Old 12th February 2024, 19:17   #1  |  Link
benwaggoner
Simple way to remove HDR10+ dynamic metadata
I want to do some demos of playback with and without HDR10+ metadata. I've already got the files with the metadata, and it'd be preferable if I can just remove it from a copy of the file rather than reencode it to exactly match.
I presume there's some mp4 or ffmpeg command line that can do it with fussy syntax.
Ben Waggoner
My Compression Book
Old 12th February 2024, 22:07   #2  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
https://forum.doom9.org/showthread.php?t=183479
Simply use the REMOVER Script.
-QfG- is offline   Reply With Quote
Old 12th February 2024, 22:17   #3  |  Link
TDS
Formally known as .......
TDS's Avatar
You could also try this:-
https://github.com/R3S3t9999/DoVi_Scripts
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
Old 13th February 2024, 01:15   #4  |  Link
benwaggoner
Nice, thanks!
Ben Waggoner
My Compression Book
Old 14th February 2024, 00:59   #5  |  Link
TDS
TDS's Avatar
Nice, thanks!
Hi Ben,
I have some good news, this is now on Doom9, it got posted last night (my time).
Pls take a look here:-
https://forum.doom9.org/showthread.p...16#post1997616
I think this is the next big thing in DV conversion & processing (and a LOT more)
