Old 8th July 2002, 21:51   #81  |  Link
Koke
Koke's Avatar
Someone uses ffdshow filter for them all codecs
or I overlooked that?
Why using so complicated solutions?
Koke is offline   Reply With Quote
Old 16th July 2002, 17:09   #82  |  Link
esby
esby's Avatar
ffdshow got decode error with div3 content too
a very few but noticable.
according to the ffdshow coders, it comes from libavcodec ...
esby
PS:
you can find two samples showing the bugs there :
http://www.chez.com/esbyphp/sample.rar
( if you got an error - copy paste the link in a blank navigator)
Update - with divx 5.05+ the bugs won't show anymore.
esby is offline   Reply With Quote
Old 1st August 2002, 00:10   #83  |  Link
midiguy
FFDSHOW has a bug in its post-processing... I posted about it in this thread:
http://forum.doom9.org/showthread.php?s=&threadid=29434
if you read the last 3-4 posts, you will get an idea about what I am talking about..
midiguy is offline   Reply With Quote
Old 1st August 2002, 00:18   #84  |  Link
midiguy
esby
PS:
in the sample AVIs, I was looking at the subtiutles, and they RULE!!! what font is that?? anyone know??
Old 28th September 2002, 00:47   #85  |  Link
qyv
copied from the readme.txt...
If you can play all of these clips without any glitches, you dont need to read this.
This is a fix to the divx3fix.reg originally posted to the doom9.org forum.
It allowed you to install divx 5 and continue playing divx 3.11 with the original codec. You can check this with the sample divx 4.12 video, since the divx 5 codec also has the glitch.
The problem was that with the fix, AntiFreeze stopped working, so this new fix changes the priority of 80 to 85 in both the divx 3.11 and AntiFreeze registry. Also works in Win98 now, as well as Win2k and WinXP.
Make sure divx 3.11, divx 5, and AntiFreeze (DivxAF) is installed, before doubleclicking on the .reg files.
http://www2.hawaii.edu/~rnakahar/Divx_3-5-AF_fix.zip
qyv is offline   Reply With Quote
Old 2nd January 2003, 23:50   #86  |  Link
plato
You can try the following,
un-instal divx5
reboot
install crystal codec 4.3.3
reboot
instanll divx 5 pro
reboot
All is fine. I do not use xvid so not sure about that.
plato is offline   Reply With Quote
Old 16th March 2003, 13:49   #87  |  Link
Lutzifer
EDIT: i fixed my problem (a mod can delete this post )
Lutzifer is offline   Reply With Quote
Old 15th July 2004, 23:48   #88  |  Link
Arcon
i just installed divx 5.2 and it plays all divx3 files
i tried the methods from the first post but i can't get divx3 back. i patched the divx_c32.ax, i edited the registry to increase the priority and i checked the priority of the divxdec.ax from divx5.2 (its 80 in the registry, divx311 got 90) but it still gets chosen by bsplayer and mplayer for div3 or DIV3 files. i tried to patch the 4cc's in the divx 5.2 ax-file but it's got a crc-check.
since it worked for the 5.1.1 decoder but not for this one i wonder what the cause of this problem might be. how can he override the ds-filter priority?
UPDATE: i tried the first method again (overwriting all 4cc codes manually in the registry) and this worked (after a reboot). don't know why the priority-thing didn't work though.
Arcon is offline   Reply With Quote
Old 8th September 2004, 16:33   #89  |  Link
esby
esby's Avatar
Well that might now please some people:
but there is still a somewhat elegant solution:
do not install divx5.
if you want divx5 decoding,
decode with xvid, ffdshow or even ffvfw.
if you want div3 decoding by divx3.11 codec, just set it correctly in ffdshow or ffvfw, depending in which context you are.
But most of the decoding related problems we were talking of in this thread are gone long since...
esby
PS: of course, the smarter solution would be that divx5 people release a version of the codec decoding only divx5.
Old 8th September 2004, 16:46   #90  |  Link
Chibi Jasmin
If you want to make the DivX3 Priority Patch work again with DivX 5.2, you can do the following:
Look here:
[HKEY_CLASSES_ROOT\CLSID\{083863F1-70DE-11d0-BD40-00A0C911CE86}\Instance\{78766964-0000-0010-8000-00AA00389B71}]
and here:
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{083863F1-70DE-11d0-BD40-00A0C911CE86}\Instance\{78766964-0000-0010-8000-00AA00389B71}]
in the filter data entries...the 8th byte now reads FF instead of 00 which it reads in the other 4 locations mentioned in first post...replacing the FF with 00 in these two locations makes the priority patched Div3 work again...bit easier than to overwrite the fourccs in the filter data entry, but still not an elegant solution.
Better alternative:
Do the exact opposite to the Div3 Priority Filter Data (leaving the DivX5 Filter data alone), that means in these two locations replace the 8th byte 00 with FF:
[HKEY_CLASSES_ROOT\CLSID\{083863F1-70DE-11d0-BD40-00A0C911CE86}\Instance\{82CCD3E0-F71A-11D0-9FE5-00609778AAAA}]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{083863F1-70DE-11d0-BD40-00A0C911CE86}\Instance\{82CCD3E0-F71A-11D0-9FE5-00609778AAAA}]
This is the better version in my opinion, because Div3 don't get updated anymore and you won't have to repeat this process, every time you install a new DivX5 (as you would have with first version)
Still no ideal thing, maybe someone can patch DivXC_32.ax again to include the 90 FF (7th-8th byte filter data) now instead of 90 00...
Chibi Jasmin is offline   Reply With Quote
Old 28th December 2005, 02:45   #91  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Why not use GSpot 2.52 beta in Expert version and set Filter Merit to 200000 and above for both DivXc_32.ax and DivXAF.ax and set DivXDec.ax to 8000 respectively MERIT_PREFERED.
shon3i is offline   Reply With Quote
