13th July 2021, 20:39 | #30721 | Link | ||
As I mentioned before, I can run my Lossless discs I want to convert through other programs first (which I know is not recommended) but it works just fine and they play perfectly in MPC-HC and/or Kodi. So I'll just take the extra step to convert them first before processing in BDRB until the gremlins decide to stop fu**ing with me. Thanks for the replies... |
14th July 2021, 05:54 | #30722 | Link |
The relevant mediainfo I already posted.
I'm still one version behind, but that shouldn't matter ini and log below ... if it helps Code:
[Options] VERSION=0.61.0.21 ENCODER=1 MODE=0 ENCODE_QUALITY=3 ONEPASS_ENCODING=1 AUTO_QUALITY=0 TARGET_SIZE=23500 NVENC_CAPABLE=1 AUDIO_TO_KEEP=deu;eng;ger; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AUDIO_DRC=0 DECODER=0 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=1 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=1 PGSTOSRT=1 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=50000 AUTO_BURN=2 MOVIEONLY_TYPE=11 ALTCRF=18 ALT_TARGET=1024 ALT_CRF_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=0 [Paths] SOURCE_PATH=V:\FULLDISC\SONIC_THE_HEDGEHOG\ WORKING_PATH=U:\BD-OUTPUT\ SupTitlePath=U:\BD_Rebuilder\Tools\SupTitle\x86\SupTitle.dll Code:
[07.10.21] BD Rebuilder v0.61.21 [00:17:01] Source: SONIC_THE_HEDGEHOG - Input BD size: 37,42 GB - Approximate total content: [02:35:52.424] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), CQM - Decoding/Frame serving: NVENCC - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [00:17:04] PHASE ONE, Encoding - [00:17:04] Processing: VID_00351 (1 of 15) - [00:17:04] Extracting A/V streams [VID_00351] - [00:22:14] Reencoding video [VID_00351] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 142.252 frames - [00:22:15] Performing CQM Prediction... - Analyzing 5,00 15,70 15,30 [15,30] - [00:23:36] Encoding using constant quality mode. - [00:38:54] Video Encode complete - [00:38:54] Processing audio tracks - Track 4352 (eng): Keeping original core audio - Track 4354 (deu): Keeping original audio - [00:38:58] Multiplexing M2TS - [00:39:43] Processing: VID_00589 (2 of 15) - [00:39:43] Extracting A/V streams [VID_00589] - [00:39:53] Reencoding video [VID_00589] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.592 frames - [00:39:54] Performing CQM Prediction... - Analyzing 5,00 18,85 21,95 [22,02] - [00:40:06] Encoding using constant quality mode. - [00:40:25] Video Encode complete - [00:40:25] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (deu): Keeping original audio - [00:40:25] Multiplexing M2TS - [00:40:30] Processing: VID_00590 (3 of 15) - [00:40:30] Extracting A/V streams [VID_00590] - [00:40:40] Reencoding video [VID_00590] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3.210 frames - [00:40:41] Performing CQM Prediction... - Analyzing 5,00 18,90 19,80 [19,80] - [00:40:52] Encoding using constant quality mode. - [00:41:13] Video Encode complete - [00:41:13] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:41:13] Multiplexing M2TS - [00:41:17] Processing: VID_00591 (4 of 15) - [00:41:17] Extracting A/V streams [VID_00591] - [00:41:30] Reencoding video [VID_00591] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 5.359 frames - [00:41:31] Performing CQM Prediction... - Analyzing 5,00 19,20 20,70 [20,80] - [00:41:42] Encoding using constant quality mode. - [00:42:34] Video Encode complete - [00:42:34] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:42:34] Multiplexing M2TS - [00:42:39] Processing: VID_00592 (5 of 15) - [00:42:39] Extracting A/V streams [VID_00592] - [00:42:53] Reencoding video [VID_00592] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 5.768 frames - [00:42:54] Performing CQM Prediction... - Analyzing 5,00 18,75 [18,75] - [00:43:01] Encoding using constant quality mode. [00:43:11] - Aborted by user request ---------------------- Code:
[07.10.21] BD Rebuilder v0.61.21 [10:24:03] Source: SONIC_THE_HEDGEHOG - Input BD size: 37,42 GB - Approximate total content: [02:35:52.424] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), CQM - Decoding/Frame serving: NVENCC - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [10:24:06] PHASE ONE, Encoding - [10:24:06] Processing: VID_00592 (5 of 15) - [10:24:06] Reencoding video [VID_00592] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 5.768 frames - [10:24:06] Performing CQM Prediction... - Analyzing 5,00 18,75 [18,75] - [10:24:15] Encoding using constant quality mode. - [10:24:56] Video Encode complete - [10:24:56] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:24:56] Multiplexing M2TS - [10:25:01] Processing: VID_00593 (6 of 15) - [10:25:01] Extracting A/V streams [VID_00593] - [10:25:15] Reencoding video [VID_00593] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 