Old 18th February 2024, 18:48   #21  |  Link
tormento
Acid fr0g
tormento's Avatar
Still have to see aq-mode 6 my count stops at 5 help!
@turment on Telegram
Old 18th February 2024, 19:50   #22  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Originally Posted by tormento View Post
Still have to see aq-mode 6… my count stops at 5… help!
It's bitmapping, so --aq-auto 6 enables the recommended stuff for HDR and --aq-auto 10 does the same for SDR (allows all modes for automatic switching). You can also set different strengths for different modes. I for example use --aq-strength 1.0 --aq-strength-edge 0.75 --aq-bias-strength 0.7 --aq-bias-strength-edge 0.8.
Old 21st February 2024, 15:06   #23  |  Link
tormento
Acid fr0g
tormento's Avatar
For SDR or HDR? Same for live action and anime?
Old 22nd February 2024, 06:06   #24  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I use the same for SDR and HDR (even though auto mode 6 skips the bias ones). I don't encode anime so the setting may need tuning for that. Note that the bias strengths are multipliers used with the non-bias one, for example strength for AQ-mode 3 is 1.0 * 0.7 = 0.7 in my case.
Old 22nd February 2024, 09:13   #25  |  Link
tormento
Acid fr0g
tormento's Avatar
Thank you.
I have tried to set those parameters but I can't understand for what aq-mode. I am using a GUI (StaxRip) and perhaps it's the reason I can't choose freely the number, i.e. I have 0 to 5 only. Choosing one of those, it allows you to modify the aq parameters (of course not with 0).
Old 22nd February 2024, 11:25   #26  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Thank you.
The aq-auto parameter is not the same as aq-mode. Aq-auto does automatic AQ-mode switching in the encoder no matter what mode you set as a parameter. So what you would need is to use jpsdr's x265 fork which includes the parameter and set the parameter --aq-auto 6 or 10 as a custom parameter if StaxRip has such functionality.
Old 22nd February 2024, 14:15   #27  |  Link
tormento
Acid fr0g
tormento's Avatar
StaxRip is double bonded with Patman builds, that, AFAIK, has aq-mode up to 5 but no aq-auto.
What multipliers could I use if limited to those modes?
P.S: Isn't --auto-aq instead of --aq-auto?
Old 22nd February 2024, 14:57   #28  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Well, the values for aq-strength based on the multipliers in my example would be 1.0 for modes 1 and 2, 0.7 for mode 3, 0.75 for mode 4 and 0.6 for mode 5.
You probably could replace the exe with jpsdr's one to use auto-aq (yes, the param is that way).
Old 24th February 2024, 11:27   #29  |  Link
tormento
Acid fr0g
tormento's Avatar
Can you please explain me the boolean values that make up the decimal number? I can't find anywhere.
Old 24th February 2024, 12:31   #30  |  Link
jpsdr
@tormento
From the help file:
   --aq-auto                     Configure auto-AQ mode. Disabled 0 (default), <>0 enabled
                                   - Bit 1: If set to 1, enable hysteresis.
                                   - Bit 2: If set to 1, enable HDR mode => don't use biased mode on auto-AQ.
                                   - Bit 3: If set to 1, replace AQ-MODE 1 by AQ-MODE 5. Overrided by bit 2.
Value of a bit = 2^(Number/position of the bit)
8 bit data for exemple, bit 0 (LSB) to bit 7 (MSB).
So, Bit 0 -> 2^0 = 1, Bit 1 -> 2^1 = 2, etc...
So, setting bit 1 and bit 2 result in 2+4=6 value.
Setting only bit 0, so 1, will just enable aq-auto, without any other option activated (or any other bit than [1,2,3]).
My github.
Old 24th February 2024, 13:40   #31  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by jpsdr View Post
@tormento
From the help file
Thank you! Do you maintain the help file on GitHub?
Old 25th February 2024, 10:42   #32  |  Link
jpsdr
The help file is included in the .7z pack releases, but it's generated with the following command : "x265_x64 --fullhelp > x265_Help.txt" (for 64bits version).
My github.
Old 18th March 2024, 14:43   #33  |  Link
tormento
Acid fr0g
tormento's Avatar
Did some tests with the material I encode most, i.e. anime.
Look here.
Really peculiar how aq-mode 3 is almost always better than any other mode.
--aq-auto was left with no parameter.
Old 18th March 2024, 14:57   #34  |  Link
tormento
Acid fr0g
tormento's Avatar
x265.exe: unrecognized option `--aq-strength-edge'
x265.exe: unrecognized option `--aq-bias-strength-edge'
What build do you use?
Old 18th March 2024, 16:47   #35  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I've used a patched build created with Media Autobuild Suite, but I'm sure https://github.com/jpsdr/x265/releases contains releases with all the goodies.
Old 18th March 2024, 19:31   #36  |  Link
jpsdr
And making new build (should be finished in 1 or 2 days) updated with the last Patman patches, especialy a patch called "fix rate control bug", wich worries me... Are all my encodes "screwed up"... as i didn't have this patch on them.
My github.
Old 18th March 2024, 19:37   #37  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Maybe it's for that age-old issue of sudden blocking in certain rather corner cases. I think it was shown to affect also x264 where the code was then ported when x265 was developed.
Old 18th March 2024, 20:57   #38  |  Link
tormento
Acid fr0g
tormento's Avatar
Please, if possible, provide some build for avx in llvm for my venerable Sandy Bridge.
The winthread one is so slow compared to msvc one.
Old 18th March 2024, 22:14   #39  |  Link
tormento
Acid fr0g
tormento's Avatar
So strange. Different builds can make a difference.
Seems like the suggested autoaq 10 is lower in quality than the implementation with no parameters at all (Patman builds).
Autoaq + tweaks are the suggested edge parameters.
As I stated, it's a very peculiar content, i.e. anime.
Old 19th March 2024, 21:21   #40  |  Link
jpsdr
It takes allready a lot of time make the builds, i don't want to add more.
My github.
