Old 12th January 2024, 13:42   #1  |  Link
Selur
Selur's Avatar
newer ffmpeg broken?
Using ffmpeg build at the end of last year:
ffmpeg version N-112974-gd324415563-g5256b2fbe6+2 Copyright (c) 2000-2023 the FFmpeg developers
  built with gcc 13.2.0 (Rev3, Built by MSYS2 project)
  configuration:  --pkg-config=pkgconf --cc='ccache gcc' --cxx='ccache g++' --ld='ccache g++' --extra-cxxflags=-fpermissive --extra-cflags=-Wno-int-conversion --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --disable-doc --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --enable-libaom --disable-debug --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libopenmpt --enable-version3 --enable-librav1e --enable-libsrt --enable-libgsm --enable-libvmaf --enable-libsvtav1 --enable-mbedtls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv --disable-w32threads
  libavutil      58. 33.100 / 58. 33.100
  libavcodec     60. 35.100 / 60. 35.100
  libavformat    60. 18.100 / 60. 18.100
  libavdevice    60.  4.100 / 60.  4.100
  libavfilter     9. 14.100 /  9. 14.100
  libswscale      7.  6.100 /  7.  6.100
  libswresample   4. 13.100 /  4. 13.100
  libpostproc    57.  4.100 / 57.  4.100
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
and:
ffmpeg_working -y -i "G:\TestClips&Co\test.avi" -an -sn -vf zscale=rangein=tv:range=tv -pix_fmt yuv420p -f yuv4mpegpipe j:\tmp\working.y4m
the output is fine.
using an ffmpeg verision I build yesterday:
ffmpeg version N-113316-g7f20bca34d-g564a15b2ee+2 Copyright (c) 2000-2024 the FFmpeg developers
  configuration:  --pkg-config=pkgconf --cc='ccache gcc' --cxx='ccache g++' --ld='ccache g++' --extra-cxxflags=-fpermissive --extra-cflags=-Wno-int-conversion --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --disable-doc --enable-gmp --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --enable-libaom --disable-debug --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libopenmpt --enable-version3 --enable-librav1e --enable-libsrt --enable-libgsm --enable-libvmaf --enable-libsvtav1 --enable-gnutls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv --disable-w32threads
  libavutil      58. 36.101 / 58. 36.101
  libavcodec     60. 37.100 / 60. 37.100
  libavformat    60. 20.100 / 60. 20.100
  libavfilter     9. 17.100 /  9. 17.100
Universal media converter
and
ffmpeg -y -i "G:\TestClips&Co\test.avi" -an -sn -vf zscale=rangein=tv:range=tv -pix_fmt yuv420p -f yuv4mpegpipe j:\tmp\broken.y4m
the output is broken.
working:
YUV4MPEG2 W640 H352 F25:1 Ip A1:1 C420mpeg2 XYSCSS=420MPEG2 XCOLORRANGE=LIMITED
FRAME
QQQQQQQQTTTTTTTTTTTTTTTTVVVVVVVVVWWXXYYZXXXXXXXX\\\\\\\\[[[[[[[[\\\\\\\\]]]]]]]]^^^^^^^^ZZZZZZZZ]]]]]]]]ZZZZZZZZ^^]]\[[ZZZZZZZZZ[ZZZ[ZWTLMMNNOOPMNOPRSTUSSSSSSSSYXXWVUTTXXXYZZ[[[[[[[[[[]^^__``adeghhgedghiklmnnppopqtwyvwy|��������������������������������S$%!!#!*S~����������������~|{zzwrn}{eORdpvg[OQ^konrqoljgedcdefhikkjjjjjjjjijjjifdbccccccccdddddddd````````aaaaaaaaaaaaaaaabbbbbbbbccccccccffffffffggggffffhhhhhhhhjjkkllmmllllllllpqrtttssqqrstuuvyzz{|}~}}}}}}}}~��������������������������}|{zyxwvuutvvutsrqqqqponmlljjihgfeeddccbbaa`^]^_`_]]]]]]]]]]\\[[ZZZVUUTTSSRPPPPPPPPPPPPPPPPMMMMMMMMJJJJJJJJLKJIGFEDEEFGGHIIFFFFFFFFCCCCCCCCCBBAA@@?QQQQQQQQTTTTTTTTTTTTTTTTVVVVVVVVVWWXXYYZXXXXXXXX[[[[[[[[[[[[[[[[\\\\\\\\]]]]]]]]^^^^^^^^]]]]]]]]]]]]]]]][[[[[[[[ZZZZZZZZZZZZZZZZ[ZZZ[ZVTLMMNNOOPLLMOPQRSSSSSSSSSTTTTTTTTVVWWXYYY[[[[[[[[]^^__``a^`bdefedlllmmnnnssrqqsuvz{|}�������������������������������nD(
broken:
FRAME
~~~~~~~~~~~~���������������~~~~~~~~~~��������������������������������������������������������������������������������������������������jjjjijidccccdddd````aaaaaaaabbbbccccffffggffhhhhjklmllllprtsqrtuyz|~}}}}~�������������|zxvuvusqqpnljigedcba`]__]]]]]\[ZVUTSPPPPPPPPMMMMJJJJLJGEEFGIFFFFCCCCCBA@
(output seems to be broken, even when using '-loglevel quiet' and '-f rawvideo')
the broken output looks like this:
both versions were build with mbas does anyone else have this issue with a new build ffmpeg? (trying to figure out whether this is a. a bug in ffmpeg b. a bug in mbas or c. something going awry with my build system)
Cu Selur
Old 12th January 2024, 13:49   #2  |  Link
richardpl
I confirm its really broken. FFmpeg becomes corporate low quality code dumpster. Stop using it, switch to gstreamer.