5.820 frames - [10:25:16] Performing CQM Prediction... - Analyzing 5,00 17,95 18,55 [18,55] - [10:25:27] Encoding using constant quality mode. - [10:26:06] Video Encode complete - [10:26:06] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:26:06] Multiplexing M2TS - [10:26:11] Processing: VID_00594 (7 of 15) - [10:26:11] Extracting A/V streams [VID_00594] - [10:26:30] Reencoding video [VID_00594] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 9.152 frames - [10:26:31] Performing CQM Prediction... - Analyzing 5,00 18,50 19,50 [19,50] - [10:26:44] Encoding using constant quality mode. - [10:27:49] Video Encode complete - [10:27:49] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:27:49] Multiplexing M2TS - [10:27:55] Processing: VID_00595 (8 of 15) - [10:27:55] Extracting A/V streams [VID_00595] - [10:28:08] Reencoding video [VID_00595] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 4.972 frames - [10:28:08] Performing CQM Prediction... - Analyzing 5,00 18,90 20,45 [20,45] - [10:28:20] Encoding using constant quality mode. - [10:28:54] Video Encode complete - [10:28:54] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:28:54] Multiplexing M2TS - [10:28:59] Processing: VID_00596 (9 of 15) - [10:28:59] Extracting A/V streams [VID_00596] - [10:29:06] Reencoding video [VID_00596] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 680 frames - [10:29:06] Performing CQM Prediction... - Analyzing 5,00 19,20 19,95 [19,95] - [10:29:18] Encoding using constant quality mode. - [10:29:24] Video Encode complete - [10:29:24] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:29:24] Multiplexing M2TS - [10:29:28] Processing: VID_00597 (10 of 15) - [10:29:28] Extracting A/V streams [VID_00597] - [10:29:40] Reencoding video [VID_00597] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 5.095 frames - [10:29:40] Performing CQM Prediction... - Analyzing 5,00 18,55 19,70 [19,70] - [10:29:52] Encoding using constant quality mode. - [10:30:29] Video Encode complete - [10:30:29] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:30:29] Multiplexing M2TS - [10:30:34] Processing: VID_00598 (11 of 15) - [10:30:34] Extracting A/V streams [VID_00598] - [10:30:45] Reencoding video [VID_00598] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3.575 frames - [10:30:45] Performing CQM Prediction... - Analyzing 5,00 18,05 18,40 [18,42] - [10:30:56] Encoding using constant quality mode. - [10:31:21] Video Encode complete - [10:31:21] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:31:21] Multiplexing M2TS - [10:31:25] Processing: VID_00599 (12 of 15) - [10:31:25] Extracting A/V streams [VID_00599] - [10:31:39] Reencoding video [VID_00599] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 5.426 frames - [10:31:39] Performing CQM Prediction... - Analyzing 5,00 18,70 22,10 22,75 [22,75] - [10:31:55] Encoding using constant quality mode. - [10:32:35] Video Encode complete - [10:32:35] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:32:35] Multiplexing M2TS - [10:32:40] Processing: VID_00600 (13 of 15) - [10:32:40] Extracting A/V streams [VID_00600] - [10:32:53] Reencoding video [VID_00600] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.505 frames - [10:32:53] Performing CQM Prediction... - Analyzing 5,00 18,15 18,75 [18,75] - [10:33:06] Encoding using constant quality mode. - [10:33:26] Video Encode complete - [10:33:26] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:33:26] Multiplexing M2TS - [10:33:31] Processing: VID_00601 (14 of 15) - [10:33:31] Extracting A/V streams [VID_00601] - [10:33:38] Reencoding video [VID_00601] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1.844 frames - [10:33:39] Performing CQM Prediction... - Analyzing 5,00 18,95 20,00 [20,00] - [10:33:51] Encoding using constant quality mode. - [10:34:10] Video Encode complete - [10:34:10] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:34:10] Multiplexing M2TS - [10:34:15] Processing: VID_00602 (15 of 15) - [10:34:15] Extracting A/V streams [VID_00602] - [10:34:19] Reencoding video [VID_00602] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 144 frames - Bitrate: 2.187 Kbs - [10:34:20] Reencoding: VID_00602, Pass 1 of 2 - [10:34:23] Reencoding: VID_00602, Pass 2 of 2 - [10:34:23] Video Encode complete - [10:34:23] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:34:23] Multiplexing M2TS [10:34:28]PHASE ONE complete [10:34:28]PHASE TWO - Rebuild Started - [10:34:28] Rebuilding BD file Structure [10:34:59] - Encode and Rebuild complete [10:34:59] Writing BD structure to ISO file - ImgBurn completed successfully - SONIC_THE_HEDGEHOG folder removed. [10:55:00] JOB: SONIC_THE_HEDGEHOG finished. |
14th July 2021, 06:59 | #30723 | Link |
[QUOTE=cartman0208;1947519]The relevant mediainfo I already posted.
