Old 17th January 2024, 21:54   #1  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
ffmpeg command help
I want wav in and wav out, and... mp3 conversion in the middle as "filter". And all that working in one instance.
ffmpeg -i in.wav out.wav
VoodooFX is offline   Reply With Quote
Old 17th January 2024, 22:56   #2  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
what do you mean with "in the middle"? You want to encode to wav but pack in an mp3 stream "in the middle"? I don't think this is possible
Old 17th January 2024, 23:27   #3  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
In "the middle" I want to encode to mp3 and decode to wav.
Who knew that degrading audio with mp3 can be useful as some magic "filter"...
Actually I solved it with pipe, still interested if it can be done without pipe.
Old 18th January 2024, 14:04   #4  |  Link
kolak
Don't think it's possible without piping.
Old 18th February 2024, 22:10   #5  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
@Jiyasharma
Your example writes mp3 to wav, I meant "wav" as PCM wav.
Old 19th February 2024, 03:14   #6  |  Link
qyot27
qyot27's Avatar
The facetious answer? Take the code for LAME's psychoacoustics model(s) and make it into a filter library that just does generic processing on PCM samples so it could be inserted into arbitrary audio pipelines.
Barring that, you'd have to study the exact steps those models perform and attempt to replicate it using the audio filters in libavfilter, SoX, etc. It almost certainly won't be 1:1, but you might be able to get close.
