Go Back   Doom9's Forum > Hardware & Software > PC Hard & Software
Old 2nd January 2023, 19:19   #1  |  Link
MalickT
How much does my PC or projector consume power for real?
PC - has 350W PSU
Projector - power input label shows 350W
Audio/Video Receiver - power input label 120V-240V 650W
So total power consumption should be 1350 Watt.
I connect all this to my UPS rated 1300 Watt and UPS shows only 35% load which is like 455 Watt. Even if I disconnect UPS from the main and UPS runs on batteries, it shows 35% and 15min remaining backup.
So could it be that the all my equipment actually uses only 455 Watt of power?
MalickT is offline   Reply With Quote
Old 2nd January 2023, 21:41   #2  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
The wattage shown on the labels is the MAXIMUM power consumption; ie, if you load your devices to the max, that's what they'll consume. In reality, power consumption is much lower. Your PC's processor doesn't constantly run at full load to consume its maximum power, neither does your receiver or projector.
Old 6th January 2023, 20:51   #3  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
At that particular moment in time (or whatever windowing your UPS uses to measure current) -- YES absolutely
Run a CPU and GPU stress test, turn your projector to its brightest setting, and crank up your amplifier and take another look. You'll see quite a lot more power being used.
