Old 22nd April 2024, 01:36   #41  |  Link
tebasuna51
tebasuna51's Avatar
The rest of encoders have diferent behaviour, sometimes show error or say nothing or for instance read the mask but ignore it like oggenc2:
WARNING: Unknown WAV surround channel mask: 165391
blindly mapping speakers using default SMPTE/ITU ordering.
Then only some channel layouts can be encoded safely:
NumCh MaskCh  Name       Present Channels                  qaac  nero  fdk.  ffm.  opus  ogg
  3        7  3.0        FL FR FC                            S     S     S     S     S     S
  4      263  4.0        FL FR FC BC                         S     S     S     S     -     -
  4       51  quad       FL FR BL BR (SL SR)                 S     S     -     S     S     S
  5       55  5.0        FL FR FC BL BR (SL SR)              S     S     S     S     S     S
  6       63  5.1        FL FR FC LF BL BR (SL SR)           S     S     S     S     S     S
  6      311  hexagonal  FL FR FC BL BR BC (SL SR)           S     -     -     -     -     -
  7      319  6.1(back)  FL FR FC LF BL BR BC (SL SR)        S     S     -     -     S     S
  7     1591  7.0        FL FR FC BL BR SL SR                S     -     -     -     -     -
  8      255  7.1(wide)  FL FR FC LF BL BR FLC FRC (SL SR)   S     S     S     -     -     -
  8     1599  7.1        FL FR FC LF BL BR SL SR             S     -     S     S     S     S
  8     1847  octagonal  FL FR FC BL BR BC SL SR             S     -     -     -     -     -
Like we can see the qaac encoder have more options (and best quality for me)
Old 22nd April 2024, 09:35   #42  |  Link
Kurt.noise
Thanks for your tests Tebasuna.
You did them with wav as source, right ? because LWLibavAudioSource does not support some multichannel lossy format (7.1 eac3 for instance)
Kurt.noise is offline   Reply With Quote
Old 22nd April 2024, 21:05   #43  |  Link
tebasuna51
tebasuna51's Avatar
LWLibavAudioSource can support 7.1 eac3 and work recoding them to flac with MeGUI 6666, but the channel mask is the default, the same for 8w341.eac3 and for 8w3D.eac3.
Without recognize the channelmask detected by LWLibavAudioSource:
Old 26th April 2024, 09:48   #44  |  Link
Kurt.noise
https://github.com/Kurtnoise-zeus/me.../tag/6666.2604
Please, report any issues regarding audio transcoding in this release. Probably, that needs to be polished here and there. Enjoy.
Old 26th April 2024, 18:38   #45  |  Link
tebasuna51
tebasuna51's Avatar
Sorry, but recoding the attached 4 ac3's, with different channel mask, output the same default channelmask.
Seems the WAVE_FORMAT_EXTENSIBLE header is not sended to ffmpeg when do:
ffmpeg.exe -i - -y -acodec ac3 -ab 384k "4_3.1.ac3"
About flac encode:
[Information] [26/04/2024 17:47:36] Job command line: C:\Portablz\MeGUI_66\tools\flac\flac.exe --force --force-raw-format --endian=little --sign=signed -5 - -o "C:\tmp\8w3D.flac" --channels=8 --bps=24 --sample-rate=48000
If you use --force-raw-format for flac encode the channelmask is ignored, only pcm samples are sended.
That command line is used before than flac support --ignore-chunk-sizes parameter or w64/rf64 headers
Use: - --ignore-chunk-sizes --silent -o "X.flac"
Or better use w64/rf64 header to avoid some warnings of flac:
#### Encoder StdErr ####
INFO: Make sure you know what you're doing when using --ignore-chunk-sizes.
Improper use can cause flac to encode non-audio data as audio.
-: WARNING: 'data' chunk has non-zero size, using --ignore-chunk-sizes is probably a bad idea
-: INFO: hit EOF with --ignore-chunk-sizes, got 958464 samples
Tested with BeHappy and Flac 1.4.3 and work fine.
Old 11th May 2024, 10:32   #46  |  Link
Kurt.noise
Back from vacations...
Which output format did you select ? which nb channels did you select as output ?
Will fix the remaining issues you've listed. Thanks again.
Old 11th May 2024, 21:18   #47  |  Link
tebasuna51
tebasuna51's Avatar
Only AC3 to AC3 without modify nothing, to avoid problems on encoders.
When you modify the flac encode we can use also it, with the best performance preserving the channelmask.
Old 14th May 2024, 13:10   #48  |  Link
Kurt.noise
Guys, lets try latest release : https://github.com/Kurtnoise-zeus/me.../tag/6666.1405
Old 17th May 2024, 12:19   #49  |  Link
tebasuna51
tebasuna51's Avatar
Thanks Kurt.
