Old 21st May 2024, 13:11   #301  |  Link
FTLOY
Friend of a friend..
FTLOY's Avatar
That is true, but the same could apply for most of the posts on this thread. Most can be found elsewhere.
It's just that other x264 & x265 builds are posted here, why not these ??
Just thought I'd ask.
RipBot264 v1.27.3 (08-06-2024)
FTLOY is offline   Reply With Quote
Old 21st May 2024, 14:36   #302  |  Link
Jamaika
Originally Posted by FTLOY View Post
Would it be "out of place", to notify of Patman & Jpsdr x264 & x265 builds here ??
I use:
https://bitbucket.org/multicoreware/x265_git/commits/
https://code.videolan.org/videolan/x264
x264 is problem. It isn't known which library has latest updates.
Jamaika is offline   Reply With Quote
Old 22nd May 2024, 23:32   #303  |  Link
tebasuna51
tebasuna51's Avatar
Ok, why not?
In my first post I say:
Please link only official, tested and legal versions with the improvements or bug fixes (or changelog), than justify the download and replace the new version in at last in one GUI of this sub-forum.
But everybody is free to include here some news.
I let Jamaica ffmpeg builds with -lfdk-aac for instance.
I like the x265 Patman mod with avs input.
Old 23rd May 2024, 07:06   #304  |  Link
FTLOY
FTLOY's Avatar
Ok, why not?
teb
Old 23rd May 2024, 07:14   #305  |  Link
FTLOY
FTLOY's Avatar
Patman's latest x264 & x265 builds..
I've only really started using these, especially x265, it has some extra commands that the "vanilla" builds don't.
But then JPSDR uses Patman's builds, and adds his own twist.
https://github.com/Patman86/x264-Mod...0.164.3191%2B1
https://github.com/Patman86/x265-Mod...g/3.6%2B13%2B1
There are quite a few variants, so it's up to you which "flavour" you want to use.
I am using :-
x265-3.6+13+1-726aec126-.Mod-by-Patman.-x86-64-gcc14.1.0
Old 23rd May 2024, 21:07   #306  |  Link
Barough
Barough's Avatar
x265 v3.6+28
https://www.mediafire.com/file/p3zsun9oj3gcutu
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else.
Old 25th May 2024, 07:11   #307  |  Link
FTLOY
FTLOY's Avatar
JPSDR's latest x265 build..
https://github.com/jpsdr/x265/releases/tag/3.60.13
Old 25th May 2024, 07:20   #308  |  Link
TDS
Formally known as .......
TDS's Avatar
x265 3.6+27-8787e87
http://msystem.waw.pl/x265/
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
Old 26th May 2024, 09:58   #309  |  Link
Jamaika
ffmpeg version 7.1.0-e9197db4 Copyright (c) 2000-2024 the FFmpeg developers
built with GCC: (GNU) 11.3.1 20221227 (experimental) (SIMD) AVX
configuration: -std=gnu++11 -march=x86-64-v2 -ftree-vectorize -g0 -O3 -fPIC -mavx -mxsave -mpclmul -maes
-Llib -lavdevice_x64 -lavfilter_x64 -lavformat_x64 -lavcodec_x64 -lswresample_x64 -lswscale_x64 -lavutil_x64 -lpostproc_x64 -ldavs2_x64 -ldav1d_x64 -luavs3d_x64 -lxevd_x64 -laom_x64 -lkvazaar_x64 -lopenh264_x64 -lsvtav1_x64 -lsvtjxs_x64 -ltheora_x64 -lvpx_x64 -luvg266_x64 -luavs3e_x64 -lx264_opencl_0810bit_x64 -lx265_081012bit_x64 -lxavs_x64 -lxavs2_x64 -lxeve_x64 -lxvid_x64 -lcelt_opus_silk_x64 -lcodec2_x64 -lmp3lame_x64 -lgsm_x64 -lvorbis_x64 -lfdk-aac_x64 -lshine_x64 -lsnappy_x64 -lspeex_x64 -ltwolame_x64 -ljxl_x64 -lpng_x64 -lwebp_x64 -lopenjpeg_x64 -llcms2_x64 -logg_x64 -lrsvgdec_x64 -lcairo_pixman_x64 -lass_x64 -l:freetype_harfbuzz_x64.a -l:fribidi_x64.a -lxml2_x64 -lvmaf_x64 -l:zlib_x64.a -l:bzip2_x64.a -l:lzma_x64.a -l: opencl_x64.a -l: opencv2_opencl_x64.a -l:quirc_x64.a -lqrencode_x64 -lpthread_x64 -L. -lcfgmgr32 -ldnsapi -ldwrite -lbcrypt -liphlpapi -lgdi32 -lopengl32 -lole32 -loleaut32 -lsecurity -lshlwapi -lstrmiids -luuid -lvfw32 -lws2_32
