Old 16th June 2011, 00:50   #1  |  Link
Rusakov
1001 Frame Ceiling
I seem to be having trouble with AVISynth and its frame counting. I tested a script that would keep the first 2000 frames of a roughly 4944 frame video. But AVISynth only seems to be counting the first 1001 frames and thus only cuts the video to that length when using trim.
The script:
ImageSource("C:\Users\Rusakov\Videos\titan.png")
AudioDub(WavSource("C:\Users\Rusakov\Music\avssound2.wav"))
Trim(0, 2000)
Info()
The end result: http://www.youtube.com/watch?v=zYJ58...el_video_title
Am I doing something wrong or is this a known bug?
Rusakov is offline   Reply With Quote
Old 16th June 2011, 00:57   #2  |  Link
sneaker_ger
end = 1000 is the standard settings for ImageSource. If you want more frames, raise end.
Old 16th June 2011, 01:02   #3  |  Link
Rusakov
Thanks, it worked like a charm!
frame, trim
