Old 13th May 2024, 21:38   #1  |  Link
burnix
ffmpeg versus x265 speed
Hi community.
Since 2 or 3 years i use a 2 pass ffmpeg script to encode my 1080p video in h265 700kbs. I use veryfast profile that give me really good result.
Recently after some search over internet to found a cost effective cpu mainboard to buy to encode my films, i have read, that recent x265 build are more efficcient than ffmpeg.
Can someone confirm that and can someone give me an example of a 2 pass x265 encoding script.
burnix is offline   Reply With Quote
Old 14th May 2024, 06:33   #2  |  Link
Ritsuka
If you are already using x265 with ffmpeg, there won't be any difference in using the stand-alone version.
Ritsuka is offline   Reply With Quote
Old 14th May 2024, 16:55   #3  |  Link
RanmaCanada
If you're using veryfast profile you'd be better off to just buy an Intel Arc GPU and call it a day, as Arc encodes are comparable to x265 medium preset, with astounding speeds.