libavutil 59. 20.100 / 59. 20.100
libavcodec 61. 5.104 / 61. 5.104
libavformat 61. 3.104 / 61. 3.104
libavdevice 61. 2.100 / 61. 2.100
libavfilter 10. 2.102 / 10. 2.102
libswscale 8. 2.100 / 8. 2.100
libswresample 5. 2.100 / 5. 2.100
libpostproc 58. 2.100 / 58. 2.100
Latest additions (news):
opencv 4.9.0-1fa96b1
libass 0.17.2-85ff2b3
aom 3.9.0-6f8189b
speex 1.2.1-117bcc0
nasm 2.17-aa03a95
cairo 1.18.0-24d00b6
libjxl 0.10.2-45e688c
libwebp 1.4.0-45129ee
highway 1.1.0-a296f93
snappy 2.1.2-2c94e11
libxml2 2.13.0-e349709
harfbuzz 8.5.0-484cb26
glib 2.81.0-c02f50f
freetype 2.13.2-b6dbbd9
lzma 5.7.0-a26dece
https://www.sendspace.com/file/qgdfzo
Old 26th May 2024, 13:46   #310  |  Link
Barough
Barough's Avatar
Opus-tools v0.2-34-g98f3ddc (using libopus 1.5.2-11-g2554a89)
https://www.mediafire.com/file/4yqjy0s9mr5cnu9
SoX Binary v14.4.2 (2024-05-26)
https://www.mediafire.com/file/u59xe71itcqn20i
Old 26th May 2024, 17:15   #311  |  Link
tebasuna51
tebasuna51's Avatar
The Changelog is from 2015-02-22.
For what we need a new version?
This new version is still broken, see Problem Flac | Sox
Old 26th May 2024, 19:12   #312  |  Link
Barough
Barough's Avatar
SoX relies on external libraries also and when some of these libraries is updated then media-autobuild_suite will make a new compile. If m-ab-s gives me a new compile i just make it available
If there is an issue with Sox, then report it over at http://sox.sourceforge.net.
See if you can try and get hold of Mans Rullgard, since he seems to be the only one that is still doing something with SoX. He made an addition to SoX 3 days ago.
There is nothing i can do about it.
Personally so do i just use SoX for making spectograms from FLAC files and that works just fine.
Old 27th May 2024, 19:11   #313  |  Link
Barough
Barough's Avatar
FFmpeg version n7.0.1-6-gd98358b329-gaead61451c+151 (x64) (GCC 14.1.0)
https://www.mediafire.com/file/1d95tsnab95hens
FFmpeg version n7.0.1-4-gb059dc4ced-g49c3918c1a+149 (x86) (GCC 14.1.0)
https://www.mediafire.com/file/1620wg92y6wd9nt
Old 28th May 2024, 21:04   #314  |  Link
seagate
ffms2 v.5.0
seagate is offline   Reply With Quote
Old 1st June 2024, 19:55   #315  |  Link
Barough
Barough's Avatar
MediaInfo v24.05.1
https://mediaarea.net/en/MediaInfo/Download/Windows
Old 3rd June 2024, 01:51   #316  |  Link
FTLOY
FTLOY's Avatar
MKVToolNix v85.0
https://mkvtoolnix.download/windows/releases/85.0/
Old 3rd June 2024, 18:32   #317  |  Link
Jamaika
ffmpeg version 7.1.0-18757b26 Copyright (c) 2000-2024 the FFmpeg developers
libavutil 59. 21.100 / 59. 21.100
libavcodec 61. 6.100 / 61. 6.100
libass 0.17.2-56ad347
libxml2 2.13.0-f0d8915
glib 2.81.0-59fd9b8
cairo 1.18.0-1193515
pcre2 10.43-9299bb9
freetype 2.13.2-d41a855
pango 1.53.0-6fab48a
lzma 5.7.0-b8d134e
highway 1.2.0-eb7bc8a
brotli 1.1.0-a528bce
libjxl 0.10.2-117342a
openjpeg 2.5.2-2c0823c
libwebp 1.4.0-0905f61
svt-av1 2.1.0-fcf5649
aom 3.9.0-a0f6102
libvp9 1.14.1-fd84dcc
dav1d 1.4.2-da2cc78
speex 1.2.1-6d7d5fe
nasm 2.17-a1e3140
https://www.sendspace.com/file/5kj4xd
ffmpeg_avx.exe -i "input.mp4" -y -vn -c:a libopus -ab 128k -ar 48000 -frames:v 1000 output_opus.ogg
ffmpeg_avx.exe -i "input.mp4" -y -vn -c:a liblc3 -ab 128k -ar 48000 -frames:v 1000 output_lc3.lc3