richardpl is offline   Reply With Quote
Old 12th January 2024, 14:25   #3  |  Link
Selur
Selur's Avatar
Hmm,... seems like it's related to '-vf zscale=rangein=tv:range=tv' without it, the output is fine, independent of the version.
Old 12th January 2024, 14:31   #4  |  Link
ProWo
There are problems with JSON too.
6.1.1. is ok.
ProWo is offline   Reply With Quote
Old 12th January 2024, 14:42   #5  |  Link
Selur
Selur's Avatar
Just noticed there was a fix for vf_zscale just now (https://git.ffmpeg.org/gitweb/ffmpeg...a8c2c6fe9c2a0a)
=> will build a new ffmpeg version and report later whether that commit fixed the problem
Old 12th January 2024, 15:16   #6  |  Link
Selur
Selur's Avatar
Yes, that commit fixes the problem.
Nice!
Cu Selur
Old 12th January 2024, 19:26   #7  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
What about ffmpeg v6 is producing different wavs than v5?
ffmpeg -i input.mp3 -ar 16000 -ac 1 -c:a pcm_s16le output.wav
VoodooFX is offline   Reply With Quote
Old 12th January 2024, 19:55   #8  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
add -flags +bitexact
Old 12th January 2024, 20:09   #9  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Has no effect with both v5 & v6.
ffmpeg -i input.mp3 -ar 16000 -ac 1 -c:a pcm_s16le -flags +bitexact output.wav
Old 12th January 2024, 23:33   #10  |  Link
richardpl
It is just "-bitexact"
Old 13th January 2024, 06:41   #11  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
This has effect, but there are still same differences in wavs. [minus a diff in the headers]
Download the test files: https://we.tl/t-XyKI8cnSy4
ffmpeg -i original.aac -ar 16000 -ac 1 -c:a pcm_s16le output.wav
EDIT:
There are 30 one byte [1] differences. [Windows]
Btw, strangely, a Linux user reported 41 differences with same(?) Linux versions.
Old 13th January 2024, 14:20   #12  |  Link
Selur
Selur's Avatar
got a question about bitexact:
-bitexact (input/output)
Enable bitexact mode for (de)muxer and (de/en)coder
source: https://ffmpeg.org/ffmpeg-all.html#Advanced-options
What does this actually mean? For encoders, I get that the output might not be always deterministic, but especially for demuxers and decoders shouldn't the output always the same?
Cu Selur
Old 13th January 2024, 15:35   #13  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
So, no one knows why wavs are different?
Those one byte differences propagate into the huge differences in AI. Found it when an user reported various hallucinations and I couldn't reproduce it.
Old 13th January 2024, 16:21   #14  |  Link
lvqcl
Different compilers, different floating point optimizations, etc.
MP3 decoding is not required to be bit-exact and different decoders can produce slightly different results.
lvqcl is offline   Reply With Quote
Old 13th January 2024, 16:55   #15  |  Link
Selur
Selur's Avatar
Okay, but shouldn't demuxers be always output the same?
Old 13th January 2024, 17:33   #16  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Actually it's about AAC, do the same stuff applies for it too?
Old 13th January 2024, 18:08   #17  |  Link
lvqcl
Yes. MP3, AAC, Vorbis, Opus, etc.
Old 17th January 2024, 18:31   #18  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
That's not the only problem in the latest master.
