Old 21st September 2008, 06:18   #1  |  Link
flebber
Practising Schemer
Matroska - Cut, Trim, Split
I have just realised I don't know and can't find the answer to a simple problem. After I have converted my files to matroska, how can I cut, trim or split these mkv files ?
I can only find a link in goole search for a program called riverpasthttp://3d2f.com/programs/7-834-river...download.shtml
What is the best way or program to use to trim mkv files?
flebber is offline   Reply With Quote
Old 21st September 2008, 12:29   #2  |  Link
littleD
littleD's Avatar
http://forum.doom9.org/showthread.php?t=120648&page=28
The best i used for mkv's
littleD is offline   Reply With Quote
Old 24th September 2008, 23:13   #3  |  Link
joseph5
There's also AviDemux.
joseph5 is offline   Reply With Quote
Old 25th September 2008, 12:54   #4  |  Link
flebber
Practising Schemer
Avidemux warns about B-frames when opening my x264 mkv's. It opens in safe mode. Its distinction between frames is poor for me and makes it nearly impossible to use. Maybe I am using avidemux wrong, I am using the latest build from razorbyte.http://avidemux.razorbyte.com.au/
littleD you were referring to mkvtoolnix with your link? I already have that but couldn't instantly figure it out so searched for other options. Will have to give it another go and try a little harder to find the cut and trim options this time.
cut, matroska.crop, mkv, trim