ffmpeg_avx.exe -i "input.mp4" -y -vn -c:a libcodec2 -ab 3000 -ar 8000 -mode 3200 -frames:v 1000 output_codec2.c2
ffmpeg_avx.exe -i "input.mp4" -y -vn -c:a libgsm -ab 13000 -ar 8000 -frames:v 1000 output_gsm.gsm
https://github.com/Jamaika1/plugins_..._vvc_evc_htj2k
Old 7th June 2024, 05:26   #318  |  Link
seagate
DGDemux v.1.0.0.74 (04.06.2024)
Old 9th June 2024, 07:25   #319  |  Link
Jamaika
ffmpeg version 7.1.0-714596bc Copyright (c) 2000-2024 the FFmpeg developers
built with GCC: (GNU) 14.1.0 (SIMD) AVX
configuration: -std=gnu++11 -march=x86-64-v2 -ftree-vectorize -g0 -O3 -fPIC -mavx -mxsave -mpclmul -maes -o lib/ffmpeg.exe fftools/ffmpeg.o fftools/ffmpeg_dec.o fftools/ffmpeg_demux.o fftools/ffmpeg_enc.o fftools/ffmpeg_filter.o fftools/ffmpeg_hw.o fftools/ffmpeg_mux.o fftools/ffmpeg_mux_init.o fftools/ffmpeg_opt.o fftools/cmdutils.o fftools/objpool.o fftools/opt_common.o fftools/sync_queue.o fftools/thread_queue.o -Llib -lavdevice_x64 -lavfilter_x64 -lavformat_x64 -lavcodec_x64 -lswresample_x64 -lswscale_x64 -lavutil_x64 -lpostproc_x64 -lwebp_x64 -lopenjpeg_x64 -lsvtjxs_x64 -ljxl_x64 -lcodec2_x64 -lgsm_x64 -logg_x64 -lvorbis_x64 -ltheora_x64 -llc3_x64 -lsnappy_x64 -lxavs_x64 -ldavs2_x64 -lxavs2_x64 -luavs3d_x64 -luavs3e_x64 -ltwolame_x64 -lspeex_x64 -lshine_x64 -lmp3lame_x64 -lxvid_x64 -lfdk-aac_x64 -lopenh264_x64 -lx264_opencl_0810bit_x64 -lkvazaar_x64 -lx265_081012bit_x64 -luvg266_x64 -lxevd_x64 -lxeve_x64 -lcelt_opus_silk_x64 -lvpx_x64 -ldav1d_x64 -laom_x64 -lsvtav1_x64 -lass_x64 -lrsvgdec_x64 -lcairo_pixman_x64 -l:fribidi_x64.a -l:freetype_harfbuzz_x64.a -lxml2_x64 -llcms2_x64 -l:zlib_x64.a -l:bzip2_x64.a -l:lzma_x64.a -lvmaf_x64 -l: opencv2_opencl_x64.a -l: opencl_x64.a -l:quirc_x64.a -lqrencode_x64 -lpthread_x64 -L. -lcfgmgr32 -ldnsapi -ldwrite -lbcrypt -liphlpapi -lgdi32 -lopengl32 -lole32 -loleaut32 -lsecurity -lshlwapi -lstrmiids -luuid -lvfw32 -lws2_32
libavcodec 61. 7.100 / 61. 7.100
Testing gcc+MinGW
https://github.com/brechtsanders/win...-11.0.1-r1.zip
libxavs2
parameters.c: In function 'xavs2_encoder_opt_set':
parameters.c:404:23: warning: '%d' directive writing between 1 and 10 bytes into a region of size 4 [-Wformat-overflow=]
  404 |         sprintf(str, "%d", ++i);
In function 'ParseRefContent',
    inlined from 'xavs2_encoder_opt_set' at parameters.c:695:23:
parameters.c:404:22: note: directive argument in the range [2, 2147483647]
parameters.c:404:9: note: 'sprintf' output between 2 and 11 bytes into a destination of size 4
[lc3 @ 000001b4815b6630] Encoder did not produce proper pts, making some up.
[libspeex @ 00000224e4d23040] 1 frames left in the queue on closing
Problem with:
ffmpeg_avx.exe -v verbose -i "input.mp4" -y -c:v libaom-av1 -vb 3000k -c:a libopus -ac 2 -ar 48000 -ab 128k -s 1920x1080 -frames:v 1000 -pix_fmt yuv420p -cpu-used 4 output_aom.mkv
ffmpeg_avx.exe -v verbose -i "input.mp4" -y -c:v libsvtjpegxs -vb 3000k -c:a aac -ab 128k -ar 48000 -frames:v 1000 -pix_fmt yuv420p output_jxs.mov
cairo -1193515
glib 2.81.0-601b8b4
harfbuzz 8.5.0-c1ca46e
libffi 3.4.6-9c9e836
libxml2 -ed3e53d
lzma -9e73918
pango 1.53.0-587807b
pcre2 10.43-6ae58be
speex 1.2.1-1de1260
aom 3.9.0-17aff84
libjxl 0.10.2-ab0bad3
highway -026be6b
https://www.sendspace.com/file/1xeb3d
Old 11th June 2024, 17:20   #320  |  Link
Barough
Barough's Avatar
dav1d v1.4.2-10-g01b94cc3
https://www.mediafire.com/file/b54zgueh0k6d4of
