because they have to present video on screen, so there has to be conversion to rgb, and you need at least matrix to convert to rgb. If not provided, matrix is defaulted/guessed.
Also if not set, vapoursynth will object if changing formats to rgb within script.
It might be a good habit to set those props like that if you are sure those values are proper, even if VirtualDub2 ignores them.
So what do I need to do in order for VirtualDub2 to get the right colors from my videos/scripts?
jay123210599 is offline   Reply With Quote
Old 28th October 2024, 23:25   #22  |  Link
_Al_
VirtualDub2 does not read those props, so does not matter what you set in vapoursynth, it will not read them. You have to set it yourself, as you did.
_Al_ is offline   Reply With Quote
Old 29th October 2024, 22:58   #23  |  Link
jay123210599
In the settings there?
colorspace, frame accurate, scripts, vapoursynth editor
