#1 | Link |
Questions about settings and scenecut detection?
Hi everybody!
Be prepared - this could be a really LAME thread if you know the answer of my questions. Occasionally I encode some vids in the last 15 years and I'm really glad that finally there are outstanding encoders like x264. I'm saying this, because I am able to tune every parameter for my encodes except the scene cut detection, which I am used to consider as important. The problem is that no matter what combination of --keyint and --scenecut values I use I always get an I-frame on each --keyint interval (tried even --scenecut values like 4000). The goal: 1. I encode Blu ray content and I want it to be 4~6 times smaller in size than the original (should I say "... and preserve max quality"?). Actually the quality is important mainly in terms of avoiding obvious compression artifacts; 2. Source resolution and frame rate are preserved; 3. DXVA compatibility; 4. Processing time is not important. The settings: In this case the video has a lot of static scenes, interlaced. Code:
--preset veryslow --tune film --crf 24 --qpmin 5 --qpmax 51 --qpstep 8 --non-deterministic --fps 25 --force-cfr --tff --min-keyint 5 --keyint 126 --scenecut 100 --no-fast-pskip --sar 1:1 --level 4.1 --open-gop --b-pyramid normal --bframes 16 --ref 4 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --subme 10 --tff --aq-mode 2 --aq-strength 0.9 --slices 4 --rc-lookahead 60 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" 1. Should I worry about the improper placement of the I-frames? I know that nowadays the correct detection is not so crucial for the quality, but I keep thinking that with better placement *something* could be better in the overall result? I would sleep better if I am able to set high keyint and rely on a proper scene cut detection. 2. The settings above are DXVA compatible on my configuration (I tested with ffdshow DXVA and with Daum PotPlayer). How likely it is these settings to be DXVA incompatible on different PC configurations? And finally I'll try to explain what I consider to be an improper scene cut detection - with the above settings i get an I-frame on frames 125,250,375,500,625,750.... In the video one almost static, dark, very well compressed scene finishes at frame 490 and is replaced by another almost static very well compressed scene that seems to be very different - much more details, colors and light. Because I'm forced to use a short keyint, too often I get I-frames just a few frames before the actual scene cut and none of the information in the I-frame *seems* to be reusable. Thank you for your answers! Last edited by jassenjj; 22nd January 2012 at 11:46. |
#2 | Link | |
Could you post a sample clip? And what's up with all these scenecut topics lately...? |
#3 | Link |
It is possible that many people are confused (or not) with the role of the I-frames in x264 and the impact on the quality and efficiency of the encoding.
Others have a real problem when it comes to adjusting subtitles manually and they would definitely benefit from a proper placement. I can't promise example movies soon. For me it is strange that I encode 3 hours of BD movie (one disc of the BBC Life series) and there are all types of scenes - static, dynamic, bright, dark, grainy, clean... and I don't have even one I-frame that is not on a keyint interval. The final encode was done with --scenecut set to 1000 (one thousand) after I had the same behavior with lower values and larger keyints. |
#4 | Link | |
That certainly doesn't sound right. |
#5 | Link |
Further investigation...
Well... this is what I get with --keyint 276 and --scenecut 9000000. Again scenecuts are are only on keyint interval and judging from the log there are at least 3 frames that are candidates for a scenecut around the choosen one: frame 722 seems to be very "heavy" compared to the neighbours. Frame 815 is just 10 frames before the I-frame but again it wasn't a good candidate.
