Old 16th March 2025, 05:06   #1  |  Link
jay123210599
vspreview: Debanding Problems
I tried to deband a video in vspreview, but I got this error and the deband video was just a black screen. How do I fix that?
Allocation of size 8112K failed: VK_ERROR_OUT_OF_DEVICE_MEMORY!
Memory heaps supported by device:
    0: flags 0x1 size   23G
    1: flags 0x0 size   15G
    2: flags 0x1 size  214M
Memory pool 0:
    Compatible types: 0x3
    Optimal flags: 0x1
    Slab  0:        c x 8640K:   10M used   16M res   33M alloc from heap 0, efficiency 63.89%  [../subprojects/libplacebo/src/utils/upload.c:245]
    Pool summary:   10M used   16M res   33M alloc, efficiency 63.89%, utilization 50.00%
Memory pool 1:
    Compatible types: 0xffffffff
    Optimal flags: 0x2
    Buffer flags: 0x3
    Slab  0:        e x 8100K: 8100K used 8100K res   31M alloc from heap 1, efficiency 100.00%  [../subprojects/libplacebo/src/gpu/utils.c:575]
    Pool summary: 8100K used 8100K res   31M alloc, efficiency 100.00%, utilization 25.00%
Memory pool 2:
    Optimal flags: 0x3
    Buffer flags: 0x3
    Pool summary:     0 used     0 res     0 alloc, efficiency 100.00%, utilization 100.00%
Memory summary:   18M used   24M res   65M alloc, efficiency 75.41%, utilization 37.90%, max page: 1520M
  Backtrace:
    #0  0x7ffa22964ef1 in pl_vulkan_release_ex+0x7491 (C:\Users\User\AppData\Roaming\VapourSynth\plugins64\libvs_placebo.dll+0x84ef1) (0x240ac4ef1)
    #1  0x7ffa22966442 in pl_vulkan_release_ex+0x89e2 (C:\Users\User\AppData\Roaming\VapourSynth\plugins64\libvs_placebo.dll+0x86442) (0x240ac6442)
    #2  0x7ffa22959604 in pl_vulkan_sem_create+0x1094 (C:\Users\User\AppData\Roaming\VapourSynth\plugins64\libvs_placebo.dll+0x79604) (0x240ab9604)
    #3  0x7ffa22941c81 in pl_buf_create+0x211 (C:\Users\User\AppData\Roaming\VapourSynth\plugins64\libvs_placebo.dll+0x61c81) (0x240aa1c81)
    #4  0x7ffa229462f8 in pl_timer_query+0x2458 (C:\Users\User\AppData\Roaming\VapourSynth\plugins64\libvs_placebo.dll+0x662f8) (0x240aa62f8)
    #5  0x7ffa2295b86c in pl_vulkan_sem_create+0x32fc (C:\Users\User\AppData\Roaming\VapourSynth\plugins64\libvs_placebo.dll+0x7b86c) (0x240abb86c)
    #6  0x7ffa229418cc in pl_tex_upload+0x7c (C:\Users\User\AppData\Roaming\VapourSynth\plugins64\libvs_placebo.dll+0x618cc) (0x240aa18cc)
    #7  0x7ffa2295102f in pl_upload_plane+0x2ef (C:\Users\User\AppData\Roaming\VapourSynth\plugins64\libvs_placebo.dll+0x7102f) (0x240ab102f)
    #8  0x7ffa228e221c in VapourSynthPluginInit2+0xb9c (C:\Users\User\AppData\Roaming\VapourSynth\plugins64\libvs_placebo.dll+0x221c) (0x240a4221c)
    #9  0x7ffb7657f30c in getVapourSynthAPI+0xd6dc (C:\Users\User\AppData\Local\Programs\Python\Python312\Lib\site-packages\VapourSynth.dll+0x10f30c) (0x18010f30c)
    #10 0x7ffb765927ac in getVapourSynthAPI+0x20b7c (C:\Users\User\AppData\Local\Programs\Python\Python312\Lib\site-packages\VapourSynth.dll+0x1227ac) (0x1801227ac)
    #11 0x7ffb765944a2 in getVapourSynthAPI+0x22872 (C:\Users\User\AppData\Local\Programs\Python\Python312\Lib\site-packages\VapourSynth.dll+0x1244a2) (0x1801244a2)
    #12 0x7ffc76c137af in wcsrchr+0x14f (C:\WINDOWS\System32\ucrtbase.dll+0x37af) (0x1800037af)
    #13 0x7ffc7897e8d6 in BaseThreadInitThunk+0x16 (C:\WINDOWS\System32\KERNEL32.DLL+0x2e8d6) (0x18002e8d6)
    #14 0x7ffc7965bf6b in RtlUserThreadStart+0x2b (C:\WINDOWS\SYSTEM32\ntdll.dll+0xbbf6b) (0x1800bbf6b)
  for malloc: ../subprojects/libplacebo/src/gpu/utils.c:575
No slab to serve request for 2025K bytes (with alignment 0xc00) in pool 2!
2025-03-15 07:15:45.670: root: CRITICAL: placebo.Deband: Failed downloading data from the GPU!
Memory pool 0:
    Optimal flags: 0x1
    Slab  0:        8 x 8640K:   13M used   25M res   33M alloc from heap 0, efficiency 51.85%  [../subprojects/libplacebo/src/utils/upload.c:245]
    Pool summary:   13M used   25M res   33M alloc, efficiency 51.85%, utilization 75.00%
Memory pool 1:
    Optimal flags: 0x2
    Buffer flags: 0x3
Memory pool 2:
    Optimal flags: 0x3
    Buffer flags: 0x3
Memory summary:   21M used   33M res   65M alloc, efficiency 63.32%, utilization 50.81%, max page: 1520M
  Backtrace:
2025-03-15 07:15:45.739: root: CRITICAL: placebo.Deband: Failed downloading data from the GPU!
Allocation of size  252K failed: VK_ERROR_OUT_OF_DEVICE_MEMORY!
Memory pool 0:
    Optimal flags: 0x1
Memory pool 1:
    Optimal flags: 0x2
    Buffer flags: 0x3
Memory pool 2:
    Compatible types: 0xffffffff... (82 KB left)
jay123210599 is offline   Reply With Quote
Old 16th March 2025, 08:16   #2  |  Link
GeoffreyA
Looks like a Vulkan issue and not enough memory. You could also try neo_f3kdb, which is a good debander for anime.
GeoffreyA is offline   Reply With Quote
Old 16th March 2025, 12:49   #3  |  Link
jay123210599
I have a Geforce RTX 3090. How does that not have enough memory?
Old 16th March 2025, 14:03   #4  |  Link
GeoffreyA
Fair enough. It says it could not allocate 8 MB, so there is some memory-allocation issue.
Old 16th March 2025, 15:01   #5  |  Link
jay123210599
How do I fix it?
Old 16th March 2025, 16:44   #6  |  Link
GeoffreyA
Originally Posted by jay123210599 View Post
How do I fix it?
To be honest, I don't know.
Old 18th March 2025, 18:39   #7  |  Link
jay123210599
I just figured it out, I needed to replace my old libvs_placebo.dll file with an newer version of it.
Old 18th March 2025, 20:54   #8  |  Link
GeoffreyA
Glad to hear it, Jay.
deband, debanding, vapoursynth