- Now the flac encodes preserve fine the channelmask with the simple command line, do you send W64/RF64 headers or check if size > 4 GB to add the parameter --ignore-chunk-sizes ?
- Direct ac3 encodes preserve also the channelmask but I have a doubt, recoding a 3.1 ac3 the relevant log lines show:
--[Information] [17/05/2024 11:55:00] MediaInfo
---[Information] File: C:\tmp\wav\4_3.1.ac3
----[Information] ChannelLayout: L R C LFE
--[Information] [17/05/2024 11:55:03] AviSynth script
---[NoImage] LoadPlugin("C:\Portablz\MeGUI_66\tools\lsmash\LSMASHSource.dll")
---[NoImage] LWLibavAudioSource("C:\tmp\wav\4_3.1.ac3", drc_scale=0)
---[NoImage] # Detected Channels: 4
---[NoImage] # Detected Channels Layout: L R C LFE
---[NoImage] cm=GetChannelMask(last)
---[NoImage] # Detected Channel Mask: cm=15
---[NoImage] # Applied Channel Mask
---[NoImage] SetChannelMask("15")
---[NoImage] 32==Audiobits(last)?ConvertAudioTo24bit(last):last
---[NoImage] return last
--[Information] [17/05/2024 11:55:04] MediaInfo
The output is correct, but for what you SetChannelMask("15") if it's already correct?:
I saved the precedent avs and I try encode it:
--[Information] [17/05/2024 12:22:42] MediaInfo
---[Information] File: C:\tmp\wav\0new_avsac3.avs
---[Information] AVS input file detected. Getting media information from AviSynth.
----[Information] ChannelsString: 4 channels
--[Information] [17/05/2024 12:22:45] AviSynth script
---[NoImage] Import("C:\tmp\wav\0new_avsac3.avs")
---[NoImage] # Detected Channel Mask: cm=3
---[NoImage] SetChannelMask("3")
--[Information] [17/05/2024 12:22:46] MediaInfo
----[Information] ChannelLayout: L R C Cb
1) MediaInfo can't extract the ChannelLayout from an avs
2) # Detected Channel Mask: cm=3 can't be obtained from cm=GetChannelMask(last) it's "15"
3) Seems apply stereo default L R, I don't know for what with 4 channels
4) ffmpeg ignore that channelmask and apply the default for 4 channels 4.0 instead the correct 3.1
Seems you trust in MediaInfo and ignore the cm=GetChannelMask(last)
I think you must trust in cm=GetChannelMask(last) unless it is invalid.
Old 17th May 2024, 14:42   #50  |  Link
tebasuna51
tebasuna51's Avatar
To know if a channelmask is valid for the Detected channels I can use:
cm = GetChannelMask(last)
nc = AudioChannels(last)
cm0 = cm
nc0 = 0  #AudioChannels
for (i=1, 18) {
  nc0 = nc0 + cm0 % 2
  cm0 = int(cm0 / 2)
if (nc0 != nc ) {
  cm = Select(nc, 3, 4, 3, 7, 263, 55, 63, 319, 1599)
  SetChannelMask(String(cm))
If it's invalid (nc0 != nc ) we select the default for the Detected channels
Old 19th May 2024, 07:38   #51  |  Link
Kurt.noise
Right, I missed avs input part...I'll check out. It's stereo by default when nothing is found.
w64 is sent but I didn't update the settings for 4+Gb size.
Old 19th May 2024, 08:20   #52  |  Link
edison
The updater told:
Cannot use update server http://megui.org/auto/stable/. Reason: Update XML is invalid
How can I fix this problem?
edison is offline   Reply With Quote
Old 19th May 2024, 09:13   #53  |  Link
tebasuna51
tebasuna51's Avatar
If sent w64 header is OK, you not need check the size.
Originally Posted by edison View Post
The updater told:
No problem here, BTW never use the stable server with MeGUI 6666, it have very old software versions. Also the development server need changes.
Help us checking the actual versions of software used from here:
https://forum.doom9.org/showthread.p...82#post1981982
Old 19th May 2024, 13:38   #54  |  Link
tebasuna51
tebasuna51's Avatar
About the software used by MeGUI here is a list of actual versions, and links to last versions.
In the folder ...\update_cache there are the actual versions, if you have troubles with a tool try replace it with last version (in ...\tools folders) and comment if work fine now.
