Old 29th March 2024, 20:49   #1  |  Link
Selur
Selur's Avatar
ffmpeg opening a blu-ray?
Trying to open the old x264 BR-Demo using:
"F:\Hybrid\64bit\ffmpeg.exe" -loglevel debug -i "bluray:G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo"
fails
ffmpeg version N-114213-g098b78df9d-gf5441e441f+1 Copyright (c) 2000-2024 the FFmpeg developers
  built with gcc 13.2.0 (Rev5, Built by MSYS2 project)
  configuration:  --pkg-config=pkgconf --cc='ccache gcc' --cxx='ccache g++' --ld='ccache g++' --extra-cxxflags=-fpermissive --extra-cflags=-Wno-int-conversion --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --disable-doc --enable-gmp --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --enable-libaom --disable-debug --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libopenmpt --enable-version3 --enable-librav1e --enable-libsrt --enable-libgsm --enable-libvmaf --enable-libsvtav1 --enable-gnutls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv --disable-w32threads
  libavutil      59.  1.100 / 59.  1.100
  libavcodec     61.  1.101 / 61.  1.101
  libavformat    61.  0.100 / 61.  0.100
  libavdevice    61.  0.100 / 61.  0.100
  libavfilter    10.  0.100 / 10.  0.100
  libswscale      8.  0.100 /  8.  0.100
  libswresample   5.  0.100 /  5.  0.100
  libpostproc    58.  0.100 / 58.  0.100
Splitting the commandline.
Reading option '-loglevel' ... matched as option 'loglevel' (set logging level) with argument 'debug'.
Reading option '-i' ... matched as input url with argument 'bluray:G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo'.
Finished splitting the commandline.
Parsing a group of options: global .
Applying option loglevel (set logging level) with argument debug.
Successfully parsed a group of options.
Parsing a group of options: input url bluray:G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo.
Opening an input file: bluray:G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo.
[AVFormatContext @ 000002165456e1c0] Opening 'bluray:G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo' for reading
[bluray @ 000002165456e740] No default whitelist set
Array too big.
fails.
This did work with older versions.
Using:
"F:\Hybrid\64bit\ffmpeg.exe" -loglevel debug -i "bluray:G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo\"
I get:
Reading option '-i' ... matched as input url with argument 'bluray:G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo"'.
Parsing a group of options: input url bluray:G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo".
Opening an input file: bluray:G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo".
[AVFormatContext @ 000001a824bae1c0] Opening 'bluray:G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo"' for reading
[bluray @ 000001a824bae740] No default whitelist set
../src/libbluray/disc/disc.c:333: failed opening UDF image G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo"
Array too big.
../src/libbluray/disc/disc.c:437: error opening file BDMV\index.bdmv
../src/libbluray/disc/disc.c:437: error opening file BDMV\BACKUP\index.bdmv
Since I couldn't find any info over at https://ffmpeg.org/ffmpeg-all.html
Does anybody know what could be wrong?
Cu Selur
Old 30th March 2024, 13:19   #2  |  Link
Selur
Selur's Avatar
I tried a 'full'-build from https://www.gyan.dev/ffmpeg/builds/ and it failed too with the 'No default whitelist set' :/
[bluray @ 0000018adf4f0540] No default whitelist set
[bluray @ 0000018adf4f0540] bd_open() failed
bluray:G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo: I/O error
Does ffmpeg 6.x work for anyone with libbluray?
Cu Selur
Old 30th March 2024, 17:29   #3  |  Link
rwill
Your last try seems to be the most successful.
According to the libbluray source code the error "../src/libbluray/disc/disc.c:333: failed opening UDF image G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo" gets triggered when the lib failed to open the path as a directory before.
So maybe there is a problem with the path? Have you tried copying the folder somewhere else? Maybe somewhere relative?
Old 30th March 2024, 19:16   #4  |  Link
Selur
Selur's Avatar
Copied "x264 BR-Demo" next to ffmpeg and called:
"F:\Hybrid\64bit\ffmpeg.exe" -loglevel debug -i "bluray:x264 BR-Demo"
ffmpeg version 6.0-full_build-www.gyan.dev Copyright (c) 2000-2023 the FFmpeg developers
  built with gcc 12.2.0 (Rev10, Built by MSYS2 project)
  configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libaribb24 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libjxl --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libvpl --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
  libavutil      58.  2.100 / 58.  2.100
  libavcodec     60.  3.100 / 60.  3.100
  libavformat    60.  3.100 / 60.  3.100
  libavdevice    60.  1.100 / 60.  1.100
  libavfilter     9.  3.100 /  9.  3.100
  libswscale      7.  1.100 /  7.  1.100
  libswresample   4. 10.100 /  4. 10.100
  libpostproc    57.  1.100 / 57.  1.100
Reading option '-i' ... matched as input url with argument 'bluray:x264 BR-Demo'.