This leads to a memory leak:
ffmpeg.exe -hide_banner -i "raw_video.h264" -i "Doc Ljubicic.avs" -map 0:0 -c:v copy -map 1:1 -c:a pcm_s24le -ar 48000 -f mxf "semi-final_output.mxf"
yet it worked just fine in a version from 2020 I had lying around (lavc58.82.100)...
Old 24th January 2024, 19:53   #19  |  Link
Selur
Selur's Avatar
Using:
ffmpeg -y -loglevel debug -noautorotate -nostdin -hwaccel auto -threads 1 -i "C:\Users\Selur\Desktop\Test\Doc Martin (S09E01) To The Lighthouse-001.mkv" -map 0:0 -an -sn -vf scale,zscale=rangein=tv:range=tv,scale -pix_fmt yuv420p -vsync 0 -f rawvideo NUL
ffmpeg version N-113317-g02fb3a775e-gbfa1b7577d+2 Copyright (c) 2000-2024 the FFmpeg developers
[AVFilterGraph @ 000002266992f780] Setting 'rangein' to value 'tv'
[h264 @ 0000022669b5e980] ct_type:1 pic_struct:0
[AVFilterGraph @ 000002266992f780] Setting 'range' to value 'tv'
detected 32 logical cores
[Parsed_scale_0 @ 0000022675c60540] w:iw h:ih flags:'' interl:0
[Parsed_scale_2 @ 000002266a05ea80] w:iw h:ih flags:'' interl:0
[graph 0 input from stream 0:0 @ 0000022669b5d1c0] Setting 'video_size' to value '1920x1080'
[graph 0 input from stream 0:0 @ 0000022669b5d1c0] Setting 'pix_fmt' to value '23'
[graph 0 input from stream 0:0 @ 0000022669b5d1c0] Setting 'time_base' to value '1/1000'
[graph 0 input from stream 0:0 @ 0000022669b5d1c0] Setting 'pixel_aspect' to value '1/1'
[graph 0 input from stream 0:0 @ 0000022669b5d1c0] Setting 'colorspace' to value 'bt709'
[graph 0 input from stream 0:0 @ 0000022669b5d1c0] Setting 'range' to value 'tv'
[graph 0 input from stream 0:0 @ 0000022669b5d1c0] Setting 'frame_rate' to value '24000/1001'
[h264 @ 0000022669b5e980] nal_unit_type: 8(PPS), nal_ref_idc: 3
[h264 @ 0000022669b5e980] nal_unit_type: 6(SEI), nal_ref_idc: 0
[h264 @ 0000022669b5e980] nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 0
    Last message repeated 3 times
[graph 0 input from stream 0:0 @ 0000022669b5d1c0] w:1920 h:1080 pixfmt:nv12 tb:1/1000 fr:24000/1001 sar:1/1 csp:bt709 range:tv
[format @ 00000226698b4040] Setting 'pix_fmts' to value 'yuv420p'
[AVFilterGraph @ 000002266992f780] query_formats: 6 queried, 15 merged, 0 already done, 0 delayed
[Parsed_scale_0 @ 0000022675c60540] picking yuv420p out of 53 ref:nv12 alpha:0
[Parsed_zscale_1 @ 0000022675c5ff80] picking yuv420p out of 53 ref:yuv420p alpha:0
[Parsed_scale_0 @ 0000022675c60540] w:1920 h:1080 fmt:nv12 csp:bt709 range:tv sar:1/1 -> w:1920 h:1080 fmt:yuv420p csp:bt709 range:tv sar:1/1 flags:0x00000004
[Parsed_scale_2 @ 000002266a05ea80] w:1920 h:1080 fmt:yuv420p csp:unknown range:tv sar:1/1 -> w:1920 h:1080 fmt:yuv420p csp:unknown range:tv sar:1/1 flags:(null)
[Parsed_zscale_1 @ 0000022675c5ff80] code 3074: no path between colorspaces
    Last message repeated 31 times
[vf#0:0 @ 0000022669b54480] Error while filtering: Generic error in an external library
[vf#0:0 @ 0000022669b54480] Task finished with error code: -542398533 (Generic error in an external library)
[vf#0:0 @ 0000022669b54480] Terminating thread with return code -542398533 (Generic error in an external library)
[vost#0:0/rawvideo @ 0000022669d609c0] Encoder thread received EOF
full output: https://pastebin.com/4WUdrte4
works if I remove "-hwaccel auto"
am I missing something? Is it just me, or can others confirm this too?
Old 25th January 2024, 12:57   #20  |  Link
Ritsuka
I don't think zscale supports biplanar formats, vf_zscale.c lists only planar ones.
Anyway, what's "zscale=rangein=tv:range=tv" supposed to do?
Ritsuka is offline   Reply With Quote
