26th August 2016, 15:10 | #1 | Link |
Ultra HD Blu-ray
I have a question, is there a way to decrypt Blu-ray Ultra HD on a PC ? Actually, i have a Blu-ray Player who read Ultra HD Blu-ray (LG BH16NS55) but there is no software to read the content (i use a Xbox One S to watch it). The structure seems the same as classic Blu-ray, i suppose that with the key, it's possible to decrypt the content. |
26th August 2016, 15:21 | #2 | Link |
Are you sure the LG BH16NS55 is UHD compatible ? I don't find any mention of that about this model.
AACS 2.0 hasn't been cracked yet ; https://www.reddit.com/r/Piracy/comm...k_bluray_rips/ http://arstechnica.com/gadgets/2016/...d-for-a-while/ |
26th August 2016, 22:14 | #6 | Link |
47.952fps@71.928Hz
According one professor here, you only need AACS 2.0 for decrypting audio only.
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
27th August 2016, 02:47 | #8 | Link | ||
Blu-ray Discs use UDF 2.5 as their filesystem. That's not the problem, and it's not really related to the optical drive. You could probably put one of the UHD Blu-rays in a first-generation BDXL-capable drive accessed by Windows Vista with stock drivers and it'd show the contents of the disc just fine. It'd probably even be fine if the filesystem on UHD Blu-ray is UDF 2.6 (still >10 years old) rather than 2.5.
The problem is AACS 2.0 not being broken. It's not inconceivable that studios could face such a backlash or early implementation problem from AACS 2.0 that they might issue some discs with the first version of AACS like with regular Blu-ray. I just highly doubt that. Highly. Quote:
27th August 2016, 11:06 | #9 | Link |
I've spent some time digging through Sony WikiLeaks stash, here's what I've found.
UHD Bluray-Discs are basically BDXL discs, so some drives might read them. It is not official though and not mentioned on the box or in the specs. Note that not all BDXL drives are capable of this, I'm not sure why. AACS 2.0 has some similarities with AACS 1.0. It obviously encrypts all the audio and video content on the disc. Problems: - host/drive certificates and any kind of device/processing key are completely separate, keys/certs from AACS 1.0 will not work - AACS 2.0 discs can be either offline or online, offline let's you play the disc in a usual way if you have device keys, online discs require Internet access to get proper decryption keys (I have no idea what kind of discs are currently available) - they've made some attempts to secure the online protocol, it probably will not be sufficient to just replay the request sent by legitimate player - since drive/host certs are separate (and in different format, with longer key and signature) this probably means that a new method of retrieving VID must be implemented by the drives; this means that while BDXL drives can read UHD discs, they will not be able to perform AACS 2.0 auth and retrieve VID (this obviously might be possible with a firmware upgrade, but I guess drive manufacturers will prefer to sell you a new drive) - there are no PC software players capable of AACS 2.0 yet, so there is no place to try to extract any keys/certs - there is no public specification (unlike AACS 1.0) and there won't be one All of this is based on various drafts and presentations, so it might as well all work differently. Unfortunately it seems that there won't be any progress with AACS 2.0 until official UHD supporting PC drives and software players are available. Unless you can reverse engineer hardware players |
27th August 2016, 12:15 | #10 | Link |
Life's clearer in 4K UHD
Okay...
If you put aside the data decryption side of things. Can people extract all the data from UHD disc's with one of these LG BH16NS55 drives? Cheers
27th August 2016, 12:25 | #11 | Link | |
I have tried with many BD-XL drive and they can't read Ultra HD BLu-ray. It's a new generation. There is difference between Ultra HD BLu-ray and BDXL, this paper explain that : http://www.blu-raydisc.com/Assets/Do...0817_clean.pdf Actually, a drive compatible with BD-ROM4 (https://www.blu-raydisc.info/content...ction-rom4.php) is an obligation, and LG is the only manufacturer who made that. |
4th September 2016, 11:27 | #15 | Link |
I've also found an interesting presentation: http://www.cptwg.org/assets/2015/201...esentation.pdf
15th September 2016, 19:17 | #16 | Link |
I have bought BH16NS55 and Deadpool UHD Blu-Ray disc.