---------------------- [07/06/21] BD Rebuilder v0.61.22 [09:51:52] Source: THE_GOOD_THE_BAD_AND_THE_UGLY_00800 - Input BD size: 39.98 GB - Approximate total content: [02:58:36.622] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), 1-Pass VBR - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [09:51:52] PHASE ONE, Encoding - [09:51:52] Processing: VID_01559 (1 of 1) - [09:51:52] Extracting A/V streams [VID_01559] - [10:00:01] Reencoding video [VID_01559] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 256,942 frames - Bitrate: 15,731 Kbs - [10:00:01] Reencoding: VID_01559, Pass 1 of 1 - [10:22:50] Video Encode complete - [10:22:50] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... [10:23:09]PHASE ONE complete [10:23:09]PHASE TWO - Rebuild Started - [10:23:09] Rebuilding BD file Structure [10:23:43] - Encode and Rebuild complete [10:23:43] JOB: THE_GOOD_THE_BAD_AND_THE_UGLY finished. [07/06/21] Checking System Settings - BD-Rebuilder v0.61.22 - Windows Version: 6.2 [9200] - Working Path Free Space: 157.42GB - AVISYNTH Version: 2.6.0.6, Ok - LAVFILTERS: Ok - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [07/06/21] Systems Settings Check complete Last edited by spotswood; 14th July 2021 at 07:04. |
14th July 2021, 13:22 | #30726 | Link | |
14th July 2021, 21:10 | #30727 | Link | ||
Here's my pre-encode MediaInfo of my GB&U disc: Code:
General Complete name : N:\\\BDMV\PLAYLIST\00800.mpls Format : Blu-ray Playlist File size : 570 Bytes Duration : 2 h 58 min Overall bit rate mode : Variable Overall bit rate : 0 b/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference fra : 4 frames Codec ID : 27 Duration : 2 h 58 min Bit rate mode : Variable Maximum bit rate : 35.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive format_identifier : HDMV Source : 01559.m2ts Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Muxing mode : Stream extension Codec ID : 134 Duration : 2 h 58 min Bit rate mode : Variable Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossless Language : English Source : 01559.m2ts Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 2 h 58 min Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 1 channel Channel layout : C Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 245 MiB Language : English Service kind : Complete Main bsid : 6 Dialog Normalization : -31 Dialog Normalization : -31 dB compr : 5.74 compr : 5.74 dB dynrng : 5.60 dynrng : 5.60 dB acmod : 1 lfeon : 0 dialnorm_Average : -31 dialnorm_Average : -31 dB dialnorm_Minimum : -31 dialnorm_Minimum : -31 dB dialnorm_Maximum : -31 dialnorm_Maximum : -31 dB dialnorm_Count : 800 compr_Average : 1.76 compr_Average : 1.76 dB compr_Minimum : -8.52 compr_Minimum : -8.52 dB compr_Maximum : 6.02 compr_Maximum : 6.02 dB compr_Count : 761 dynrng_Average : 2.24 dynrng_Average : 2.24 dB dynrng_Minimum : -8.34 dynrng_Minimum : -8.34 dB dynrng_Maximum : 5.88 dynrng_Maximum : 5.88 dB dynrng_Count : 792 format_identifier : AC-3 Source : 01559.m2ts Code:
General Complete name : C:\Users\eM-SSD\Videos\1080p_HEVC\THE_GOOD_THE_BAD_AND_THE_UGLY\\BDMV\PLAYLIST\00000.mpls Format : Blu-ray Playlist File size : 694 Bytes Duration : 2 h 58 min Overall bit rate : 1 b/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4.1@High Codec ID : 36 Duration : 2 h 58 min Bit rate : 15.2 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.307 Stream size : 19.0 GiB Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 format_identifier : HDMV Source : 00000.m2ts / 00000.m2ts Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 2 h 58 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 1 channel Channel layout : C Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 818 MiB Language : English Service kind : Complete Main bsid : 8 Dialog Normalization : -31 Dialog Normalization : -31 dB acmod : 1 lfeon : 0 dialnorm_Average : -31 dialnorm_Average : -31 dB dialnorm_Minimum : -31 dialnorm_Minimum : -31 dB dialnorm_Maximum : -31 dialnorm_Maximum : -31 dB dialnorm_Count : 1 format_identifier : AC-3 SamplingCount_Source : General_Duration Duration_Source : General_Duration Source : 00000.m2ts / 00000.m2ts Last edited by spotswood; 14th July 2021 at 21:22. |
14th July 2021, 22:46 | #30728 | Link |
Done.