I would definitely be glad if somebody help me to understand this or finally expose it as a bug. Code:
x264 [debug]: frame= 689 QP=27.63 NAL=2 Slice:P Poc:1384 I:5343 P:2683 SKIP:134 size=42870 bytes x264 [debug]: frame= 690 QP=27.91 NAL=2 Slice:B Poc:1380 I:2075 P:3816 SKIP:2015 size=26255 bytes x264 [debug]: frame= 691 QP=28.12 NAL=0 Slice:B Poc:1378 I:546 P:1966 SKIP:5610 size=6254 bytes x264 [debug]: frame= 692 QP=29.42 NAL=0 Slice:B Poc:1382 I:2480 P:2501 SKIP:3098 size=16831 bytes x264 [debug]: frame= 693 QP=27.31 NAL=2 Slice:P Poc:1388 I:4243 P:3685 SKIP:232 size=37233 bytes x264 [debug]: frame= 694 QP=29.04 NAL=0 Slice:B Poc:1386 I:2206 P:3496 SKIP:2151 size=22423 bytes x264 [debug]: frame= 695 QP=26.74 NAL=2 Slice:P Poc:1396 I:5424 P:2614 SKIP:122 size=44366 bytes x264 [debug]: frame= 696 QP=28.63 NAL=2 Slice:B Poc:1392 I:2038 P:4092 SKIP:1811 size=24287 bytes x264 [debug]: frame= 697 QP=29.04 NAL=0 Slice:B Poc:1390 I:1898 P:3595 SKIP:2482 size=20968 bytes x264 [debug]: frame= 698 QP=29.72 NAL=0 Slice:B Poc:1394 I:1957 P:2803 SKIP:3341 size=16146 bytes x264 [debug]: frame= 699 QP=27.94 NAL=2 Slice:P Poc:1406 I:5148 P:2789 SKIP:223 size=40717 bytes x264 [debug]: frame= 700 QP=28.64 NAL=2 Slice:B Poc:1402 I:4614 P:2303 SKIP:1016 size=34805 bytes x264 [debug]: frame= 701 QP=29.61 NAL=0 Slice:B Poc:1398 I:140 P:1738 SKIP:6273 size=4110 bytes x264 [debug]: frame= 702 QP=29.28 NAL=0 Slice:B Poc:1400 I:1506 P:4247 SKIP:2170 size=21772 bytes x264 [debug]: frame= 703 QP=30.37 NAL=0 Slice:B Poc:1404 I:121 P:1658 SKIP:6367 size=3665 bytes x264 [debug]: frame= 704 QP=27.09 NAL=2 Slice:P Poc:1408 I:3780 P:4034 SKIP:346 size=38718 bytes x264 [debug]: frame= 705 QP=27.08 NAL=2 Slice:P Poc:1416 I:5788 P:2191 SKIP:181 size=44497 bytes x264 [debug]: frame= 706 QP=27.93 NAL=2 Slice:B Poc:1412 I:1741 P:4773 SKIP:1375 size=31836 bytes x264 [debug]: frame= 707 QP=29.38 NAL=0 Slice:B Poc:1410 I:1438 P:3857 SKIP:2617 size=19934 bytes x264 [debug]: frame= 708 QP=30.47 NAL=0 Slice:B Poc:1414 I:105 P:1935 SKIP:6114 size=4515 bytes x264 [debug]: frame= 709 QP=27.56 NAL=2 Slice:P Poc:1426 I:4898 P:3135 SKIP:127 size=47343 bytes x264 [debug]: frame= 710 QP=29.69 NAL=2 Slice:B Poc:1422 I:1219 P:4513 SKIP:2195 size=23694 bytes x264 [debug]: frame= 711 QP=29.97 NAL=0 Slice:B Poc:1418 I:751 P:4201 SKIP:3007 size=16508 bytes x264 [debug]: frame= 712 QP=29.20 NAL=0 Slice:B Poc:1420 I:179 P:1872 SKIP:6086 size=4640 bytes x264 [debug]: frame= 713 QP=30.16 NAL=0 Slice:B Poc:1424 I:1412 P:2911 SKIP:3790 size=15216 bytes x264 [debug]: frame= 714 QP=27.61 NAL=2 Slice:P Poc:1434 I:4534 P:3442 SKIP:184 size=42685 bytes x264 [debug]: frame= 715 QP=27.82 NAL=2 Slice:B Poc:1430 I:1855 P:4264 SKIP:1776 size=29316 bytes x264 [debug]: frame= 716 QP=29.48 NAL=0 Slice:B Poc:1428 I:232 P:1923 SKIP:5971 size=5425 bytes x264 [debug]: frame= 717 QP=29.53 