Old 4th July 2011, 15:49   #1  |  Link
nusrat1990
VC1 pro sdk Encoder speed
Hello.
I am using VC1 pro SDK encoder.
my app transcodes mpeg2 elementary stream ->vc1 AP.
The app must work in realtime (live broadcasting).
mpeg2 es source is 20 mbit/s 1920x1080
I do mpeg2 decoding using libmpeg2, it's very fast.
Bottleneck in vc1 encoder part, which is at least 3-5 times slower than decoder.
my processor is : i7 920(2.6 ghz)
I tried to decrease encoder definition from 1920x1080 to 960x540. it worked. Decoded frames count equal to encoded, but I need to use 1-pass CBR with bitrate specifying, so decreasing definition is not suitable.
also app uses 4 - 10 threads of encoding. i send to each encoder thread 15-35 frames.
current settings are:
-peakrate 0
-rate 0
-profiletype 2
-bframes 7
-maxkeydist 1000
-vbv 0
-ratecontrol 1
-qp 8
-maxw 1920
-maxh 1080
-complexity 0
-framerate 30
Are there any other settings which can increase speed of encoding?
If here are professionals about vc1 pro encoder sdk, please help me.
Thanks,
Nusrat
nusrat1990 is offline   Reply With Quote
Old 4th July 2011, 16:18   #2  |  Link
Midzuki
Unavailable
Midzuki's Avatar
I am not a pro, but while Ben Waggoner is not around...
-peakrate 0
-rate 0
-profiletype 2
-bframes 7
-maxkeydist 1000
-vbv 0
-ratecontrol 1
-qp 8
-maxw 1920
-maxh 1080
-complexity 0
-framerate 30
try -bframes 1 and -maxkeydist 300
Midzuki is offline   Reply With Quote
Old 4th July 2011, 16:38   #3  |  Link
kieranrk
Are you serious? Using a dead codec for live broadcasting?
kieranrk is offline   Reply With Quote
Old 4th July 2011, 16:58   #4  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Ooops, I hadn't noticed that detail
Anyway
-bframes 0 and -maxkeydist 60
Old 4th July 2011, 21:14   #5  |  Link
nusrat1990
Are there any other vc1 codec?
I tried intel codec in IPP. Its perfomance is even worse.
Anyway
I tested to set bframes to zero.
But I got error code: -30.
That means only one thing: this setting conflicts with something. very strange.
Why decreasing definition is not suitable.
in 1-pass CBR i specify
-rate 5000
-vbv 2500000
which means half second buffer
Now bitrate will be less than 5000 because i decreased definition, so how can i predict how less it will be?
Performance should be enough to use low buffer.
as i unsderstand from documentation:
lim(real_bitrate) = specified_bitrate;
(vbv -> 0)
I will try to guess, with what "-bframes 0" conflicts.
Old 4th July 2011, 21:42   #6  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
It seems MainConcept has an VC-1 SDK for sale:
http://www.mainconcept.com/products/...ideo/vc-1.html
I have no idea about it's quality/performance through...
Old 4th July 2011, 23:17   #7  |  Link
mp3dom
MainConcept VC-1 implementation is quite poor (at least with previous SDK). Even if PSE/PEP is dead and slow, I think it's still the best implementation available.
If nusrat is obliged to use VC-1 for streaming he can think to go with hardware. There are some solutions from Inlet (hardware board encoders).
more info: http://www.compumodules.com/professi...les/fathom.pdf
Old 5th July 2011, 00:12   #8  |  Link
kieranrk
Why don't you use MPEG-4/AVC like everyone else using a post-MPEG-2 codec? No television broadcasts have ever been done in production with VC-1.
Old 5th July 2011, 01:08   #9  |  Link
Midzuki
Unavailable
Midzuki's Avatar
TinTime built a mod of AVS2ASF which fixed that problem and others as well. Download it (source-code included) from:
http://www.mediafire.com/file/ztl0tdilg4n/AVS2ASF.zip
or from:
http://forum.videohelp.com/threads/3...=1#post2067819
BUT, in the end, I have to agree with both kieranrk and mp3dom VC-1 was poisoned by Microsoft's incurable "ASF-mania", this is the reason why it sux pig time
Old 5th July 2011, 08:17   #10  |  Link
nusrat1990
or from:
Midzuki,
Yes, in original vc1 sample encoder has error. bdeltaqp conflicts with bframes.
But performance is still bad.
Hardware solution is not flexible,
there is no udp based input and output.
Also my app should work like pipeline, no file using allowed.
MainConcept is slow.
I have to use 1-pass VBR with definition decreasing...
Thanks to everybody for help.
Project completed.
P.S. it's not my decision of using vc1. It's actually not television broadcasting, it's rather comp to comp broadcasting.
Old 3rd August 2011, 23:12   #11  |  Link
benwaggoner
Hmmm. A few questions
  • How many milliseconds of latency can you live with?
  • What OS are you running on? Would it be feasible to run on Windows 7?
  • Have you looked at licensing the VC-1 Encoder SDK Enterprise version instead? That's the one with all the IPTV broadcast tuning
The Pro SDK is relatively old code at this point. The encoder in Windows 7 has substantial performance improvemence (8-way threaded, and 40% faster when using B-frames). So if you're trying to do a live HD broadcast of WMV, that would do the job better and more easily. Just make sure to set the PropertyBucket parameters optimally.
Alternatively the Enterprise version of the SDK is the one with the good live encoding tuning, including Lookahead Rate Control and Dynamic Complexity. That's what gets used for all the Silverlight HD live sports broadcasting (Olympics, Wimbleton, and so on). Inlet's Spinnaker VC-1 live encoder runs this library on a bunch of Intel cores.
Your settings could also use some tuning
  • 1 B-frame is generally optimal for film/video content. Using 7 will hurt quality and probably performance as well.
  • Don't set BdeltaQP. If you leave the parameter unset, you'll get the dynamic mode which is almost always best.
  • Why QP=8?
Ben Waggoner
My Compression Book
encoding, performance, vc1prosdk