Luckily I had a small enough Bluray still on disk (despite Bruce Willis a terrible movie) so I didn't have to reencode the video. Log: Code:
---------------------- [07.14.21] BD Rebuilder v0.61.21 [23:33:24] Source: 10_MINUTES_GONE - Input BD size: 21,50 GB - Approximate total content: [01:56:50.473] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), CQM - Decoding/Frame serving: NVENCC - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [23:33:32] PHASE ONE, Encoding - [23:33:32] Processing: VID_00003 (1 of 3) - [23:33:32] Extracting A/V streams [VID_00003] - [23:37:04] Reencoding video [VID_00003] - [23:37:05] Keeping original video (no reencode) - [23:37:05] Processing audio tracks - Track 4352 (deu): Reencoding audio to AC3... - Track 4353 (eng): Reencoding audio to AC3... - [23:40:27] Multiplexing M2TS - [23:41:31] Processing: VID_00004 (2 of 3) - [23:41:31] Extracting A/V streams [VID_00004] - [23:41:37] Reencoding video [VID_00004] - [23:41:37] Keeping original video (no reencode) - [23:41:37] Processing audio tracks - Track 4352 (deu): Reencoding audio to AC3... - [23:41:37] Multiplexing M2TS - [23:41:42] Processing: VID_00012 (3 of 3) - [23:41:42] Extracting A/V streams [VID_00012] - [23:42:00] Reencoding video [VID_00012] - [23:42:00] Keeping original video (no reencode) - [23:42:00] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [23:42:01] Multiplexing M2TS [23:42:07]PHASE ONE complete [23:42:07]PHASE TWO - Rebuild Started - [23:42:07] Rebuilding BD file Structure [23:42:49] - Encode and Rebuild complete [23:42:49] Writing BD structure to ISO file - ImgBurn completed successfully - 10_MINUTES_GONE folder removed. [23:44:08] JOB: 10_MINUTES_GONE finished. Code:
General ID : 0 (0x0) Complete name : V:\FullDisc\10 MINUTES GONE\BDMV\STREAM\00003.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 18.0 GiB Duration : 1 h 36 min Overall bit rate mode : Variable Overall bit rate : 26.7 Mb/s Maximum Overall bit rate : 48.0 Mb/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 2 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 2 frames Codec ID : 27 Duration : 1 h 36 min Bit rate mode : Variable Maximum bit rate : 30.2 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Muxing mode : Stream extension Codec ID : 134 Duration : 1 h 36 min Bit rate mode : Variable Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Muxing mode : Stream extension Codec ID : 134 Duration : 1 h 36 min Bit rate mode : Variable Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless Text #1 ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Text #2 ID : 4609 (0x1201) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Code:
General ID : 1 (0x1) Complete name : U:\BD-Output\10_MINUTES_GONE\BDMV\STREAM\00003.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 16.5 GiB Duration : 1 h 36 min Overall bit rate mode : Variable Overall bit rate : 24.6 Mb/s Maximum Overall bit rate : 35.5 Mb/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 2 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 2 frames Codec ID : 27 Duration : 1 h 36 min Bit rate mode : Variable Bit rate : 22.3 Mb/s Maximum bit rate : 30.2 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.449 Stream size : 15.0 GiB (91%) Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 1 h 36 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 441 MiB (3%) Service kind : Complete Main Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 1 h 36 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 441 MiB (3%) Service kind : Complete Main Text #1 ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Text #2 ID : 4609 (0x1201) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 |
16th July 2021, 00:14 | #30730 | Link |
@spotswood
It looks like there are two audio channels on the original. The second one says: Code:
Bit rate : 192 kb/s Channel(s) : 1 channel Channel layout : C Sampling rate : 48.0 kHz |
16th July 2021, 05:05 | #30731 | Link | |
Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 2 h 58 min Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 1 channel Channel layout : C ...and post encode: Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 2 h 58 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 1 channel Channel layout : C BDRB is definitely re-encoding the DTS-MA track since it has the same ID #4352. The original Mono track has ID #4353 and is not included since I de-selected it. I did Atomic Blonde which doesn't have a Mono track that I'll post below... |
16th July 2021, 05:25 | #30732 | Link |
OK, here's Atomic Blonde. I would normally keep this DTS-X 7.1 track, but am using this as an example:
MediaInfo Pre-Encode: Code:
General Complete name : N:\\\BDMV\PLAYLIST\00800.mpls Format : Blu-ray Playlist File size : 578 Bytes Duration : 1 h 54 min Overall bit rate mode : Variable Overall bit rate : 1 b/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference fra : 4 frames Codec ID : 27 Duration : 1 h 54 min Bit rate mode : Variable Maximum bit rate : 34.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive format_identifier : HDMV Source : 00246.m2ts Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS XLL X Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Muxing mode : Stream extension Codec ID : 134 Duration : 1 h 54 min Bit rate mode : Variable Channel(s) : Object Based Channel layout : Object Based Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Language : English Source : 00246.m2ts Code:
[Status] LABEL=ATOMIC_BLONDE VERSION=v0.61.22 SOURCE_SIZE=35696302080 SOURCE_VIDEO_SIZE=35696302080 TARGET_SIZE=24641536000 REDUCTION=.690310608218609 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=4 DGDECNV=-1 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 UHD_V3_MODE=-1 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00246] AUDIO=1000 PGS=10000 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=24641536000 RATE=25786 NSIZE=0 FLINK=0 MLINK=0 Code:
---------------------- [07/14/21] BD Rebuilder v0.61.22 [11:27:24] Source: ATOMIC_BLONDE_00800 - Input BD size: 33.24 GB - Approximate total content: [01:54:44.294] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), 1-Pass VBR - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [11:27:24] PHASE ONE, Encoding - [11:27:24] Processing: VID_00246 (1 of 1) - [11:27:24] Extracting A/V streams [VID_00246] - [11:32:37] Reencoding video [VID_00246] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 165,058 frames - Bitrate: 25,786 Kbs - [11:32:37] Reencoding: VID_00246, Pass 1 of 1 - [11:48:09] Video Encode complete - [11:48:09] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... [11:48:14]PHASE ONE complete [11:48:14]PHASE TWO - Rebuild Started - [11:48:14] Rebuilding BD file Structure [11:48:52] - Encode and Rebuild complete - WORKFILES folder removed. [11:48:52] JOB: ATOMIC_BLONDE finished. Code:
General Complete name : C:\Users\eM-SSD\Videos\1080p_HEVC\ATOMIC_BLONDE\\BDMV\PLAYLIST\00000.mpls Format : Blu-ray Playlist File size : 526 Bytes Duration : 1 h 54 min Overall bit rate : 1 b/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4.1@High Codec ID : 36 Duration : 1 h 54 min Bit rate : 25.5 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.512 Stream size : 20.4 GiB Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 format_identifier : HDMV Source : 00000.m2ts / 00000.m2ts Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 1 h 54 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 1 channel Channel layout : C Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 525 MiB Language : English Service kind : Complete Main bsid : 8 Dialog Normalization : -31 Dialog Normalization : -31 dB acmod : 1 lfeon : 0 dialnorm_Average : -31 dialnorm_Average : -31 dB dialnorm_Minimum : -31 dialnorm_Minimum : -31 dB dialnorm_Maximum : -31 dialnorm_Maximum : -31 dB dialnorm_Count : 1 format_identifier : AC-3 SamplingCount_Source : General_Duration Duration_Source : General_Duration Source : 00000.m2ts / 00000.m2ts Last edited by spotswood; 16th July 2021 at 05:29. |
16th July 2021, 20:59 | #30734 | Link |
Here ya go...
