4th December 2011, 02:51 | #1 | Link |
x264 lossless (or nearly lossless) settings for Adobe software
I like the idea of using x264 for lossless or nearly lossless encoding of sources processed in AviSynth for later use in Premiere and After Effects. However, I have yet to find a setting that yields a such a file that can be imported successfully. Does anyone know of settings that would be appropriate for this?
4th December 2011, 03:56 | #2 | Link |
i notice, for Adobe sw, that rgb encodings importing are faster than yv12 ones, so imho lagarith (rgb 24/32bit) do this work right.
powered by Google Translator Last edited by Motenai Yoda; 4th December 2011 at 21:29. |
4th December 2011, 08:13 | #3 | Link |
Thanks for the reply, and you are correct for the most part. Lagarith and Ut do work quite well; especially in After Effects, which is an RGB program through-and-through. They edit nicely in Premiere also. Since CS5, Premiere is also much native YUV functionality (in fact, it seems to handle LAGS YV12 very nicely). It also has a lot of H.264 support (because of AVCHD camcorders, etc.) so I am wondering if there is a way to make some kind of AVC Intra lossless/virtually lossless that Premiere can parse. Using x264 --qp 0 is no good, as Premiere cannot understand files that have been generated this way. Perhaps there are other setting which could conform compatibility, which was the reason for my question. I am hoping to benefit from the more efficient H.264 compression, as compared to the much larger lossless AVIs.
4th December 2011, 13:06 | #4 | Link |
I think the H.264 support that Premiere has does not include lossless mode, my understanding is that this is normal - no camcorder is going to use lossless mode after all.
Just use a very low crf (will it import --crf 1 ?) but it will be lossy compaired to UT or lagarith. |
4th December 2011, 21:10 | #5 | Link | |
Sometimes the video will cause a failure on import (like, "The file is damaged or unsupported") while other times it imports but all the frames appear 100% green in Premiere. |
4th December 2011, 21:22 | #6 | Link |
Software Developer
Well, true "lossless" mode, as implemented by x264, requires the "High 4:4:4" Profile. Adobe's H.264 decoder probably doesn't support that profile.
Also when using something like "--crf 1" you are likely to get a very high bitrate. So the resulting stream may easily come out at some Level that isn't supported by the decoder. However, as far as I know, the Level's usually are not a problem with pure software decoders. But you never know. Their decoder may be picky...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 4th December 2011 at 21:32. |
4th December 2011, 22:08 | #7 | Link | |
It's kind of a shame: Even the --crf 0 and --crf 1 options tend to produce significantly smaller files than Lagarith. And, since the world is essentially going H.264 across the board, it would be kind of nice to leave AVI files behind. |
4th December 2011, 22:19 | #8 | Link |
Software Developer
You might try something like "--crf 12", which still should be (extremely close to) "visually lossless" quality, but come out at a much lower bitrate.
Or you might use Premiere with Avisynth input. I don't use Premier, but I know that an Avisynth plugins exists: * http://neuron2.net/www.math.berkeley...-premiere.html * http://urchin.earth.li/~tomford/avisynth/ This way you should be able to decode the input with FFmpegSource2, which uses the libavcodec H.264 decoder and thus supports almost everything A very simplistic AVS script should be sufficient: Code:
FFVideoSource("C:\Path to your input\source.mkv")
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 4th December 2011 at 22:21. |
5th December 2011, 21:12 | #9 | Link | ||
However, with CS5, everything is 64-bit so those plugins do not work anymore. (and the neuron2 plugin there has not worked for a long time, I believe, as it was written for older versions of both AviSynth and Premiere). Quote:
One issue/question (and I know this has been discussed on here but I never really found an answer to my satisfaction): When I mux the file with mp4box, the framerate defaults to 25 fps. I understand that I can use, for example, mp4box -fps 29.97, but I wonder:
** EDIT ** OK, duh … answered my own question x264 --force-cfr Last edited by vampiredom; 5th December 2011 at 21:37. |
12th December 2011, 23:40 | #10 | Link |
Anime addict
Visit http://forum.doom9.org/showthread.ph...ighlight=pismo, you can load avs file in premiere cs5.5 or above.
