Old 15th January 2024, 12:55   #1  |  Link
an3k
an3k's Avatar
Blu-ray ROM4 Format Specification
Hello,
I'm looking for the mentioned specification, https://blu-raydisc.info/format-spec/rom4-spec.php
$5,000 for all three books is a bit expensive I'd say. At minimum I'd need
Ultra HD ROM version 4 Book 24 "Part 3: Audio Visual Basic Specifications v.3.xx"
if there is a chance to get it through different paths.
Thanks a lot in advance!
an3k is offline   Reply With Quote
Old 16th January 2024, 11:17   #2  |  Link
cubicibo
No chance if you are an individual, unfortunately, and it pisses off everyone.
Per the FAQ:
May I obtain an FLLA as an individual?
The licensing program is available to registered companies, not to individuals.
But, what would be your needs? Most of the specifications were carried from v1.x/v2.x to v3.x without any changes (HDMV PGS, IGS...), or just dropped entirely (PIP, TextST). Only elements related to MPLS, STN Table, HDR, HDR-to-SDR, and DV would be new. Surprisingly, HEVC encoding parameters are egiven in the White Paper.
cubicibo is offline   Reply With Quote
Old 16th January 2024, 19:33   #3  |  Link
kolak
We had BD book in my old company (2 parts I think).
It probably still there with my bosses on the shelf or it was thrown away
As far as I'm aware there were only printed (unique) versions. Maybe it changed.
Old 16th January 2024, 20:10   #4  |  Link
wswartzendruber
hlg-tools Maintainer
wswartzendruber's Avatar
I'm not too proud to go dumpster diving.
wswartzendruber is offline   Reply With Quote
Old 18th January 2024, 17:32   #5  |  Link
an3k
an3k's Avatar
Well, I do have my company, so I could get them ... but I don't want to pay (that much)
Originally Posted by eac3to_mod View Post
an3k, if you had some specific questions perhaps forum members could help with them.
Thank you. I wanted to help finding the book(s) to help BDEdit developer pel - since he needs them.
Maybe back in the day it was different but "currently" they want the book back once the subscription ends
Old 19th January 2024, 11:54   #6  |  Link
nevcairiel
There are definitely digital version of the BD specifications. Its not quite as super secretive as they tried DVD to be back in the day.
Old 19th January 2024, 12:47   #7  |  Link
kolak
At the time we bought it (start of BD) I'm almost sure there was no digital version.
Each printed version was with unique ID printed on every page (if I'm correct). What happened later I have no idea.
