Go Back   Doom9's Forum > Hardware & Software > PC Hard & Software
Old 26th June 2022, 17:30   #1  |  Link
rupeshforu3
rupeshforu3's Avatar
Best Android tablet with high resolution display with qhd+ at lowest price.
Hi I am Rupesh from India and I want to buy a new tablet with low specifications but with high resolution display with qhd+ type.
At present Apple ipad has the highest resolution with DCI-P3 feature. But I can't spend 50000 to 60000 and so I am searching for android tablet.
I found that Xiaomi pad 5 has similar features like DCI-P3 and wqhd+ display and it costs around 26000.
Still I want a new tablet with even lower spec but with qhd+ resolution and if possible OLED display.
I found OLED display tablet from lenevo ie., Lenevo tab p11 pro, lenevo p12 pro etc., but it's cost is around 27000.
All of the above comes with octa core processors like Qualcomm 860 etc., and has nice features but costs lot.
My requirement is I want a new tablet with quad core processor, 1gb to 2gb ram, micro SD card support but with high resolution display and if possible OLED display.
I found realme tab which has WUXGA display and nokia tab T20 which has 2k resolution.
Mainly I want to read ebooks and so low resolution display can cause eye strain. Rarely I will see movies.
Can anyone of you suggest a new android tablet with high resolution display and with atleast qhd+ display type, quad core processor is enough as it cost less.
Regards,
Rupesh.
Sent from my LM-G710 using Tapatalk
rupeshforu3 is offline   Reply With Quote
Old 27th June 2022, 23:08   #2  |  Link
You seem to have settled on Nokia Tab T20 in some other forum.
Here's my small input,
If it supports it, try go for DARK mode/theme, with white text on black, very restful to the eyes,
and you dont get 'snowblind' reading in a dark room. [also good on battery]
10.4 inch is a nice size screen.
Old 28th June 2022, 02:58   #3  |  Link
rupeshforu3
Ok thanks for your suggestions.
Old 28th June 2022, 22:18   #4  |  Link
chainring
chainring's Avatar
If you can find one, a Samsung Galaxy Tab S6? I have one and its been fantastic. OLED, 8GB RAM, 256GB storage, microSD.
chainring is offline   Reply With Quote
Old 3rd July 2022, 07:17   #5  |  Link
PCU
Samsung Galaxy Tab models or old Google Pixel only.
PCU is offline   Reply With Quote
Old 5th July 2022, 15:24   #6  |  Link
rupeshforu3
Hi I heard that amoled display has been integrated into android smartphone.
May I know which tablets has been released with amoled display.
Old 6th July 2022, 02:07   #7  |  Link
Sunspark
Samsung sells a few tablets with amoled display.
Sunspark is online now   Reply With Quote
Old 6th July 2022, 02:42   #8  |  Link
rupeshforu3
May I know the names.
Old 6th July 2022, 03:24   #9  |  Link
Sunspark
Galaxy Tab S7+, S8+.
You should review the Samsung website for your own national market, they may not be available everywhere.