Parsing a group of options: input url bluray:x264 BR-Demo.
Opening an input file: bluray:x264 BR-Demo.
[NULL @ 000001f0032ae380] Opening 'bluray:x264 BR-Demo' for reading
[bluray @ 000001f0032c6bc0] No default whitelist set
../src/libbluray"F:\Hybrid\64bit\ffmpeg.exe" -loglevel debug -i bluray:"x264 BR-Demo"
  built with gcc 12.2.0 (Rev10, Built by MSYS2 project)debug -i "bluray:x264 BR-Demo"
[NULL @ 000001679c49e380] Opening 'bluray:x264 BR-Demo' for reading
[bluray @ 000001679c4b6bc0] No default whitelist set
../src/libbluray/disc/disc.c:333: failed opening UDF image x264 BR-Demo
[bluray @ 000001679c4b6bc0] bd_open() failed
bluray:x264 BR-Demo: I/O error
I agree that this likely is somehow related to the path, since a Hybrid user reported that it works on Linux with FFmpeg 6.0 and libbluray 1.3.4, but he has the problem on windows.
"F:\Hybrid\64bit\ffmpeg.exe" -loglevel debug -i bluray:"x264-BR-Demo"
Reading option '-i' ... matched as input url with argument 'bluray:x264-BR-Demo'.
Parsing a group of options: input url bluray:x264-BR-Demo.
Opening an input file: bluray:x264-BR-Demo.
[NULL @ 000001f5ee7de380] Opening 'bluray:x264-BR-Demo' for reading
[bluray @ 000001f5ee7f6bc0] No default whitelist set
[bluray @ 000001f5ee7f6bc0] 3 usable playlists:
[bluray @ 000001f5ee7f6bc0] playlist 00000.mpls (0:09:56)
[bluray @ 000001f5ee7f6bc0] playlist 00002.mpls (0:10:53)
[bluray @ 000001f5ee7f6bc0] playlist 00003.mpls (0:05:35)
[bluray @ 000001f5ee7f6bc0] selected 00002.mpls
[mpegts @ 000001f5ee7de380] Format mpegts probed with size=2048 and score=50
[mpegts @ 000001f5ee7de380] stream=0 stream_type=1b pid=1011 prog_reg_desc=HDMV
[mpegts @ 000001f5ee7de380] stream=1 stream_type=86 pid=1100 prog_reg_desc=HDMV
[mpegts @ 000001f5ee7de380] Before avformat_find_stream_info() pos: 0 bytes read:32768 seeks:0 nb_streams:2
For transform of length 32, inverse, mdct_float, flags: [aligned, out_of_place], found 3 matches:
    1: mdct_inv_float_avx2 - type: mdct_float, len: [16, ∞], factors[2]: [2, any], flags: [aligned, out_of_place, inv_only], prio: 511
    2: mdct_inv_float_c - type: mdct_float, len: [2, ∞], factors[2]: [2, any], flags: [unaligned, out_of_place, inv_only], prio: 96
    3: mdct_naive_inv_float_c - type: mdct_float, len: [2, ∞], factors[2]: [2, any], flags: [unaligned, out_of_place, inv_only], prio: -130976
For transform of length 16, inverse, fft_float, flags: [aligned, inplace, preshuf, asm_call], found 2 matches:
    1: fft16_asm_float_fma3 - type: fft_float, len: 16, factor: 2, flags: [aligned, inplace, out_of_place, preshuf, asm_call], prio: 512
    2: fft16_asm_float_avx - type: fft_float, len: 16, factor: 2, flags: [aligned, inplace, out_of_place, preshuf, asm_call], prio: 480
Transform tree:
    mdct_inv_float_avx2 - type: mdct_float, len: 32, factors[2]: [2, any], flags: [aligned, out_of_place, inv_only]
For transform of length 64, inverse, mdct_float, flags: [aligned, out_of_place], found 3 matches:
For transform of length 32, inverse, fft_float, flags: [aligned, inplace, preshuf, asm_call], found 2 matches:
    1: fft32_asm_float_fma3 - type: fft_float, len: 32, factor: 2, flags: [aligned, inplace, out_of_place, preshuf, asm_call], prio: 512
    2: fft32_asm_float_avx - type: fft_float, len: 32, factor: 2, flags: [aligned, inplace, out_of_place, preshuf, asm_call], prio: 480