[Options] VERSION=0.61.0.22 ENCODER=1 MODE=3 ENCODE_QUALITY=3 ONEPASS_ENCODING=2 AUTO_QUALITY=0 NVENC_CAPABLE=1 TARGET_SIZE=23500 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=1 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AUDIO_DRC=0 DECODER=3 AVCHD=0 REMOVE_WORKFILES=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=1 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=1 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=20480 MOVIE_ONLY_LOOP=0 ENABLE_TEST=1 ENABLE_BLANKING=1 BLANK_THRESHOLD=1800 MULTIPROCESS=1 BEEP_SOUNDFILE=C:\Windows\Media\tada.wav UHD_CONVERT_ENABLE=1 UHD_ALL_MODE=1 MOVIEONLY_TYPE=0 UHD_V3_MODE=1 FORCE_NOENCODE=0 [Paths] DGIndexNV=C:\Users\eM-SSD\Downloads\dgdecnv2053v228\x32 Binaries\DGIndexNV.exe DGDecNV=C:\Users\eM-SSD\Downloads\dgdecnv2053v228\x32 Binaries\DGDecodeNV.dll SOURCE_PATH=N:\ WORKING_PATH=C:\USERS\EM-SSD\VIDEOS\1080P_HEVC\ |
17th July 2021, 19:58 | #30736 | Link | |
Audio Format : AC-3 Format/Info : Audio Coding 3 Duration : 3 h 6 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 854 MiB (100%) Service kind : Complete Main |
17th July 2021, 20:33 | #30737 | Link |
Just did another one. Input:
Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : TrueHD / AC-3 Format profile : TrueHD+Atmos / TrueHD / AC-3 Muxing mode : Stream extension Codec ID : 131 Bit rate mode : Variable / Constant Bit rate : 640 kb/s Maximum bit rate : 9 858 kb/s Channel(s) : Object Based / 8 channels / 6 channels Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : / 48.0 kHz / 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Delay relative to video : -1 ms Service kind : Complete Main Code:
Audio Format : AC-3 Format/Info : Audio Coding 3 Duration : 2 h 2 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 559 MiB (100%) Service kind : Complete Main AUDIO_AMPLIFY=1.0 to the INI file. This forces BD-RB to reencode (to a volume of 1.0x the original) instead of keeping the 640Kbs core audio. Code:
- [13:20:30] Processing: VID_00003 (1 of 1) - [13:20:31] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... Now I'm going to load spotswood's INI and try it again. Last edited by jdobbs; 17th July 2021 at 20:40. |
17th July 2021, 21:00 | #30738 | Link |
Ok. Using spotswood's INI settings, BD-RB kept the original core audio (it didn't reencode). Using the same source as my last post, the output looks like this:
Audio Format : AC-3 Format/Info : Audio Coding 3 Duration : 2 h 2 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 559 MiB (100%) Service kind : Complete Main @spotswood Are you sure this INI is the one you used? If so, why is your log showing a reencode while mine isn't? One other thing... have you tried using MEDIAINFO on the output M2TS instead of the MPLS, just to see if it reports something different (it doesn't on mine)? [EDIT] Ok. Now I did it with AUDIO_AMPLIFY set and "Do not reencode AC3" unchecked: Code:
Audio Format : AC-3 Format/Info : Audio Coding 3 Duration : 2 h 2 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 559 MiB (100%) Service kind : Complete Main Last edited by jdobbs; 17th July 2021 at 21:32. |
17th July 2021, 22:00 | #30739 | Link | |
Problem Solved!
Anyway, I'VE FIXED THE PROBLEM! I mentioned before that I had started over and re-downloaded and unzipped a fresh v0.61.22 of BDRB leaving everything stock w/o adding any hidden options etc. but the same problem persisted. Since running the System Settings Check showed everything to be fine, I didn't think to reinstall the helper programs, namely AviSynth. So after reinstalling v2.60 and trying again, voila! The lossless tracks are properly being reencoded to AC3 5.1@640 like they're supposed to. Something must have corrupted my AviSynth installation, I don't know, but after reinstalling it everything is fine now. What a relief! I was going crazy and really didn't want to wipe my drive and do a fresh W10 install. I apologize again for sending everyone trying to help (namely jdobbs) on a wild goose chase. I feel so stupid that I didn't think to reinstall everything (troubleshooting 101). Whole carton of eggs on face. If I post with what I think is a bug in the future, just ignore me. I'll figure it out eventually... Last edited by spotswood; 17th July 2021 at 22:11. |
17th July 2021, 22:08 | #30740 | Link |
Yes, with or without it didn't make a difference. This option is checked by default and I've always left it that way. It doesn't seem to make a difference either way. The only options I change depending on the job are "Do not convert DTS to AC3" (when keeping the DTS core), and "Keep HD audio for BD25 intact" (self explanatory and only for 7.1 tracks, personal preference). Thanks again for trying to help. When in doubt, reinstall everything!
