#21 | Link | |
Then 1 big workflow can be split into few smaller ones and output of each gets passed to next one. Easier to organise and manage. |
#22 | Link |
Broadcast Encoder
I was writing a Wikipedia Page about FFASTrans but I'm struggling to get it approved 'cause they say that it lacks official references...
Here's the page: https://en.wikipedia.org/wiki/Draft:...nth_Transcoder Any suggestions? Have you ever managed to get something approved on Wikipedia? |
#23 | Link |
He was complaining about COI, conflict of interest, as if you "advertise" the software. I don't know how to resolve it though, probably a further read on this page will help, https://en.wikipedia.org/wiki/Wikipe...ct_of_interest. A suggestion on writing the content, probably you need to cite the references within the content, rather than just put up reference list.
#24 | Link | ||
Broadcast Encoder
![]() Anyway, about the references, I tried to add as many as I could, but it still didn't work... ![]() Quote:
The way I did it was by calling other workflows using the REST-API, so what you suggested is exactly what I did. The way it's implemented right now, though, requires a bit of knowledge and scripting of the REST-API, but it can be done. ![]() |
#27 | Link |
Broadcast Encoder
Version 1.2.0 Stable Released!!
Changelog: - New filter: Safe Color Limiter makes sure you video stays within legal TV ranges. - New filter: Linear Transformation for linear conversion between different color formats like HDR <-> SDR. - Both conditional and populate nodes now supports dynamic number of fields and resizes the GUI accordingly. - Added new operator mode to support regular expressions in the conditional node. - Added the ability to send attachments and a "Reply to" field to the "Send E-mail" node. - Added HD profiles to the "DV/DVCPRO" encoder. - Added lasso functionality for selecting several nodes in the editor. - Added new function $regreplace() for replacing strings using PCRE regex patterns. - Added new function $jsonput() for adding JSON data to an existing or create new JSON formatted string. - Added new variable %s_wf_folder% for getting folder of the running workflow. - Added new variable %i_job_priority% for getting priority of the running job instance. - Added new variable %s_split_id% for getting split id of the running job instance. - Added file count to the "Hold" node wait for file option. - Added option in "Custom AviSynth" filter to attempt adapting colors pace metadata to video properties. - Copied nodes with connection within the group is now kept. - Selected nodes can now be moved simultaneously while keeping their relative position. - The "YouTube"-decoder will no longer try to download complete lists. - Improved start TC detection on some formats. - The "H.264" encoder can now produce MXF files and uncompressed PCM audio in the MOV, MKV and MXF wrappers. - The "A/V Media" decoder now dither if source video bit depth is higher than specified in the node. - Increased the number of max active jobs the inbuilt monitor would display. - The rest service now returns 503 if database is not available. Mostly a problem when running FFAStrans from share. - Aborting jobs will now try more graceful shutdown of child processes before force killing. - General improvements to file monitoring and job initiation reliability. - Addressed several stability issues when running FFAStrans from a share. - Fixed issue where running FFAStrans would not properly close on shutdown. - Submitting files to other workflows than the current in editor did not work. - Video with too short audio could result in corrupt endings. - Results from PSNR and SSIM in "Video quality" analyzer was switched. - Fixed issues with catching all STDOUT data from "Command Executor". - Fixed GUI issues when controlling manager through TeamViewer. - Fixed several reliability issues with the camera monitors. - Fixed crash when attempting to use predefined levels in "Colorspace" filter. - The workflow counter in FFAStrans Workflow Manager lower status bar did not work. - Fixed issue with the FFAStrans Workflow Manager causing graphic issues and instability when working with large workflows. - Custom nodes would crash if trying to open a help section that did not exist. - Variables within variables was not properly expanded. - The web interface would sometimes show hanging node even though it had finished. - When submitting file through the API, the job id was initially written to a wrong key. - Fixed crash that sometimes occurred when enumerating child processes. - Variables or statics with data containing the pipe "|" character was not displayed in the variables list. - Numerous other minor bug fixes and improvements. The website has now been re-written from scratch: http://ffastrans.com/wp/ Cheers, Frank |
#28 | Link | |
Broadcast Encoder
Version 1.3.0 Stable Released!!
Finally a new version that doesn't just focus on fixes and improvements but that also has a lot of new nice features. Changelog: Quote:
#29 | Link | |
Broadcast Encoder
Version 1.3.0.1 Stable Released!!
Changelog: Quote:
#30 | Link | |
Broadcast Encoder
Version 1.3.0.2 Stable Released!!
Changelog: Quote:
Download: Link |
#31 | Link | |
Broadcast Encoder
Version 1.3.1 Stable Released!!
Changelog: Quote:
#32 | Link | |
Broadcast Encoder
FFAStrans 1.4.0.1 Released!!
Changelog: Quote:
![]() Last edited by FranceBB; 29th January 2024 at 08:58. |
#33 | Link | |
Broadcast Encoder
FFAStrans 1.4.0.5 Released!!
Changelog: Quote:
#34 | Link |
Broadcast Encoder
Well, those were from 4 years ago and although they have been working fine up until a while ago, they're not gonna work with 1.4.x 'cause starting from 1.4 we have the Avisynth frame properties.
Before frame properties either you had an input, you submitted the file to an encoder node and let the filter_builder take care of creating a command line for you to encode the file properly by performing all the necessary conversions like deinterlacing, converting the primaries, transfer and matrix etc or you could just write your own AVS Script and then basically tell the filter_builder "hey, don't do anything, I've done everything, just encode the file". In other words, there was no in between scenario. Now, with the new frame properties, we actually have a way to interact with the filter_builder.a3x which means that we can have scenarios in which you're doing some things within your Avisynth Script but you don't wanna take care of some other things and you want the filter_builder to do it for you. This is where frame properties come in handy. I'll update the workflow collection on Monday, first thing in the morning. You're gonna be able to see where frame properties are used and how. ![]() Last edited by FranceBB; 20th April 2024 at 15:59. |
#35 | Link | |
Broadcast Encoder
FFAStrans 1.4.0.6 Released!!
Changelog: Quote:
#36 | Link | |
Broadcast Encoder
FFAStrans 1.4.0.7 Released!!
Changelog: Quote:
#37 | Link |
Awesome! I like to start to use it but I have not found if (probably the answer is no) it supports encoding in >10-bit for dnxhr/prores or if you can recommend another codec for the use in post production? Thanks!
#38 | Link |
Broadcast Encoder
Unfortunately you're right, but there's nothing I can do about it. The problem with DNX and ProRes is that both implementations rely on the Lavc encoder which is built in ffmpeg and nobody ever developed it to make it go past 10bit planar, so we can't just add an encoding profile that doesn't exist.
![]() If someone is gonna develop a new high bit depth version of the DNX HR and AppleProRes encoder that supports 12bit, we'll definitely add support for it, but until then I'm afraid we don't have much choice. ![]() |
#39 | Link | |
#40 | Link | |
Broadcast Encoder
![]() Last edited by FranceBB; 28th July 2024 at 15:13. |
