Old 29th April 2009, 13:05   #21  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Originally Posted by chaynik View Post
I've had great luck uploading FFV1 (ffmpeg's implementation of huffyuv) to youtube.
FFV1 has absolutely nothing to do with HuffYUV.
Unlike huffyuv, ffv1 supports the 4:2:0 colorspace (native to h264, mpeg4, mpeg2, etc) and has some adaptive routines to further shrink down the size while remaining lossless. Perfect intermediate IMO for youtube uploads.
Perhaps you meant FFVHUFF, not FFV1?
Old 29th April 2009, 13:28   #22  |  Link
chaynik
Yes, that's what I meant. My mistake.
chaynik is offline   Reply With Quote
Old 29th April 2009, 18:38   #23  |  Link
zilog jones
zilog jones's Avatar
That is interesting that it accepts at least one lossless codec. Anyone tried FFV1 or any others? What about MJPEG?
Regarding the vertical resolution halving issue with 480 line HQ videos, this definatley occurs with HD 720p videos too This must have been what was happening to imk's videos. To get good results with my PAL videos for both HD and HQ I upscaled to 1536x1152 - obviously being VHS sources they look quite blurry in "HD" but in the standard YouTube window they're not too shabby and there's no serious blocking or anything.
I have noticed apparent dropped frames with some of my HD videos played in HQ mode - it looks like frames are being dropped when playing within the website or using MPC+ffdshow, but when playing in VLC they look fine. Reported framerate is still 25fps. Any ideas?
zilog jones is offline   Reply With Quote
Old 29th April 2009, 20:03   #24  |  Link
imk
|ン、)
imk's Avatar
Not related to quality entirely, but I found that if I upload a really high-quality MP4, YouTube will actually re-encode it with video and audio out of sync. The video will play choppy, too.
http://www.youtube.com/watch?v=hmuRCUJmDik&fmt=22
If I upload a MKV instead of a MP4, it seems to handle it fine.
imk is offline   Reply With Quote
Old 29th April 2009, 20:40   #25  |  Link
zilog jones
Yes, MKV seems to be the most reliable containter - I've uploaded >20Mbit/s x264 video with no problems.
I've also noticed if you upload HD video with no audio, it will not play it back properly within the website - the loading circle keeps flickering in the centre throughout playback. If you download the video it will play fine though. I didn't try using AudioSwap to see if it is just the lack of an audio stream that causes this.
Old 1st May 2009, 21:22   #26  |  Link
JohannesL
AviSynth/x264 user
JohannesL's Avatar
I use 720p x264 encoded H.264 with --crf 20 and pretty basic settings for all of my videos, and it turns out pretty good: http://www.youtube.com/watch?v=5dYl8...el_page&fmt=22
archlinux
JohannesL is offline   Reply With Quote
Old 1st May 2009, 23:32   #27  |  Link
zilog jones
That video seems to suffer from the same issue I noticed when uploading 720p, i.e. it is vertically blurred. It's very noticeable if you download the video (using one of the many Firefox plugins for example) and watch it at full size. What resolution was it rendered at? I assume it's from an emulator. You should try uploading at something like 1280x960 and compare the difference.
Old 16th May 2009, 14:22   #28  |  Link
JohannesL
AviSynth/x264 user
JohannesL's Avatar
In the beginning, only 1280x720 uploads would get HD on YouTube. SM64 is 1.429 letterboxed to 4:3, so for a while, I cropped out the borders, scaled to 1028x720 and pillarboxed to 1280x720. I recently found out any video with a height above 720 will get HD now, so I tried to crop out the borders and scale to 1280x896 and upload, and YouTube downscaled it to 1028x720. The quality is a bit better than my 1280x720 uploads.
archlinux
Old 17th May 2009, 04:26   #29  |  Link
10L23r
is it better to upload a 640*480 vid or a 480*360 vid for regular (not hd) viewing? what resize algorithm does the encoder use?
and, does anyone know how the hell youtube's entire encoding process works
10L23r is offline   Reply With Quote
Old 17th May 2009, 04:46   #30  |  Link
Dark Shikari
x264 developer
It's just your standard mencoder chain.
Old 26th May 2009, 11:50   #31  |  Link
chaynik
Why mencoder and not ffmpeg?
Old 26th May 2009, 13:21   #32  |  Link
Trahald
Wewkiee
Trahald's Avatar
Yeah... I post stuff with no audio and noticed that too. Never made the connection. I need to put a silent audio track in.
...yeah...but...why on earth would I compare apples with apples?
Trahald is offline   Reply With Quote
Old 26th May 2009, 14:04   #33  |  Link
Dark Shikari
x264 developer
Better for handling bizarre proprietary formats due to w32codecs, probably.
Old 18th June 2009, 14:57   #34  |  Link
JohannesL
AviSynth/x264 user
JohannesL's Avatar
Using this Avisynth script on a 640x448 RGB video game source:
function nnedi22x(clip a) {return a.nnedi2(1,true).turnright().nnedi2(1,true).turnleft().spline36resize(a.width*2,a.height*2,-0.5,-0.5)}
avisource("Direct64.avi")
lumvid = ConvertToYV12().NNEDI22x()
chromvid = PointResize(Width()*2,Height()*2).ConvertToYV12()
MergeChroma(lumvid,chromvid)
LimitedSharpenFaster()
(Results in 1280x896 YV12)
And then encoding with x264 at CRF 21 and uploading, I got this quality:
http://www.youtube.com/watch?v=Uazn8oNRYVg&fmt=22
archlinux
x264 for youtube, youtube, youtube higher quality, youtube hq videos
