Old 30th October 2019, 19:24   #1  |  Link
iAvoe
Intra/inter reference area versus performance
From the original document x265.readthedocs.io and a bunch of paper, I've found that both x264/5 are only using one row of macroblock/ctus for inter and intra referencing (or just inter, not very sure about intra). And in x265, frame-thread can be used to make the whole inter frame(s) available but in cost of adding delays.
My questions are:
1.if I'm right, could there be an option to expand reference area by waiting for more reference blocks outside are generated, if blocks within it are not good enough (causing error)
2.does lookahead-thread option increases performance when frame-thread is disabled
3.is inter frame referencing not as relevent as I think, because by increasing mode decision / loop filter costs (things to do before generating reference blocks) are giving better compression
4.is the whole intra frame available to reference at very first
Thanks for reading though!
iAvoe is offline   Reply With Quote
performance, referencing
