Old 6th February 2009, 18:55   #1  |  Link
trueimage
Ripping BD to HDD with AnyDVD HD
Which options should I set?
just leave as default?
This is for use with BD-Rebuilder or straight 1:1 backup.
trueimage is offline   Reply With Quote
Old 6th February 2009, 19:50   #2  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
It is safe to leave it at defaults. If you want to enable those other options you can, but AnyDVD HD will work right "out-of-the-box" so to speak.
Old 6th February 2009, 19:51   #3  |  Link
trueimage
Do I want to disable BD-Live on a backup?
What about region, should I remove itor not care?
Why shouldn't I remove these things?
Old 6th February 2009, 21:57   #4  |  Link
Adub
Adub's Avatar
The reason why you wouldn't want to remove these things is because you wanted to keep some of the advanced functionality such as BD-Live.
However, if you don't use 'em then yes, remove BD-Live.
Prohibited User Operations are never fun, so you can go ahead and remove those too if you want.
You can also go ahead and remove the region code support if you are going to be playing this on different players, possibly over sea's. If you aren't then it doesn't matter.
If you want to check the "Remove adverts and trailers" then you can, however some people like to keep trailers and so on.
Note: Since you are going to be using this with BD-Rebuilder anyways, if you are going to do a main movie only backup, then there is no real point either way as the trailers and adverts would be removed anyways.
anydvd, blu-ray
