19th July 2019, 10:40 | #23 | Link | |
It should be used with precaution. Speed gain is marginal (if any, because next filter would fall back to C version internally if frame is not well aligned), scripts should do the Crop with "align"=true. This parameter is kept in Avisynth+ only for compatibility reasons. |
19th July 2019, 12:50 | #25 | Link |
Tried the first example above with colorbars YV12, no problems with avs+, avs 2.60, avs v2.61alpha, avs Neo.
EDIT: Same with 2nd example script.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 19th July 2019 at 12:54. |
19th July 2019, 12:57 | #27 | Link |
Later, gotta leave right now.
19th July 2019, 12:59 | #28 | Link | |
What does "crash" means? Exit? Error message? When fed into Avsmeter it would show the Exception text whether it is C0000005 or illegal instruction, whatever. |
19th July 2019, 14:20 | #29 | Link |
Same with Align=False
What player ? Also, Vdub2 would show error message properly (usually).
19th July 2019, 15:33 | #30 | Link |
SSE4.1 is used but hello_hello's processor does not support it.
Tried Intel SDE emulator with --mrm option I'm using this tool to emulate either pre-historic or too modern (= not available for me, e.g. AVX512) instruction sets. This --mrm emulates Merom architecture. Code:
AVSMeter 2.9.0 (x86) - Copyright (c) 2012-2019, Groucho2004 AviSynth 2.60, build:Aug 28 2012 [18:17:07] (2.6.0.3) TID 16 SDE-ERROR: Executed instruction not valid for specified chip (CORE2): 0x16512cb7: pextrb byte ptr [ecx], xmm0, 0x0 Image: C:\Program Files (x86)\AviSynth+\plugins\FastBlur.dll+0x2cb7 Instruction bytes are: 66 0f 3a 14 01 00 TID 20 SDE-ERROR: Executed instruction not valid for specified chip (CORE2): 0x16512cb7: pextrb byte ptr [ecx], xmm0, 0x0 Image: C:\Program Files (x86)\AviSynth+\plugins\FastBlur.dll+0x2cb7 Instruction bytes are: 66 0f 3a 14 01 00 TID 19 SDE-ERROR: Executed instruction not valid for specified chip (CORE2): 0x16512cb7: pextrb byte ptr [ecx], xmm0, 0x0 Image: C:\ProTID 23 SDE-ERROR: Executed ig |
19th July 2019, 16:48 | #31 | Link |
Formerly davidh*****
That makes sense. Pixels are written out in groups of four using older SSE instructions, but any stragglers get dealt with using newer instructions. For YV12 that means you have to be mod8 so that the chroma channels are mod4.
If you pad the video to the right by repeating the final column of pixels, the FastBlur result (after cropping again) should be identical. Last edited by wonkey_monkey; 19th July 2019 at 16:51. |
19th July 2019, 17:53 | #32 | Link | ||
Source available yet so as I can recompile, I am unlikely to use if not OK on my other machines [well once in a blue moon I might use it on No1 m/c].
(one a P4 with hyperthreading, no SSE4.1 , I'm pretty sure. My core2 Q6600 has SSE4 I think but not SSE4.1, cant check at moment, I knocked it off a table a coupla days back and CPU + heatsink is currently detached from Motherboard). That Emulator sounds pretty nifty. EDIT: From The emulator FAQ: Quote:
EDIT: Looks like Q6600 only has SSE3/SSSE3, no SSE4.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 20th July 2019 at 08:16. |
20th July 2019, 07:58 | #34 | Link |
A rather large conclusion to jump to based on Pinterf comment.
20th July 2019, 14:45 | #35 | Link |
Here's what AVS meter shows when it crashes. Usually the program opening the script simply vanishes, so that's as close as I get to an error message. Is there a way to dig out more info?
20th July 2019, 16:12 | #36 | Link |
Easiest way to see invisible error message is to right click on avs and Open with VDub2.
Here result of loading empty avs file info VD2 (I was kinda curious what it would produce):- MPC-HC just gives a "Scripts return was not a video clip (is the undefined value)".
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 20th July 2019 at 16:15. |
20th July 2019, 21:30 | #37 | Link | ||
It looks like Pinterf was correct.
For the function I'm using FastBlur for (blurring borders), I originally did something like this: Quote:
25th December 2019, 01:40 | #38 | Link |
Updated to fix a rounding/accumulation bug with floating point clips.
http://horman.net/avisynth/download/FastBlur.zip |
30th December 2019, 20:11 | #39 | Link |
How does this compare with `Dither_box_filter16()` when using iterations=1
and gamma=false? I tried matching the output between the two but I couldn't get the equivalent radius from one to the other. And since I'm on it, would you be willing to add the usual `y, u, v` parameters from MaskTools/DitherTools, for convenience? |
31st December 2019, 12:07 | #40 | Link |
FastBlur(9, iterations = 1, gamma = false) is pretty close. In general multiplying by 9/16 seems to work for other radiuses.
There seems to be a border bug in the version I recently uploaded which I'll sort out later. EDT: never mind, there was no bug, it was a dithertools misunderstanding. Copying all the functionality of y/u/v seems more trouble than its worth at the moment. Last edited by wonkey_monkey; 31st December 2019 at 18:30. |