MeGUI_6666-14/05/2024      Last    Date      Download
SYSTEM
megui-core-2944            MeGUI
megui-data_2443            MeGUI
megui-libs-2847            MeGUI
megui-update_2680          MeGUI
redist-4-64                MeGUI
mediainfo-18.05            24.04   20240418  https://mediaarea.net/es/MediaInfo/Download/Windows
DEMUX-DECODE
dgindexnv-250-231115       255     20240411  https://www.rationalqm.us/dgdecnv/binaries/
dgmpgdec-2.0.0.8           3.0.0.0 20240402  https://www.rationalqm.us/dgmpgdec/
eac3to-3.36-32             3.51    20240312  https://www.rationalqm.us/eac3to/
ffmpeg-5.0-64              7.0     20240518  https://github.com/BtbN/FFmpeg-Builds/releases
pgcdemux_1.2.0.5           last know 2014    https://www.videohelp.com/software/PgcDemux
AVISYNTH
avisynth-plugin-13-64      many plugins      pending check
avisynthplus-3.5.1-64      3.7.3   20240131  https://forum.doom9.org/showthread.p...98#post1909698
ffms2-230707-64            r2390   20240306  https://codeberg.org/StvG/ffms2/releases
lsmash-231117-64           r1194   20240408  https://github.com/HomeOfAviSynthPlu...Works/releases
AUDIO
besplit-0.9b8              last know 2005    https://www.videohelp.com/software/Besplit
fdk-aac 0.6.3              1.0.6   20240510  https://www.mediafire.com/file/w2o5fmp2mmypuhg
flac-1.4.3-64              1.4.3   20230622  https://ftp.osuosl.org/pub/xiph/releases/flac/
lame-3.100-64              3.100.1 20200908  https://www.rarewares.org/mp3-lame-bundle.php
oggenc2.87-aoTuVb6.03_x64  2.88    20200817  https://www.rarewares.org/ogg-oggenc.php
opus-0.2.29-230614-64      0.2-34  20231211  https://www.videohelp.com/software/OpusTools
qaac-2.80-64               2.82    20240322  https://github.com/nu774/qaac/releases
NeroAacEnc 1.5.4.0         last know 2010    https://www.videohelp.com/software/Nero-AAC-Codec
VIDEO
vsrip_1007                 last know 2011    https://www.videohelp.com/software/VSRip
x264-3164-64               3191    20240514  https://www.videohelp.com/software/x264-Encoder
x265-3.5+104-64            v3.6+12 20240511  http://msystem.waw.pl/x265/
xvid-1.4.0-64              ok for me
MUXERS
avi-mux_gui-1.17.8.3       last know 2010    https://www.videohelp.com/software/AVIMux-GUI
haali_2859                 last know 2013    https://www.videohelp.com/software/Haali-Media-Splitter
mkvtoolnix-80.0.0-64       84.0    20240428  https://mkvtoolnix.download/windows/releases/
mp4box-2.3-DEV-rev349-64   2.4     20240417  https://www.videohelp.com/software/MP4Box
tsmuxer-20230319-32                20240512  https://github.com/justdan96/tsMuxer/releases
Old 19th May 2024, 18:25   #55  |  Link
tebasuna51
tebasuna51's Avatar
I'm not a expert about video AviSynth plugins but maybe someones are obsolete. I let to video experts suggest some changes.
About audio AviSynth plugins:
- BassAudio and NicAudio like decoders are obsolete, we have lsmash and ffms2 for audio/video decoders.
- Timestretch is a internal fuction of AviSynth 2.6 and is included with Avs+ releases, we don't need the external plugin.
- AudioLimiter don't have a 64 bit version but we can use instead the http://avisynth.nl/index.php/Soxfilter
Then only the SoxFilter v2.2 20240104 must be included for audio management.
Old 20th May 2024, 13:55   #56  |  Link
Kurt.noise
I would pick up ffmpeg binaries from here instead of https://github.com/BtbN/FFmpeg-Builds/releases
Libraries used in these builds are more updated than the ones from BtbN. No difference for megui though.
Old 20th May 2024, 23:54   #57  |  Link
tebasuna51
tebasuna51's Avatar
No problem, is the other repository recommended in ffmpeg web. The essentials build is enough most the times.
Old 21st May 2024, 09:08   #58  |  Link
tormento
Acid fr0g
tormento's Avatar
Btbn releases shared ffmpeg too, while Gyan builds them on major release only. Plus Gyan release them once a week (almost) while Btbn releases almost everyday.
@turment on Telegram
Old 21st May 2024, 10:49   #59  |  Link
Kurt.noise
Originally Posted by tormento View Post
while Gyan builds them on major release only. .
nope...there are also the git master builds.
Old 21st May 2024, 12:42   #60  |  Link
tebasuna51
tebasuna51's Avatar
Maybe we can try also x265 with AVS input: https://github.com/Patman86/x265-Mod-by-Patman/releases
