23rd September 2009, 02:45 | #2082 | Link |
Weird. I'm having the exact same problem as paolo, but I thought the error was due to being a tff source and not knowing the proper settings for deinterlacing it. Now that I think about it, I've had 2 DVD's that exibited this same trend. This one has the "Warner Bros" logo animation at the front, with no sound, and then the movie comes up all out of sync. The other DVD I had was the Foster Home season 2 discs (multi-episode per DVD). What it did was start the audio for the episode during the show intro, causing audio to be out of sync by exactly 59.5 seconds. I was able to manually set audio delay on my own and fix it. I didn't report it at that time because I thought it was due to a funky DVD structure, but now I'm not so sure.
Here's my make report for my latest endeavor: Code:
HDConvertToX v.2.1.471.3569 "Isotta" report Input File: h:\video_ts\vts_01_1.vob ( H:\VIDEO_TS\VTS_01_0.IFO ) PGC : PGC 1. Length: 1:31:30:03 / chained=1 Codec Video: mpeg Width / Heigh : 720 / 480 Framerate / Framecount: 29.970 / 164535 Duration(hh:mm:ss): 1:31:30 Aspect Ratio: 1.3334 Resized resolution: 704 / 544 Crop Values : 8:0:8:0 Start Video Configuration -> Encoding Settings: X264 Extreme Quality NMT Compatibility: On Encoding Preset: 7 Final Size: 20 Priority: idle Denoise Level: None Video Handling: Use Best Decoder Deinterlace: Telecine -> End Video Configuration Start Audio Configuration -> Audio Codec: Nero AAC Audio Audio Bitrate/Quality: 192 Audio Channels: 2 MP3 Mode: abr Normalize: On Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 80: English (AC3 2ch, 0xBD 0x80) [0] 81: Francais (AC3 2ch, 0xBD 0x81) [0] -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On -> End Advanced AviSynth Start Queue -> prompt $d $t $_$P$G "E:\Programs\HDConvertToX\applications\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[h:\video_ts\vts_01_1.vob] -OF=[E:\Programs\HDConvertToX\analysis\movie] -exit -minimize "E:\Programs\HDConvertToX\applications\eac3to.exe" "H:\VIDEO_TS\VTS_01_1.vob"+"H:\VIDEO_TS\VTS_01_2.vob"+"H:\VIDEO_TS\VTS_01_3.vob"+"H:\VIDEO_TS\VTS_01_4.vob"+"H:\VIDEO_TS\VTS_01_5.vob" 3: stdout.wav -normalize -down2 | "E:\Programs\HDConvertToX\applications\neroaacenc.exe" -if - -br 192000 -ignorelength -of "E:\Programs\HDConvertToX\analysis\hdencodertox-pid3.mp4" "E:\Programs\HDConvertToX\applications\x264.exe" --crf 20 --preset medium --bframes 3 --trellis 0 --ref 3 --deblock -1,-1 --subme 9 --direct auto --me umh --b-adapt 1 --no-chroma-me --tune film --sar 1:1 --output "E:\Programs\HDConvertToX\analysis\hdconverttox_vts_01_1.h264" "E:\Programs\HDConvertToX\analysis\hdconverttox_vts_01_1.avs" --level 4.0 "E:\Programs\HDConvertToX\applications\Chapter\ChapterXtractor.exe" "H:\VIDEO_TS\VTS_01_0.IFO" "E:\Programs\HDConvertToX\analysis\chapters.txt" -p5 "E:\Programs\HDConvertToX\applications\mp4box.exe" -add "E:\Programs\HDConvertToX\analysis\hdconverttox_vts_01_1.h264" -fps 23.976 -add "E:\Programs\HDConvertToX\analysis\hdencodertox-pid3.mp4":lang=eng -chap "E:\Programs\HDConvertToX\analysis\chapters.txt" "E:\Media\Movies\DVD\Horror\The Witches.Mp4" -> End Queue AviSynth Script -> Working with files: E:\Programs\HDConvertToX\analysis\hdconverttox_vts_01_1.avs Mpeg2Source("E:\Programs\HDConvertToX\analysis\movie.d2v") tfm(last,d2v="E:\Programs\HDConvertToX\analysis\movie.d2v").tdecimate() LanczosResize(704,544,8,0,-8,-0) ColorMatrix(d2v="E:\Programs\HDConvertToX\analysis\movie.d2v") -> End AviSynth Script |
23rd September 2009, 07:25 | #2083 | Link |
HDConvertToX author
the command line of audio extraction/encoding is ok
"E:\Programs\HDConvertToX\applications\eac3to.exe" "H:\VIDEO_TS\VTS_01_1.vob"+"H:\VIDEO_TS\VTS_01_2.vob"+"H:\VIDEO_TS\VTS_01_3.vob"+"H:\VIDEO_TS\VTS_01_4.vob"+"H:\VIDEO_TS\VTS_01_5.vob" 3: stdout.wav -normalize -down2 | "E:\Programs\HDConvertToX\applications\neroaacenc.exe" -if - -br 192000 -ignorelength -of "E:\Programs\HDConvertToX\analysis\hdencodertox-pid3.mp4" try ripping with latest dvdfab/anydvd BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
23rd September 2009, 08:32 | #2084 | Link | |
Anyway I tried dss or ffmpegsource and have same problem. Regards |
23rd September 2009, 08:48 | #2085 | Link |
HDConvertToX author
open the file (not the avs) with mpc
you got the same noise ? If NO, then the DSS should bring the same quality If YES, update your decoder BHH
23rd September 2009, 11:10 | #2086 | Link |
Emperor building empire
@ buzzqw - Video encoding wont start
I recently installed HDConverTox on a friend's new PC (XP partition) ... hoping to test drive a little speed.
