Old 18th December 2024, 04:44   #1  |  Link
UFOxyz
how can i rotate an image file to 270 degrees or 90 degrees in clockwise?
none of these below worked.
ffmpeg -y -rotate=90 -i "%1" "m:\aaa.bmp"
ffmpeg -y -rotate=90 -i "%~1" "m:\aaa.bmp"
ffmpeg -y -display_rotation 90 -i b.bmp "m:\aaa.bmp"
ffmpeg -y -display_rotation 90 -codec copy -i b.bmp "m:\aaa.bmp"
are these in below the same?
-c copy
-codec copy
-c codec copy
PS
now i kind of got it after a long floundering
-codec copy must not be included
if there is a way to improve or refine the command line, please do add
Last edited by UFOxyz; 18th December 2024 at 05:26. Reason: i kind of made it work, but hope to refine the command line
UFOxyz is offline   Reply With Quote
Old 18th December 2024, 13:42   #2  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
You cannot use -c copy since it does unmodified stream copy. If you rotate, that's a modification. As the name implies, it copies content 1:1, hence the name copy. If you modify something, it's no longer "copy" and it won't work.
To rotate 90° clockwise, use -vf transpose=1
Old 18th December 2024, 18:50   #3  |  Link
Z2697
hflip or vflip should be used after transpose to create actual rotation effect. There's also a filter that's just called "rotate".
Z2697 is offline   Reply With Quote
Old 18th December 2024, 19:54   #4  |  Link
microchip8
microchip8's Avatar
Not mandatory. Just using transpose=<value> rotates just fine.
Old 19th December 2024, 20:24   #5  |  Link
Sharc
Something like this?
ffplay -i "your_source" -vf "rotate='15*PI/180:ow=hypot(iw,ih):oh=ow',scale=w=-2:h=576,setsar=1/1"
or
ffmpeg -i "your_source" -vf "rotate='0.2*PI*t:ow=hypot(iw,ih):oh=ow:fillcolor=yellow',scale=w=-2:h=720,setsar=sar=1/1" -c:a copy -c:v libx264 -crf 20 "rotated.mp4"
Old 19th December 2024, 23:41   #6  |  Link
Maybe see this (Open Source, I think), Lossless rotate for jpg, apparently.
FreeVimager
https://www.contaware.com/software/freevimager.html
rotate image