NAL=0 Slice:B Poc:1432 I:1772 P:3893 SKIP:2360 size=21764 bytes x264 [debug]: frame= 718 QP=27.10 NAL=2 Slice:P Poc:1442 I:4744 P:3278 SKIP:138 size=44210 bytes x264 [debug]: frame= 719 QP=27.94 NAL=2 Slice:B Poc:1438 I:2167 P:4067 SKIP:1705 size=29142 bytes x264 [debug]: frame= 720 QP=30.16 NAL=0 Slice:B Poc:1436 I:1542 P:3013 SKIP:3565 size=15241 bytes x264 [debug]: frame= 721 QP=29.21 NAL=0 Slice:B Poc:1440 I:196 P:2114 SKIP:5843 size=5436 bytes x264 [debug]: frame= 722 QP=28.02 NAL=2 Slice:P Poc:1450 I:8091 P:69 SKIP:0 size=106610 bytes x264 [debug]: frame= 723 QP=27.39 NAL=2 Slice:B Poc:1446 I:125 P:1769 SKIP:6261 size=4803 bytes x264 [debug]: frame= 724 QP=30.81 NAL=0 Slice:B Poc:1444 I:74 P:1451 SKIP:6633 size=2178 bytes x264 [debug]: frame= 725 QP=31.28 NAL=0 Slice:B Poc:1448 I:834 P:5219 SKIP:1542 size=46652 bytes x264 [debug]: frame= 726 QP=27.83 NAL=2 Slice:P Poc:1458 I:3863 P:4109 SKIP:188 size=73567 bytes x264 [debug]: frame= 727 QP=29.75 NAL=2 Slice:B Poc:1454 I:799 P:5916 SKIP:1084 size=46704 bytes x264 [debug]: frame= 728 QP=31.66 NAL=0 Slice:B Poc:1452 I:193 P:5357 SKIP:2541 size=20833 bytes x264 [debug]: frame= 729 QP=31.47 NAL=0 Slice:B Poc:1456 I:55 P:3162 SKIP:4930 size=6852 bytes x264 [debug]: frame= 730 QP=28.59 NAL=2 Slice:P Poc:1468 I:3757 P:4315 SKIP:88 size=75266 bytes x264 [debug]: frame= 731 QP=31.41 NAL=2 Slice:B Poc:1464 I:771 P:5610 SKIP:1334 size=40269 bytes x264 [debug]: frame= 732 QP=31.70 NAL=0 Slice:B Poc:1460 I:175 P:5862 SKIP:1985 size=23056 bytes x264 [debug]: frame= 733 QP=31.45 NAL=0 Slice:B Poc:1462 I:107 P:3538 SKIP:4455 size=8525 bytes x264 [debug]: frame= 734 QP=31.00 NAL=0 Slice:B Poc:1466 I:906 P:5020 SKIP:1907 size=29456 bytes x264 [debug]: frame= 735 QP=28.53 NAL=2 Slice:P Poc:1472 I:2321 P:5537 SKIP:302 size=60525 bytes x264 [debug]: frame= 736 QP=30.99 NAL=0 Slice:B Poc:1470 I:139 P:3167 SKIP:4797 size=7755 bytes x264 [debug]: frame= 737 QP=27.91 NAL=2 Slice:P Poc:1480 I:3875 P:4098 SKIP:187 size=74235 bytes x264 [debug]: frame= 738 QP=30.60 NAL=2 Slice:B Poc:1476 I:917 P:5521 SKIP:1301 size=41422 bytes x264 [debug]: frame= 739 QP=31.11 NAL=0 Slice:B Poc:1474 I:777 P:5322 SKIP:1690 size=30428 bytes x264 [debug]: frame= 740 QP=31.10 NAL=0 Slice:B Poc:1478 I:639 P:5363 SKIP:1763 size=28280 bytes x264 [debug]: frame= 741 QP=27.97 NAL=2 Slice:P Poc:1488 I:3723 P:4227 SKIP:210 size=76874 bytes x264 [debug]: frame= 742 QP=30.75 NAL=2 Slice:B Poc:1484 I:1024 P:5459 SKIP:1266 size=42398 bytes x264 [debug]: frame= 743 QP=31.80 NAL=0 Slice:B Poc:1482 I:320 P:5253 SKIP:2476 size=21968 bytes x264 [debug]: frame= 744 QP=31.22 NAL=0 Slice:B Poc:1486 I:742 P:4607 SKIP:2529 size=24529 bytes x264 [debug]: frame= 745 QP=28.78 NAL=2 Slice:P Poc:1498 I:4407 P:3719 SKIP:34 size=75099 bytes x264 [debug]: frame= 746 QP=30.65 NAL=2 Slice:B Poc:1494 I:2613 P:4072 SKIP:1050 size=47824 