The encode stoped after the audio encoding section. Audio encode was fine ... Test Interlace pattern also worked fine . Code:
HDConvertToX v.2.1.471.3569 "Isotta" report Input File: f:\to errol\images\jailhouse 1\video_ts1\vts_01_1.vob ( F:\To Errol\IMAGES\Jailhouse 1\VIDEO_TS1\VTS_01_0.IFO ) PGC : PGC 1. Length: 1:45:28:15 / chained=1 Codec Video: mpeg Width / Heigh : 720 / 576 Framerate / Framecount: 25.000 / 158200 Duration(hh:mm:ss): 1:45:29 Aspect Ratio: 1.7778 Resized resolution: 832 / 464 Crop Values : 8:8:12:8 Start Video Configuration -> Encoding Settings: X264 Slow ; Quality= 22 Encoding Preset: 7 Final Size: 22 Priority: abovenormal Denoise Level: Super Light Video Handling: Use Best Decoder -> End Video Configuration Start Audio Configuration -> Audio Codec: Nero AAC Audio Audio Bitrate/Quality: 0.2 Audio Channels: 2 MP3 Mode: vbr Normalize: On Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 80: English (AC3 2ch, 0xBD 0x80) [0] 81: Francais (AC3 2ch, 0xBD 0x81) [0] 82: Nederlands (AC3 2ch, 0xBD 0x82) [0] 83: Espanol (AC3 2ch, 0xBD 0x83) [0] 84: Italiano (AC3 2ch, 0xBD 0x84) [0] -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE Nederlands 0 (0xBD 0x20) [0] wide Portugues 1 (0xBD 0x21) [0] wide Greek 2 (0xBD 0x22) [0] wide -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On -> End Advanced AviSynth Start Queue -> prompt $d $t $_$P$G "C:\Program Files\HDConterTox\applications\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[f:\to errol\images\jailhouse 1\video_ts1\vts_01_1.vob] -OF=[C:\Program Files\HDConterTox\job0\movie] -exit -minimize "C:\Program Files\HDConterTox\applications\eac3to.exe" "F:\To Errol\IMAGES\Jailhouse 1\VIDEO_TS1\VTS_01_1.vob"+"F:\To Errol\IMAGES\Jailhouse 1\VIDEO_TS1\VTS_01_2.vob"+"F:\To Errol\IMAGES\Jailhouse 1\VIDEO_TS1\VTS_01_3.vob"+"F:\To Errol\IMAGES\Jailhouse 1\VIDEO_TS1\VTS_01_4.vob"+"F:\To Errol\IMAGES\Jailhouse 1\VIDEO_TS1\VTS_01_5.vob" 3: stdout.wav -normalize -down2 | "C:\Program Files\HDConterTox\applications\neroaacenc.exe" -if - -q 0.2 -ignorelength -of "C:\Program Files\HDConterTox\job0\hdencodertox-pid3.mp4" "C:\Program Files\HDConterTox\applications\x264.exe" --crf 22 --preset slow --sar 1:1 --output "C:\Program Files\HDConterTox\job0\hdconverttox_vts_01_1.h264" "C:\Program Files\HDConterTox\job0\hdconverttox_vts_01_1.avs" "C:\Program Files\HDConterTox\applications\mp4box.exe" -add "C:\Program Files\HDConterTox\job0\hdconverttox_vts_01_1.h264" -fps 25.000 -add "C:\Program Files\HDConterTox\job0\hdencodertox-pid3.mp4":lang=eng -chap "C:\Program Files\HDConterTox\job0\autochapters.txt" "F:\To Errol\IMAGES\Jailhouse 1\Jailhouse1.mp4" -> End Queue AviSynth Script -> Working with files: C:\Program Files\HDConterTox\job0\hdconverttox_vts_01_1.avs Mpeg2Source("C:\Program Files\HDConterTox\job0\movie.d2v") LanczosResize(832,464,8,8,-12,-8) ColorMatrix(d2v="C:\Program Files\HDConterTox\job0\movie.d2v") hqdn3d(1) -> End AviSynth Script It's all good Pascal |
23rd September 2009, 12:11 | #2087 | Link |
HDConvertToX author
got any error opening avs script in virtualdub ?
