Old 19th December 2024, 06:47   #1  |  Link
RARY
Noisy YUV and Y4m test sequences
Hello,
I need some noisy video clips in YUV or Y4M format. It should have wide range of noise from high noisy to clean video clips and also includes different noises. Anyone has recommendations or links to such datasets.
Thank you!
RARY is offline   Reply With Quote
Old 19th December 2024, 14:48   #2  |  Link
Dont know if what you want is included here, but maybe worth a look.
Consolidated list of test video clip resources :- https://forum.doom9.org/showthread.php?t=135034
(Avisynth Forum, Sticky)
If you do find some of what you seek, then maybe post links in that thread.
Old 19th December 2024, 17:27   #3  |  Link
Z2697
Consolidated list of test video clip resources :- https://forum.doom9.org/showthread.php?t=185996
Link is wrong?
Z2697 is offline   Reply With Quote
Old 19th December 2024, 17:34   #4  |  Link
Z2697
Uncompressed clips are huge...
Only some open source video projects provide truely lossless (original quality) source files. And most often they are CGI rather than real life footage.
Or some small size standard test clips.
You can find some at https://media.xiph.org/video/derf/
Otherwise if you just want some "casual" stuff you can just decode the more common videos (i.e. lossy compressed) to uncompressed format.
Old 19th December 2024, 23:28   #5  |  Link
Link is wrong?
Yep, sorry, link was to this thread by mistake.
Fixed.
Old 20th December 2024, 16:21   #6  |  Link
Leo 69
Here are three, high quality (uncompressed) noisy samples:
https://app.filen.io/#/d/eda706e7-ab...IxFOFQU66Ajdcm
Leo 69 is offline   Reply With Quote
Old 12th January 2025, 07:58   #7  |  Link
KarthikTdk
Hi All,
I want test video sequence of above mentioned of yuv 4:2:0 ratio , i found some websites but they are not use full, Kindly any one help to get these videos.
Thanks,
Karthik.
KarthikTdk is offline   Reply With Quote
film grain, gaussian, motion noise, salt-and-pepper noise, temporal noise