bytes x264 [debug]: frame= 747 QP=31.54 NAL=0 Slice:B Poc:1490 I:84 P:3133 SKIP:4934 size=6427 bytes x264 [debug]: frame= 748 QP=31.33 NAL=0 Slice:B Poc:1492 I:588 P:5583 SKIP:1604 size=33927 bytes x264 [debug]: frame= 749 QP=32.83 NAL=0 Slice:B Poc:1496 I:21 P:1465 SKIP:6668 size=2436 bytes x264 [debug]: frame= 750 QP=28.42 NAL=2 Slice:P Poc:1500 I:2316 P:5384 SKIP:460 size=56132 bytes x264 [debug]: frame= 751 QP=28.16 NAL=2 Slice:P Poc:1508 I:4771 P:3190 SKIP:199 size=74230 bytes x264 [debug]: frame= 752 QP=29.48 NAL=2 Slice:B Poc:1504 I:1127 P:5551 SKIP:1041 size=51136 bytes x264 [debug]: frame= 753 QP=31.86 NAL=0 Slice:B Poc:1502 I:305 P:5320 SKIP:2368 size=22934 bytes x264 [debug]: frame= 754 QP=31.18 NAL=0 Slice:B Poc:1506 I:60 P:2676 SKIP:5414 size=5318 bytes x264 [debug]: frame= 755 QP=28.89 NAL=2 Slice:P Poc:1518 I:4368 P:3673 SKIP:119 size=70602 bytes x264 [debug]: frame= 756 QP=31.26 NAL=2 Slice:B Poc:1514 I:1043 P:5300 SKIP:1361 size=42403 bytes x264 [debug]: frame= 757 QP=31.56 NAL=0 Slice:B Poc:1510 I:253 P:5744 SKIP:1946 size=25958 bytes x264 [debug]: frame= 758 QP=31.18 NAL=0 Slice:B Poc:1512 I:58 P:2308 SKIP:5760 size=5396 bytes x264 [debug]: frame= 759 QP=31.00 NAL=0 Slice:B Poc:1516 I:645 P:5369 SKIP:1953 size=26145 bytes x264 [debug]: frame= 760 QP=28.57 NAL=2 Slice:P Poc:1522 I:2963 P:4924 SKIP:273 size=58736 bytes x264 [debug]: frame= 761 QP=31.46 NAL=0 Slice:B Poc:1520 I:69 P:2055 SKIP:6019 size=4488 bytes x264 [debug]: frame= 762 QP=28.10 NAL=2 Slice:P Poc:1530 I:4328 P:3656 SKIP:176 size=73195 bytes x264 [debug]: frame= 763 QP=30.14 NAL=2 Slice:B Poc:1526 I:1291 P:5349 SKIP:1118 size=44493 bytes x264 [debug]: frame= 764 QP=31.33 NAL=0 Slice:B Poc:1524 I:535 P:5129 SKIP:2329 size=24398 bytes x264 [debug]: frame= 765 QP=30.75 NAL=0 Slice:B Poc:1528 I:691 P:5247 SKIP:1823 size=28662 bytes x264 [debug]: frame= 766 QP=27.77 NAL=2 Slice:P Poc:1538 I:4411 P:3575 SKIP:174 size=72655 bytes x264 [debug]: frame= 767 QP=30.59 NAL=2 Slice:B Poc:1534 I:1143 P:5099 SKIP:1583 size=37041 bytes x264 [debug]: frame= 768 QP=31.45 NAL=0 Slice:B Poc:1532 I:404 P:4978 SKIP:2651 size=21656 bytes x264 [debug]: frame= 769 QP=30.97 NAL=0 Slice:B Poc:1536 I:459 P:4298 SKIP:3235 size=18512 bytes x264 [debug]: frame= 770 QP=29.12 NAL=2 Slice:P Poc:1548 I:4508 P:3561 SKIP:91 size=67886 bytes x264 [debug]: frame= 771 QP=30.40 NAL=2 Slice:B Poc:1544 I:2721 P:3843 SKIP:1148 size=48399 bytes x264 [debug]: frame= 772 QP=31.35 NAL=0 Slice:B Poc:1540 I:68 P:2564 SKIP:5513 size=5797 bytes x264 [debug]: frame= 773 QP=30.65 NAL=0 Slice:B Poc:1542 I:759 P:5512 SKIP:1439 size=36447 bytes x264 [debug]: frame= 774 QP=32.07 NAL=0 Slice:B Poc:1546 I:66 P:2121 SKIP:5947 size=4154 bytes x264 [debug]: frame= 775 QP=28.16 NAL=2 Slice:P Poc:1550 I:2880 P:4912 SKIP:368 size=60181 bytes x264 [debug]: frame= 776 QP=27.90 NAL=2 Slice:P