Bye
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
16th December 2011, 01:37 | #11 | Link |
I did some testing in the past about x264 loading into premiere. I believe you need to set it to use only keyframes (--keyint 1, i think), and also it does not support lossless, but you can use qp 1.
I also find that premiere usually interprets the fps of the file incorrectly, so its necessary to manually set it through "interpret footage" |
9th January 2012, 16:43 | #12 | Link |
I've made a quick and dirty test and I've managed to get crf 1.1 to load in both After Effects and Premiere CS 5.5. I didn't check the audio or any deep scrubbing but I think I remember the first few frames as being black (yup, I used b-frame compression)
CRF 1.1 was the same size as CRF 2 at ~30MB, ultrafast was twice the size at ~60MB, and LAGS was about 90MB. I can't remember the original size of the MTS Another strange thing that happened is that both AE and Premiere loaded MTS files from my Panasonic GH2 before and now both are refusing to do it (same files). I guess the fact that I have a unstable CS 5.5 install might have a lot to do with this... |
10th January 2012, 22:28 | #14 | Link |
brontosaurusrex
in premiere cs 5.5 (on osx) was possible to edit 1920x1080 avc stuff directly from canon 7D (not exactly smooth, but bearable), so maybe that could be a starting point for a cool preset.
/Volumes/raid0/mvi_2330.mov General Complete name : /Volumes/raid0/mvi_2330.mov Format : MPEG-4 Format profile : QuickTime Codec ID : qt File size : 75.8 MiB Duration : 15s 600ms Overall bit rate : 40.8 Mbps Encoded date : UTC 2010-10-09 16:18:54 Tagged date : UTC 2010-10-09 16:18:54 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L5.0 Format settings, CABAC : No Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=12 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 15s 600ms Bit rate : 39.2 Mbps Width : 1 920 pixels Height : 1 080 pixels Original height : 1 088 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.757 Stream size : 72.9 MiB (96%) Language : English Encoded date : UTC 2010-10-09 16:18:54 Tagged date : UTC 2010-10-09 16:18:54 Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M Audio ID : 2 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : sowt Duration : 15s 600ms Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 2.86 MiB (4%) Language : English Encoded date : UTC 2010-10-09 16:18:54 Tagged date : UTC 2010-10-09 16:18:54 ---------------------------------- droped files: /Volumes/raid0/mvi_2330.mov ---------------------------------- MediaInfo Command line, MediaInfoLib - v0.7.51
certain other member |
4th February 2012, 22:22 | #15 | Link | |
27th January 2022, 11:14 | #16 | Link | |
Voukoder Use the best encoders available in your favorite NLE. What is the Voukoder? Voukoder is system wide video- and audio encoding service for Windows that improves your media encoding experience. It supports various encoders (both CPU and GPU based) and also provides a set of post processing filters. Currently supported are: • DaVinci Resolve 17 • Adobe Premiere (CS6 and later) • Adobe Media Encoder (CS6 and later) • Adobe After Effects (CC 2015 and later) • VEGAS Pro 12-19 • VirtualDub2 Voukoder is incredibly fast! If you have a video card with hardware encoding capabilities you could get an encoding speed of 4-8 times faster than in real time (depending on your project). Download & Install You will find all required installation packages in the download menu at the top. 1. the First download and install the main "Voukoder" application 2. Next download and install the "Connector plugin" for your favorite video editing application Main plugin: https://github.com/Vouk/voukoder/rel...koder-10.2.msi Connector: PP/AME: https://github.com/Vouk/voukoder-con...0.msi?raw=true AE: https://github.com/Vouk/voukoder-con...0.msi?raw=true |
16th February 2022, 02:04 | #17 | Link |
There are some new plug-ins for Premiere that are worth a look. After Codecs adds a x264/x265 encoder for export. Influx adds import support for FFV1 and other codecs. I bring these plug-ins up because Voukoder is Windows only, while the Autokroma plug-ins are cross platform for Windows and Mac.
https://www.autokroma.com |