First, some impressions about the drive. Yes, it can read UHD Blu-Ray. Deadpool is a two layer UHD disc with 33GB per layer. There are also three layer discs, with the same data density, like Batman vs. Superman, but I haven't tested that (will not spend money on that piece of crap). While it reads UHD discs, it is kinda unreliable. From time to time it simply refuses to work and returns various errors. Usually reloading the disc fixes the problem, but one time I had to power it down, otherwise it refused to work at all. I was able, on the second try, to make image of Deadpool disc with data transfer not leaving 10-20MB/s range. It might be just an unreliable disc, I don't have a second one yet. The drive does not support AACS 2.0, so it almost surely will not work with software players, if they become available. Now onto AACS 2.0, which is more interesting. The overall disc structure seems the same. UHD disc does not contain BD+ (normal Blu-Ray counterpart is BD+). It does have bus encryption enabled, which seems mandatory for AACS 2.0. The MKB file has the same basic structure like those from AACS 1.0. It reports itself as a MKBv60. It has a new type and several new record types with unknown purpose. It is signed with a different AACS LA certificate, which was expected. Host and driver revocation lists are exactly the same like those found on normal Blu-Ray MKBv60 discs. This makes sense, as drives would need to maintain only a single list of host certs to revoke (AACS 2.0 certificates use longer keys, but the certificate ID space seems shared). The subset-difference tree seems to be much larger, instead of usual 562 entries there are now 181250 (number of C-values record entries to be precise). I've tried running AACS 1.0 auth for this disc. Surprisingly... it was successful. I was able to read VID, PMSN and Read Data Key (used by bus encryption). Now, onto some speculation why it works and what does it mean. My guess is that AACS 1.0 drives are not supposed to read UHD discs. Both VID and PMSN are simply some values store on disc, that are not accessible in normal way. Drive is perfectly able to read them, but reading is protected by AACS-authentication process, which requires host certificate. If we assume that AACS 2.0 stores those values at the exactly the same place as AACS 1.0, then AACS 1.0 drive, capable of reading UHD discs, will gladly read them, provided AACS 1.0 host certificate. Bus encryption is somewhat different, (some) disc sectors have some low level markers that tell the drive to encrypt them on the fly. Getting the decryption key from the drive also requires AACS-authentication. If the same markers are used by AACS 2.0 (I don't see why not, it is kinda low level thing) then AACS 1.0 drive will handle this perfectly fine, if it can read the disc. Which we know it can If the above is correct, then it means that this kind of drive kinda defeats part of AACS 2.0. But, don't get your hopes too high. The values (VID, etc.) I was able to retrieve could be completely bogus. Also, to fully decrypt AACS 2.0 we would need device/processing/volume key. There were no new device/processing keys available even for AACS 1.0 for a few years and we don't have any player/ripper to extract volume key from. Disc information: Code:
Disc ID: F58AA868C40D5894C332F9BDB978522432D5CC82 VID : 55F4D4B1F77D26D0E7A9D55DA5599AA7 MKBv : 60 PMSN : will not provide for obvious reasons, but was able to read it Bus encryption: Device support: yes Enabled in media: yes Content Certificate ID: 006F8005EF00 BD-J Root Cert hash: 0000000000000000000000000000C73B53981817 Device binding ID: some random value generated by my PC Host Revocation List (MKB version 60): 000000000001 - 0000000003e8 000080000001 - 0000800080e8 270f80000001 - 270f80000bb8 ff2210100001 - ff221010001f ff2210400001 - ff221040001f ff2220000001 - ff22200000ff ff2290100001 - ff229010001f ff2290400001 - ff229040001f ff22a0000001 - ff22a00000ff ff2318000001 - ff231800001f ff2318100001 - ff231810001f ff2318400001 - ff231840001f ff2340000001 - ff23400000ff ff2710000001 - ff271000001f ff2790000001 - ff279000001f ffff0000000b - ffff00000014 ffff00000016 ffff00000021 - ffff0000002a ffff00000035 - ffff00000038 ffff0000004e - ffff00000052 ffff00000054 - ffff00000057 ffff0000005d - ffff00000066 ffff00000080 ffff00000088 - ffff00000091 ffff00000094 ffff000000ae ffff000000b2 - ffff000000bb ffff000027db ffff00002817 ffff00002820 ffff00002834 - ffff0000283d ffff00002846 ffff0000284b ffff80000001 - ffff80000024 ffff80000029 ffff8000002f ffff80000039 ffff80000045 ffff80000071 ffff80000079 ffff8000007c - ffff8000007e ffff800000ad ffff800000c4 - ffff800000c6 ffff800000d0 ffff800000f4 - ffff800000fd ffff80000146 Drive Revocation List (MKB version 60): 000000000001 - 0000000003e8 000080000001 - 0000800055f0 270f20000001 - 270f20000514 270f80000001 - 270f800007d0 ff2600000001 - ff2600000096 Last edited by dizzier; 15th September 2016 at 19:48. |
15th September 2016, 21:06 | #17 | Link | |
15th September 2016, 21:31 | #19 | Link | |
- processing keys are present in the firmware, however, as I've said, the cryptography of PS3 was not broken; they fixed their usage of cryptography and then released a new firmware, using it correctly with new keys; while you can update it you cannot decrypt it and thus you cannot get hold of the new processing keys - after PS3 screw up AACS discs were switched to use different processing key for each disc; there is nothing in the spec that forbids it and it was even noticed on this forum - they've fixed it by making the MKB treatment online; PS3 sends MKB file to Sony servers, they provide VUK in response, that way no processing or device key is present on the console - nobody skilled looked at it for a while |
6th December 2017, 20:03 | #20 | Link | |
According to this post on the MakeMKV forum the VID retrieved using the AACS1 cert is valid. Therefore it should be possible to play the discs for which a VUK is known. So if there is anyone that has one of these AACS1 UHD-friendly drives and also has one of the discs for which a VUK has been posted here , please try to play it in VLC and post the results |