Poc:1558 I:5488 P:2445 SKIP:227 size=68079 bytes x264 [debug]: frame= 777 QP=29.06 NAL=2 Slice:B Poc:1554 I:1295 P:5535 SKIP:899 size=53649 bytes x264 [debug]: frame= 778 QP=31.16 NAL=0 Slice:B Poc:1552 I:290 P:5277 SKIP:2416 size=24305 bytes x264 [debug]: frame= 779 QP=30.93 NAL=0 Slice:B Poc:1556 I:48 P:2444 SKIP:5660 size=5254 bytes x264 [debug]: frame= 780 QP=28.45 NAL=2 Slice:P Poc:1568 I:4753 P:3263 SKIP:144 size=66267 bytes x264 [debug]: frame= 781 QP=30.53 NAL=2 Slice:B Poc:1564 I:1384 P:4961 SKIP:1410 size=41080 bytes x264 [debug]: frame= 782 QP=30.83 NAL=0 Slice:B Poc:1560 I:289 P:5554 SKIP:2066 size=25923 bytes x264 [debug]: frame= 783 QP=30.03 NAL=0 Slice:B Poc:1562 I:96 P:2359 SKIP:5660 size=6073 bytes x264 [debug]: frame= 784 QP=31.13 NAL=0 Slice:B Poc:1566 I:527 P:4376 SKIP:3158 size=18968 bytes x264 [debug]: frame= 785 QP=28.04 NAL=2 Slice:P Poc:1572 I:2983 P:4883 SKIP:294 size=57686 bytes x264 [debug]: frame= 786 QP=30.65 NAL=0 Slice:B Poc:1570 I:92 P:2318 SKIP:5721 size=5569 bytes x264 [debug]: frame= 787 QP=27.82 NAL=2 Slice:P Poc:1580 I:4237 P:3772 SKIP:151 size=67392 bytes x264 [debug]: frame= 788 QP=29.99 NAL=2 Slice:B Poc:1576 I:1189 P:5069 SKIP:1477 size=40117 bytes x264 [debug]: frame= 789 QP=31.09 NAL=0 Slice:B Poc:1574 I:423 P:4475 SKIP:3108 size=19142 bytes x264 [debug]: frame= 790 QP=31.06 NAL=0 Slice:B Poc:1578 I:514 P:4719 SKIP:2535 size=22706 bytes x264 [debug]: frame= 791 QP=27.58 NAL=2 Slice:P Poc:1588 I:4312 P:3692 SKIP:156 size=67614 bytes x264 [debug]: frame= 792 QP=29.87 NAL=2 Slice:B Poc:1584 I:1227 P:5109 SKIP:1432 size=39426 bytes x264 [debug]: frame= 793 QP=31.48 NAL=0 Slice:B Poc:1582 I:427 P:4654 SKIP:2925 size=19990 bytes x264 [debug]: frame= 794 QP=31.30 NAL=0 Slice:B Poc:1586 I:444 P:3871 SKIP:3759 size=16358 bytes x264 [debug]: frame= 795 QP=28.96 NAL=2 Slice:P Poc:1598 I:4604 P:3423 SKIP:133 size=61232 bytes x264 [debug]: frame= 796 QP=30.00 NAL=2 Slice:B Poc:1594 I:2962 P:3597 SKIP:1253 size=45141 bytes x264 [debug]: frame= 797 QP=31.49 NAL=0 Slice:B Poc:1590 I:96 P:1962 SKIP:6095 size=4605 bytes x264 [debug]: frame= 798 QP=30.49 NAL=0 Slice:B Poc:1592 I:893 P:5153 SKIP:1661 size=36406 bytes x264 [debug]: frame= 799 QP=31.39 NAL=0 Slice:B Poc:1596 I:44 P:1814 SKIP:6285 size=3393 bytes x264 [debug]: frame= 800 QP=27.83 NAL=2 Slice:P Poc:1600 I:3780 P:4134 SKIP:246 size=55172 bytes x264 [debug]: frame= 801 QP=27.67 NAL=2 Slice:P Poc:1608 I:5601 P:2445 SKIP:114 size=62510 bytes x264 [debug]: frame= 802 QP=28.74 NAL=2 Slice:B Poc:1604 I:1863 P:4900 SKIP:979 size=49699 bytes x264 [debug]: frame= 803 QP=31.24 NAL=0 Slice:B Poc:1602 I:478 P:4725 SKIP:2801 size=20790 bytes x264 [debug]: frame= 804 QP=30.55 NAL=0 Slice:B Poc:1606 I:79 P:2240 SKIP:5826 size=4927 bytes x264 [debug]: frame= 805 QP=28.48 NAL=2 Slice:P Poc:1618 I:4978 P:3111 SKIP:71 size=65319 bytes x264 [debug]: scene cut at 825 Icost:2860025 Pcost:1055207 ratio:0.6310 bias:89754.5469 gop:275 (imb:2104 pmb:5684) x264 [debug]: frame= 806 QP=30.35 NAL=2 Slice:B Poc:1614 I:1232 P:5170 SKIP:1327 size=40674 bytes x264 [debug]: frame= 807 QP=30.96 NAL=0 Slice:B Poc:1610 I:446 P:5117 SKIP:2388 size=23869 bytes x264 [debug]: frame= 808 QP=29.81 NAL=0 Slice:B Poc:1612 I:79 P:1998 SKIP:6058 size=4869 bytes x264 [debug]: frame= 809 QP=30.97 NAL=0 Slice:B Poc:1616 I:390 P:4439 SKIP:3226 size=17656 bytes x264 [debug]: frame= 810 QP=27.83 NAL=2 Slice:P Poc:1628 I:5757 P:2360 SKIP:43 size=66475 bytes x264 [debug]: frame= 811 QP=29.73 NAL=2 Slice:B Poc:1624 I:2853 P:3966 SKIP:982 size=47462 bytes x264 [debug]: frame= 812 QP=30.35 NAL=0 Slice:B Poc:1620 I:882 P:5303 SKIP:1549 size=34856 bytes x264 [debug]: frame= 813 QP=30.41 NAL=0 Slice:B Poc:1622 I:667 P:5519 SKIP:1549 size=36470 bytes x264 [debug]: frame= 814 QP=30.51 NAL=0 Slice:B Poc:1626 I:1233 P:5330 SKIP:1207 size=42379 bytes x264 [debug]: frame= 815 QP=24.14 NAL=2 Slice:P Poc:1636 I:8142 P:18 SKIP:0 size=90658 bytes x264 [debug]: frame= 816 QP=29.13 NAL=2 Slice:B Poc:1632 I:869 P:5259 SKIP:1886 size=34983 bytes x264 [debug]: frame= 817 QP=31.42 NAL=0 Slice:B Poc:1630 I:163 P:4497 SKIP:3200 size=16594 bytes x264 [debug]: frame= 818 QP=30.44 NAL=0 Slice:B Poc:1634 I:2251 P:4430 SKIP:1171 size=47540 bytes x264 [debug]: frame= 819 QP=24.88 NAL=2 Slice:P Poc:1648 I:819 P:5717 SKIP:1624 size=37264 bytes x264 [debug]: frame= 820 QP=29.75 NAL=2 Slice:B Poc:1642 I:207 P:3118 SKIP:4759 size=9297 bytes x264 [debug]: frame= 821 QP=34.40 NAL=0 Slice:B Poc:1638 I:54 P:1736 SKIP:6360 size=2225 bytes x264 [debug]: frame= 822 QP=29.14 NAL=0 Slice:B Poc:1640 I:4 P:774 SKIP:7378 size=1037 bytes x264 [debug]: frame= 823 QP=32.59 NAL=0 Slice:B Poc:1644 I:12 P:1631 SKIP:6493 size=2959 bytes x264 [debug]: frame= 824 QP=30.93 NAL=0 Slice:B Poc:1646 I:18 P:2212 SKIP:5910 size=3040 bytes x264 [debug]: frame= 825 QP=21.99 NAL=2 Slice:I Poc:1650 I:8160 P:0 SKIP:0 size=119399 bytes x264 [debug]: frame= 826 QP=25.14 NAL=2 Slice:P Poc:1664 I:1300 P:5320 SKIP:1540 size=41522 bytes x264 [debug]: frame= 827 QP=31.99 NAL=2 Slice:B Poc:1658 I:370 P:3023 SKIP:4655 size=11305 bytes x264 [debug]: frame= 828 QP=32.21 NAL=0 Slice:B Poc:1652 I:84 P:2693 SKIP:5344 size=5469 bytes x264 [debug]: frame= 829 QP=31.66 NAL=0 Slice:B Poc:1654 I:176 P:3226 SKIP:4683 size=8554 bytes x264 [debug]: frame= 830 QP=32.30 NAL=0 Slice:B Poc:1656 I:171 P:3089 SKIP:4787 size=8668 bytes x264 [debug]: frame= 831 QP=32.17 NAL=0 Slice:B Poc:1660 I:80 P:2980 SKIP:5036 size=6521 bytes |
#7 | Link |
Question about scenecut parameter : Is the value of parameter independant of image size ?
If not, for what image size the default value [40] is set for, and how it should be adjusted according image size ? |
encoding, i-frame, scenecut, x264 |