BHH
24th September 2009, 01:41 | #2089 | Link | |
I'll run a test on The Game Plan as well (currently the only 2 BD discs that I have). |
24th September 2009, 01:55 | #2090 | Link |
Well, its not a bad rip. Playing the VOBs directly does not exhibit this behavior. Nor does mounting the iso (I rip DVD Decryptor in ISO mode) and playing it in MPC.
I'm attempting a conversion with Ripbot264 and seeing if it exhibits the same behavior. Edit: Ripbot Conversion finished, and comes out perfect. Thus, I can only assume that the problem in on HDC's end, and not on my rip's end. Sorry Last edited by Crono141; 24th September 2009 at 05:36. |
24th September 2009, 07:36 | #2091 | Link |
HDConvertToX author
@Crono141
could you post the log files generated by ripbot ? (pm me if you prefer) BHH
24th September 2009, 11:10 | #2092 | Link |
I did a reencode of a 1080p movie to 720p as I did several times with AutoMKV before. As in those cases I chose a CRF of 20, but somehow the result only has a bitrate of 1900, with AutoMKV and the same CRF it used a much higher bitrate, especially in a movie like this (Iron Man).
Besides that this is a great tool, but for now I'll switch back to AutoMKV where I can estimate the results in adance. What could be the problem here? |
24th September 2009, 11:58 | #2093 | Link |
HDConvertToX author
isn't a problem, at all
automkv has a very outdated x264, hdc has a very new x264 x264.exe has changed a lot crf encoding in latest (and not so latest) builds use the search BHH
24th September 2009, 13:22 | #2094 | Link |
So does that mean that with this Tool I should use a much lower CRF? As I am used from AutoMKV, also the tooltip for HDConvertToX says that 18 gives quite good results. I had in mind that values between 18 and 22 are common. But as I said, that gave me a very low bitrate (which it did not with AutoMKV). So do I have to use CRF of 10 or something like that for bitrates of about 4000-7000 (like most 720p encodes that are "available" on the internet).
24th September 2009, 16:12 | #2095 | Link | |
Can you post your sys specs and the framerate on multi thread vs single encode if you dont mind? I started converting my BD on single thread and only getting 6fps which I gotta check with the beta version soon. thanks |
24th September 2009, 16:27 | #2096 | Link |
HDConvertToX author
@CYBERSONIC
you should use the crf you prefer, usually 20 is enough but if you prefere quality wise encoding feel free to use whatever crf you want BHH
24th September 2009, 18:57 | #2097 | Link | |
AMD Phenom II X4 955BE @ 3.5GHZ ASUS GTX260 ASUS M4N82 DELUXE NF980ASLI R 8GB OCZ Platinum PC8500 DDR2 1066MHz Win 7 x64 Ultimate Framerate on the Multi that I ran last night, I think was around 14 to 17fps. I'm encoding to MP4, 2pass, insane quality, 8500kbs bitrate. If I recall, it was something like 7 to 11fps on single thread. I'm not 100% sure on the fps, though, as I don't usually monitor it. Is there an output that tells me what it averaged? |
24th September 2009, 19:30 | #2098 | Link | |
If it can help, the movie that gives me problems is "Codice Swordfish" But I don't have problems playing vob files... I think the problem is related to the different lenght of the vob and the avi... They differ 2 minutes, and audio could be out-of-phase of THOSE 2 minutes... Other movies are OK, BTW ... Thank you |
25th September 2009, 07:46 | #2100 | Link | |
HDConvertToX author
BETA update just few post above BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