Transform tree:
    mdct_inv_float_avx2 - type: mdct_float, len: 64, factors[2]: [2, any], flags: [aligned, out_of_place, inv_only]
[h264 @ 000001f5ee804b40] Decoding VUI
[extract_extradata @ 000001f5ee7c6300] nal_unit_type: 9(AUD), nal_ref_idc: 0
[extract_extradata @ 000001f5ee7c6300] nal_unit_type: 7(SPS), nal_ref_idc: 3
[extract_extradata @ 000001f5ee7c6300] nal_unit_type: 8(PPS), nal_ref_idc: 3
[extract_extradata @ 000001f5ee7c6300] nal_unit_type: 6(SEI), nal_ref_idc: 0
    Last message repeated 2 times
[extract_extradata @ 000001f5ee7c6300] nal_unit_type: 5(IDR), nal_ref_idc: 3
    Last message repeated 3 times
[h264 @ 000001f5ee804b40] nal_unit_type: 9(AUD), nal_ref_idc: 0
[h264 @ 000001f5ee804b40] nal_unit_type: 7(SPS), nal_ref_idc: 3
[h264 @ 000001f5ee804b40] nal_unit_type: 8(PPS), nal_ref_idc: 3
[h264 @ 000001f5ee804b40] nal_unit_type: 6(SEI), nal_ref_idc: 0
[h264 @ 000001f5ee804b40] nal_unit_type: 5(IDR), nal_ref_idc: 3
[h264 @ 000001f5ee804b40] Format yuv420p chosen by get_format().
[h264 @ 000001f5ee804b40] Reinit context to 1920x1088, pix_fmt: yuv420p
[h264 @ 000001f5ee804b40] no picture
    Last message repeated 1 times
[mpegts @ 000001f5ee7de380] Probe buffer size limit of 5000000 bytes reached
../src/libbluray/bluray.c:299: 00003.m2ts: no timestamp for SPN 0 (got 0). clip 27000000-56420625.
[mpegts @ 000001f5ee7de380] After avformat_find_stream_info() pos: 0 bytes read:6832768 seeks:2 frames:420
Input #0, mpegts, from 'bluray:x264-BR-Demo':
  Duration: 00:10:53.79, start: 600.000000, bitrate: 11392 kb/s
  Program 1
  Stream #0:0[0x1011], 98, 1/90000: Video: h264 (High), 1 reference frame (HDMV / 0x564D4448), yuv420p(tv, bt709, progressive, left), 1920x1080 (1920x1088) [SAR 1:1 DAR 16:9], 0/1, 24 fps, 24 tbr, 90k tbn
  Stream #0:1[0x1100], 322, 1/90000: Audio: dts (DTS-HD MA) ([134][0][0][0] / 0x0086), 48000 Hz, 5.1(side), s16p
Successfully opened the file.
Correcting start time of Input #0 by 9223372036254775807 us.
At least one output file must be specified
[AVIOContext @ 000001f5ee800180] Statistics: 6832768 bytes read, 2 seeks
Renaming the folder to "x264-BR-Demo" does seem to work.
So seems like ffmpeg and/or libbluray has issues with any 'special' character (even white spaces)
Old 30th March 2024, 19:32   #5  |  Link
Selur
Selur's Avatar
It does work if one uses '8.3 filename' (assuming short filename creation is enabled, which it is not always in Windows nowadays)
Old 30th March 2024, 19:46   #6  |  Link
rwill
I would try some escape combinations like "G:\\TestClips&Co\\discs\\Blu-ray\\x264\ BR-Demo" (with or without the quotes).
But I am afraid I cannot be of help, I am no Windows Path expert.
Old 30th March 2024, 21:32   #7  |  Link
Selur
Selur's Avatar
tried that didn't help
also the 8.3 workaround does only seem to work with the build from https://www.gyan.dev/ffmpeg/builds/ not with the one from MBAS
=> will try to look more into it tomorrow.
Old 31st March 2024, 11:36   #8  |  Link
Selur
Selur's Avatar
gaynet-builds work
ffmpeg-6.1.1-full_build\bin>ffmpeg.exe -loglevel debug -i "bluray:G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo"
ffmpeg-6.0-full_build\bin>ffmpeg.exe -loglevel debug -i "bluray:G:\TestClips&Co\discs\Blu-ray\x264 BR-Demo"
MBAS builds to not.
=> going to contact the MBAS folks. (https://github.com/m-ab-s/media-auto...te/issues/2627)
Cu Selur
